Windows 7 PCI to PCI x16 Adapter?
Andrew Butler
Does Anyone Know A Way To Put A Regular PCI Card, Such as a NIC, in a PCI x16 Slot?
Also, Would It Impact the speed of the card? (increase/decrease)
Thanks,
Andrew B. :)
You were perfectly clear. You want to install a PCI card into a PCIe (PCI Express) slot. You can't do that and there is no adapter that I am aware of that allows it. In spite of their similar names, PCI and PCIe use totally different slots, bus topologies, and controllers.
Rather that giving you an answer, I will provide this link. You are referring to a PCIe card and slot?
Sorry, I Wasn't Clear on my question. I Meant a regular PCI Slot (Not PCI-E), being used in a PCIx16 Slot.
