Please un-install the program,
then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):
[DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012):
Link Removed (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link:
Disc-Tools.com
Manual procedure here:
Link Removed - Invalid URL
[/quote
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Link Removed - Invalid URL (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: Link Removed
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
BIOS64.sys Sat Jun 7 20:12:00 2003 (3EE27F50)
This is probably aBIOSTAR I/O driver file
This one
MUST be removed from your system!!!
BS_I2c64.sys Mon Jun 16 02:45:18 2008 (48560BFE)
Found in BIOSTAR BIOS Flash Utility
Please remove from your system
BS_TPIO64.sys Wed Apr 29 23:17:44 2009 (49F91858)
Tosrfhid.sys Tue May 19 21:23:51 2009 (4A135BA7)
Toshiba Bluetooth HID Driver
tosporte.sys Tue Jun 16 06:48:47 2009 (4A37788F)
Toshiba Bluetooth Port Emulation Driver
tosrfbd.sys Tue Jul 7 08:13:38 2009 (4A533BF2)
Toshiba Bluetooth RF Bus Driver
tosrfusb.sys Tue Jul 28 04:45:07 2009 (4A6EBA93)
Toshiba Bluetooth Driver
tosrfcom.sys Tue Jul 28 06:18:20 2009 (4A6ED06C)
usbfilter.sys Wed Oct 7 03:44:08 2009 (4ACC46C8)
AMD USB Filter Driver (likely part of the chipset drivers)
ahcix64s.sys Wed Oct 21 09:40:52 2009 (4ADF0F64)
AMD AHCI Compatible RAID Controller
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon Sep 17 12:31:26.046 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091712-21949-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (6 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]2 days 2:45:19.131[/B]
BugCheck Code: [B]BugCheck 116, {fffffa801378e4e0, fffff880092a7008, 0, 2}[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]atikmpag.sys ( atikmpag+7008 )[/B]
BugCheck Info: [B]VIDEO_TDR_FAILURE (116)[/B]
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
BUGCHECK_STR: 0x116
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x116_IMAGE_atikmpag.sys[/B]
BIOS Version 080015
BIOS Release Date 08/31/2011
Manufacturer BIOSTAR Group
Product Name TA890FXE
**************************Thu Sep 6 04:48:24.619 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090612-18548-01.dmp]
System Uptime:[B]2 days 3:49:37.774[/B]
BugCheck Code: [B]BugCheck 116, {fffffa80192074e0, fffff88009282768, 0, 2}[/B]
Probably caused by :[B]atikmpag.sys ( atikmpag+8768 )[/B]
BUGCHECK_STR: 0x116
BIOS Version 080015
[/font]
3rd Party Drivers:
[B]BIOS64.sys Sat Jun 7 20:12:00 2003 (3EE27F50)[/B]
[B]BS_I2c64.sys Mon Jun 16 02:45:18 2008 (48560BFE)[/B]
[B]BS_TPIO64.sys Wed Apr 29 23:17:44 2009 (49F91858)[/B]
[B]Tosrfhid.sys Tue May 19 21:23:51 2009 (4A135BA7)[/B]
[B]tosporte.sys Tue Jun 16 06:48:47 2009 (4A37788F)[/B]
[B]tosrfbd.sys Tue Jul 7 08:13:38 2009 (4A533BF2)[/B]
amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
WmVirHid.sys Tue Apr 27 16:08:53 2010 (4BD74455)
WmXlCore.sys Tue Apr 27 16:09:26 2010 (4BD74476)
WmBEnum.sys Tue Apr 27 16:10:19 2010 (4BD744AB)
RTKVHD64.sys Fri Apr 30 05:05:58 2010 (4BDA9D76)
LVPr2M64.sys Fri May 7 21:38:16 2010 (4BE4C088)
lvrs64.sys Tue Nov 9 21:36:46 2010 (4CDA053E)
lvuvc64.sys Tue Nov 9 21:37:14 2010 (4CDA055A)
AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
speedfan.sys Sat Dec 18 06:03:51 2010 (4D0C9517)
epfwwfp.sys Tue Jun 28 03:30:08 2011 (4E098300)
epfw.sys Tue Jun 28 03:30:10 2011 (4E098302)
ehdrv.sys Tue Jun 28 03:34:38 2011 (4E09840E)
EpfwLWF.sys Mon Jul 11 12:19:38 2011 (4E1B229A)
eamonm.sys Tue Aug 2 05:33:29 2011 (4E37C469)
[B]sptd.sys Sat Aug 20 00:34:53 2011 (4E4F396D)[/B]
[B]dtsoftbus01.sys Mon Oct 17 08:12:30 2011 (4E9C1BAE)[/B]
avata6yi.SYS Mon Oct 17 11:34:18 2011 (4E9C4AFA)
mbam.sys Tue Mar 20 12:04:48 2012 (4F68AAA0)
avmfawox.SYS Mon Oct 17 11:34:18 2011 (4E9C4AFA)
AtihdW76.sys Thu Feb 23 07:30:12 2012 (4F463154)
[B]AODDriver2.sys Tue Mar 6 04:55:00 2012 (4F55DEF4)[/B]
atikmpag.sys Thu Apr 5 21:10:44 2012 (4F7E4294)
atikmdag.sys Thu Apr 5 21:48:25 2012 (4F7E4B69)
[/font]
avata6yi.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
avmfawox.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
