Here is what I need to do..... I need to disable the properties for the lan adapter in Windows 7. For instance, a user right clicks on there network adapter and properties is disabled.
These systems are on a domain. I successfully achieved this with Windows XP machines using a GPO, however, the GPO does not work in Windows 7. So I figured I could achieve this via a registry edit. However, for the life of me I can not find the registry edit for Windows 7 that will allow me to do this. I can find the reg key in windows xp that will allow you disable the properties but I can not find the reg key or anyway in Windows 7.
Can anyone point me in the right direction? Ideally I would like to locate the reg key that will allow me to disable the lan properties and I can push that out via GPO.
Thank you,
Thank you,
