Windows 7 please help, bosd!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
nutcase06
hello ive had a few bluscreens since installing new memmory, this first happened on win7 32 bit
i also updated drivers before the first instant of bluescreen.
i later had to reinstall windows and so updated to 64bit, the problems persisted each time i would open the internet browser....
i then ran mem test on each memmory module and the results came back with nor failing ram.
i then found that the problem could have been caused due to me connecting to the internet via ethernet port because before that i would always connect using a netgear adapter. i found and uninstalled the drivers for the gigabit network port, and only used the netgear adapter to connect to the internet.
this seemed to have stopped the bluescreens.
now today i have had another bluescreen, few weeks since uninstalling the gigabit network driver.
this bluescreen happened as i was playing the witcher 2.
the only thing that has changed on my pc before this bluescreen, is that i have installed an extra set of speakers for the rear, setting up a 4 channel system.
please can anyone possibly help figure out what could actually be the problem.
i have attached the seven forum data files as well as jpegs of cpuz readings
kindest regards, nutcase06
  • Seven Forums.zip
  • cpuz readings.zip
How about starting by updating the following drivers
ASACPI.sys 3/27/2005 ASUSTeK Computer Inc. -Support- Drivers and Download P7P55D LE (expand utilities, about the 12th one down, ATK0110 driver for WindowsXP/Vista/Win7 32&64-bit)
scmndisp.sys 1/17/2007 Old Netgear Driver, often associated with Blue Screens try here WNDA3100 Model (that's your adapter I believe, if it doesn't have an update consider renaming to .OLD extension
wacommousefilter.sys 2/16/2007 Link Removed due to 404 Error
Rt64win7.sys 2/26/2009 Realtek
If Blue Screens persist after tending to the above issues please;
Download Memtest86+ from this location here. Burn the ISO to a CD and boot the computer from the CD.
Ideally let it run for at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test. Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Test RAM sticks individually. When you find a good one then test it in all slots. Post back with the results.
See this Guide to using Memtest 86+
Top Bottom
