Please Help me!!! STOP e4
Please help me!!! BSOD for 3 months now
error e4
cannot run chkdsk C: error e4 appears
I'm stressed out a little more I'm gonna throw this laptop outside the window!
View attachment 071911-63617-01.rar
Thank you!!!
Elmer
Hi snowe and Welcome to the Forum.
STOP 0x000000E4: WORKER_INVALID
Usual causes:
Device driver, ?Memory
Your latest dump file lists ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
As a Priority:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct AVG Remover for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download Microsoft Security Essentials as AVG's replacement. Re-boot to Safe Mode. In Safe Mode run the AVG Removal tools. Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled!
Download and install CPU-Z. Take screenshots/snips of the Memory tab and all the slot#'s under the SPD tab. Attach the images directly to a post for all to see. Do not zip them.
Go to Post Reply, click on Go Advanced button and attach the screenshots to your post by using the paper clip you will find on the top toolbar.
Download and install RamMon.
Run RamMon, select the Export/Copy button. Select the Export/Copy format as HTML then Write to File. Attach the saved report in a zipped file.
Outdated Drivers. Update:
bcmwl664.sys Wed Jul 08 01:45:04 2009 Broadcom Virtual Wireless Adapter
enecir.sys Mon Jun 29 03:17:30 2009 ENE Consumer IR Driver for eHome Check with O.E.M. Support.
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also comes with iTunes
Rt64win7.sys Thu Feb 26 09:04:13 2009 Realtek PCIe GBE Family Controller v7.046
Bugcheck Analysis:
BugCheck E4, {1, fffff88002fe0c00, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+1052e )
Followup: MachineOwner
0: kd> !analyze -v
WORKER_INVALID (e4)
A executive worker item was found in memory which must not contain such
items or a work item was queued that is currently active in the system.
Usually this is memory being freed.  This is usually caused by
a device driver that has not cleaned up properly before freeing memory.
Arguments:
Arg1: 0000000000000001, Queuing of active worker item
Arg2: fffff88002fe0c00, Address of worker item
Arg3: 0000000000000000, Queue number
Arg4: 0000000000000000, 0
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xE4
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002f24a17 to fffff80002ec7600
STACK_TEXT:
fffff880`02fe0b08 fffff800`02f24a17 : 00000000`000000e4 00000000`00000001 fffff880`02fe0c00 00000000`00000000 : nt!KeBugCheckEx
fffff880`02fe0b10 fffffa80`04bfc665 : fffffa80`00000000 00000000`00000000 00000000`00000000 fffffa80`03cf4700 : nt! ?? ::FNODOBFM::`string'+0x1052e
fffff880`02fe0b80 fffffa80`00000000 : 00000000`00000000 00000000`00000000 fffffa80`03cf4700 fffff800`03041e80 : 0xfffffa80`04bfc665
fffff880`02fe0b88 00000000`00000000 : 00000000`00000000 fffffa80`03cf4700 fffff800`03041e80 fffff880`00000020 : 0xfffffa80`00000000
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02f24a17 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+1052e
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4b88cfeb
FAILURE_BUCKET_ID:  X64_0xE4_nt!_??_::FNODOBFM::_string_+1052e
Drivers:
fffff880`03c51000 fffff880`03c5e000   Accelerometer Accelerometer.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`00e00000 fffff880`00e57000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02d0a000 fffff880`02d94000   afd      afd.sys      Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`03c6e000 fffff880`03c84000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00ddc000 fffff880`00de7000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`00c76000 fffff880`00c7f000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00c7f000 fffff880`00ca9000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`03b15000 fffff880`03b5c000   avgldx64 avgldx64.sys Thu Jun 03 22:06:48 2010 (4C081968)
fffff880`03b0d000 fffff880`03b14080   avgmfx64 avgmfx64.sys Sun Apr 25 22:06:15 2010 (4BD4AEC7)
fffff880`01880000 fffff880`0188c0c0   avgrkx64 avgrkx64.sys Thu Feb 11 03:52:44 2010 (4B737F0C)
fffff880`019a4000 fffff880`019f5000   avgtdia  avgtdia.sys  Wed Apr 27 08:34:54 2011 (4DB7C71E)
fffff880`00dab000 fffff880`00db7000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`03cf2000 fffff880`03f9a000   bcmwl664 bcmwl664.sys Wed Jul 08 01:45:04 2009 (4A53EC10)
fffff880`018f8000 fffff880`018ff000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03afc000 fffff880`03b0d000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`02a30000 fffff880`02a4e000   bowser   bowser.sys   Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
fffff880`018c5000 fffff880`018ef000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00e57000 fffff880`00f17000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`03a43000 fffff880`03a55000   circlass circlass.sys Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`01850000 fffff880`01880000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00d11000 fffff880`00d6f000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03b98000 fffff880`03b9c500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`010e2000 fffff880`01155000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`00da2000 fffff880`00dab000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`03c5e000 fffff880`03c6e000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0188d000 fffff880`0189b000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03a5b000 fffff880`03ade000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`03ade000 fffff880`03afc000   dfsc     dfsc.sys     Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`02c97000 fffff880`02ca6000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`043cc000 fffff880`043ee000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`02cb8000 fffff880`02cc4000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0189b000 fffff880`018ae000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`048f4000 fffff880`048ff000   dump_msahci dump_msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`043f4000 fffff880`04400000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04800000 fffff880`048f4000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 02:00:14 2009 (4AC5509E)
fffff880`05322000 fffff880`05368000   dxgmms1  dxgmms1.sys  Tue Jul 14 00:38:32 2009 (4A5BC578)
fffff880`03c1e000 fffff880`03c3b000   enecir   enecir.sys   Mon Jun 29 03:17:30 2009 (4A48243A)
fffff880`01070000 fffff880`01084000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01024000 fffff880`01070000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`015a4000 fffff880`015ee000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`03c3b000 fffff880`03c48000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`02e0e000 fffff800`02e57000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`053dc000 fffff880`05400000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04200000 fffff880`0425c000   HdAudio  HdAudio.sys  Tue Jul 14 01:06:59 2009 (4A5BCC23)
fffff880`0426d000 fffff880`04286000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`0425c000 fffff880`0426d000   hidir    hidir.sys    Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`04286000 fffff880`0428e080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`02de8000 fffff880`02df6000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`01224000 fffff880`0122e000   hpdskflt hpdskflt.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`05c18000 fffff880`05ce0000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`0121b000 fffff880`01224000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`03fd9000 fffff880`03ff7000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`048ff000 fffff880`05321e20   igdkmd64 igdkmd64.sys Fri Feb 11 19:16:32 2011 (4D558B10)
fffff880`03b82000 fffff880`03b98000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`03c00000 fffff880`03c0f000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0428f000 fffff880`0429d000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00ba2000 fffff800`00ba5000   kdcom    kdcom.dll    Tue May 03 14:43:29 2011 (4DC00681)
fffff880`03a00000 fffff880`03a43000   ks       ks.sys       Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`013da000 fffff880`013f4000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Tue Jul 14 00:50:34 2009 (4A5BC84A)
fffff880`043ee000 fffff880`043f3200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05d7a000 fffff880`05d8f000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05d36000 fffff880`05d59000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cb9000 fffff880`00cfd000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`05d28000 fffff880`05d36000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03c0f000 fffff880`03c1e000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`03bf3000 fffff880`03c00000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c5c000 fffff880`00c76000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02a4e000 fffff880`02a66000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`02a66000 fffff880`02a8e000   mrxdav   mrxdav.sys   Tue Jul 14 00:23:57 2009 (4A5BC20D)
fffff880`02a8e000 fffff880`02abb000   mrxsmb   mrxsmb.sys   Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`02abb000 fffff880`02b09000   mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`02b09000 fffff880`02b2c000   mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`00ca9000 fffff880`00cb4000   msahci   msahci.sys   Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0195d000 fffff880`01968000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fd3000 fffff880`00fdd000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01084000 fffff880`010e2000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`02c8c000 fffff880`02c97000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`0149d000 fffff880`014af000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014b2000 fffff880`015a4000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`03ca8000 fffff880`03cb4000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`05de2000 fffff880`05df5000   ndisuio  ndisuio.sys  Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`03cb4000 fffff880`03ce3000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`042fb000 fffff880`04310000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02dd9000 fffff880`02de8000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02cc5000 fffff880`02d0a000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01968000 fffff880`01979000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02c80000 fffff880`02c8c000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e57000 fffff800`03433000   nt       ntkrnlmp.exe Sat Feb 27 07:55:23 2010 (4B88CFEB)
fffff880`01237000 fffff880`013da000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`018ef000 fffff880`018f8000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`05d8f000 fffff880`05de2000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02d9d000 fffff880`02dc3000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fea000 fffff880`00fff000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00d6f000 fffff880`00da2000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00dcc000 fffff880`00ddc000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`03800000 fffff880`038a6000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0438f000 fffff880`043cc000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cfd000 fffff880`00d11000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`03c84000 fffff880`03ca8000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`03b9d000 fffff880`03bb8000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`03bb8000 fffff880`03bd9000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`03bd9000 fffff880`03bf3000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02c2f000 fffff880`02c80000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`03ce3000 fffff880`03cee000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01942000 fffff880`0194b000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0194b000 fffff880`01954000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01954000 fffff880`0195d000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`011a1000 fffff880`011db000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`05c00000 fffff880`05c18000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03fa7000 fffff880`03fd9000   Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`038a6000 fffff880`038b1000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01493000 fffff880`0149d000   speedfan speedfan.sys Sat Dec 18 11:03:51 2010 (4D0C9517)
fffff880`0148b000 fffff880`01493000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`038e1000 fffff880`03979000   srv      srv.sys      Tue Dec 08 08:32:55 2009 (4B1E0F37)
fffff880`02b2c000 fffff880`02b95000   srv2     srv2.sys     Tue Jul 14 00:25:02 2009 (4A5BC24E)
fffff880`02a03000 fffff880`02a30000   srvnet   srvnet.sys   Tue Dec 08 08:32:26 2009 (4B1E0F1A)
fffff880`04310000 fffff880`0438f000   stwrt64  stwrt64.sys  Wed Mar 24 04:01:24 2010 (4BA98E94)
fffff880`03cee000 fffff880`03cef480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Tue Jul 14 00:25:34 2009 (4A5BC26E)
fffff880`01997000 fffff880`019a4000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01979000 fffff880`01997000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02c1b000 fffff880`02c2f000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`005e0000 fffff960`005ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03b5c000 fffff880`03b82000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`02ca6000 fffff880`02cb8000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`011db000 fffff880`011f8000   usbccgp  usbccgp.sys  Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`0429d000 fffff880`0429ef00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`053cb000 fffff880`053dc000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`042a1000 fffff880`042fb000   usbhub   usbhub.sys   Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`05375000 fffff880`053cb000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`05368000 fffff880`05375000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`05cfa000 fffff880`05d27100   usbvideo usbvideo.sys Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`00fdd000 fffff880`00fea000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`018ff000 fffff880`0190d000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0190d000 fffff880`01932000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`015ee000 fffff880`015fe000   vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00db7000 fffff880`00dcc000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01155000 fffff880`011a1000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`03f9a000 fffff880`03fa7000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02dc3000 fffff880`02dd9000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`05ce0000 fffff880`05cea000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`02c00000 fffff880`02c1b000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`01932000 fffff880`01942000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00f17000 fffff880`00fbb000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00fbb000 fffff880`00fca000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02d94000 fffff880`02d9d000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`0038f000   win32k   win32k.sys   unavailable (00000000)
fffff880`03c48000 fffff880`03c51000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fca000 fffff880`00fd3000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05d59000 fffff880`05d7a000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0188d000 fffff880`0189b000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0189b000 fffff880`018a7000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018a7000 fffff880`018b2000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`018b2000 fffff880`018c5000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
here are the shots you wanted =)
View attachment RAMinfo.rar
and here is the RAMinfo
thank you so much
questions
is it necessary to update them? I tried the automatic update and it said its already at it's best
and should I really uninstall AVG?
here are the pics
nmsuk
Windows Forum Admin
Hi
From the CPu-z shots I can see your memory timings are unfortunately misconfigured. The timings in the bios need to be set 667Mhz 9-9-9-25-34.
If you need help with memory timings please supply details of the make and model of your motherboard please.
Elmer
questions
Afraid so! But you've given me the opportunity to air my "canned speeches" again!!
Never
rely on Windows Update or Device Manager to update your drivers until you've exhausted your PC Mfr., Motherboard Mfr. or the software/hardware Mfr. resources. Windows Update is well known to update drivers backwards to older versions.
To stop Windows installing drivers Automatically
Go to Control Panel >> Devices and Printers, r-click your computer icon and select Device installation settings. Select No, let me choose what to do and Never install driver software from Windows Update >> Save Changes
The links I provided above will point you in the right direction for grabbing the latest drivers available.
AVG. It's best to remove it and replace with BSOD friendly MSE until your bluescreens are resolved. Feel free to re-install AVG after that, although I personally wouldn't.
Your RAM timings are out. You currently have it set at 6-6-6-15. It should be set to 9-9-9-24 @667mhz (or 333mhz).
NMSUK beat me to it! :D
Elmer
#7
EDIT!! Double post Again!! When I go to Post Quick Reply it asks me if I'm sure I want to navigate from the screen and data will be lost. Obviously it isn't but I'm ending up multi posting. This is haphazard by the way. No pattern.
found it!!!
Elmer
#9
That'll make NMSUK happy!
I suppose you'll be saying next you can't find an update for the Broadcom Driver.
Never fear! :cool: Elmer's here!! bcmwl664. Don't say I don't look after you! ;)
It's dated August '09 and is the newest I could find. But it is newer.
#10
lol thank you so much
actually I'm quite baffled when I went in there and just tried using the device manager ahaha =D
oh yeah and I'm still lost at the clock timing... should I restart my computer???
I am ashamed being a computer science student and all haha
thanks Elmer! and NMSUK =)
Elmer
#11
Bloomin' typical :D
Do you mean you've changed the settings already?
#12
no dunno how ahaha help!!!
Elmer
#13
NMSUK will be back shortly, he's had to nip out. Knows more about ram than I do!
#14
ok thanks!
Elmer
#15
While you are waiting, could you fill out some of your specs under your profile please? It helps no end!! If you get stuck you could d'load Speccy which will help you out with some of it.
Also, for info. In my BIOS I go to the advanced tab then arrow down to Chipset Configuration and hit Enter and that opens up my RAM timing settings. You could have a look to see if you've got the figures it's set at, 6-6-6-15 or its set on Auto.
The terminology may well be different!
nmsuk
Windows Forum Admin
#16
Sorry I've taken so long to get back to you. Could you post the hp model number from the underside of the laptop. I'll then check to see if there are any bios updates for it.
With laptops the bios is normally locked down so I'm thinking changing the timings is going to be a no go. I'm still hopeful there will be a bios update that will solve your problem.
Rich
#17
hmm.. is it dv6t - 1300
ahaha its ok It's around 5 o clock dawn in here
Elmer
#20
Hi snowe.
Usual causes:
In fact this .dmp file is identical to the previous one. There are still the old drivers and your RAM timings are still out.
You need to get these sorted otherwise you will never stop the BSOD's.
As a Priority:
AVG must go. Links in my post #2
RAM timings need resetting.
It is not wise to have old drivers on your PC. But the others mentioned in my post #2 can wait, They are not the priorities.
If you are struggling with anything, don't be afraid to ask. We are here to help. But you also have to help us to help you.
Drivers:
fffff880`04800000 fffff880`0480d000   Accelerometer Accelerometer.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`00f62000 fffff880`00fb9000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02d35000 fffff880`02dbf000   afd      afd.sys      Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`0481d000 fffff880`04833000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00de1000 fffff880`00dec000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`00cda000 fffff880`00ce3000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00d9c000 fffff880`00dc6000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`03b9a000 fffff880`03be1000   avgldx64 [COLOR=red] [B]avgldx64.sys Thu Jun 03 22:06:48 2010 (4C081968)[/B][/COLOR]
fffff880`03b92000 fffff880`03b99080   avgmfx64 [COLOR=red] [B]avgmfx64.sys Sun Apr 25 22:06:15 2010 (4BD4AEC7)[/B][/COLOR]
fffff880`01905000 fffff880`019110c0   avgrkx64 [COLOR=red] [B]avgrkx64.sys Thu Feb 11 03:52:44 2010 (4B737F0C)[/B][/COLOR]
fffff880`02c9f000 fffff880`02cf0000   avgtdia  [COLOR=red] [B]avgtdia.sys  Wed Apr 27 08:34:54 2011 (4DB7C71E)[/B][/COLOR]
fffff880`00e2b000 fffff880`00e37000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`048a4000 fffff880`04b4c000   bcmwl664 bcmwl664.sys Wed Jul 08 01:45:04 2009 (4A53EC10)
fffff880`019ae000 fffff880`019b5000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03b81000 fffff880`03b92000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`02bb0000 fffff880`02bce000   bowser   bowser.sys   Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`0194a000 fffff880`01974000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`043a3000 fffff880`043b5000   circlass circlass.sys Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`018d5000 fffff880`01905000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00d3e000 fffff880`00d9c000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03a3c000 fffff880`03a40500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`00e22000 fffff880`00e2b000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`0480d000 fffff880`0481d000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04fd6000 fffff880`04fe4000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03ae0000 fffff880`03b63000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`03b63000 fffff880`03b81000   dfsc     dfsc.sys     Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`03ad1000 fffff880`03ae0000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`018bf000 fffff880`018d5000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04e3d000 fffff880`04e5f000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`04fe4000 fffff880`04ff0000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`043c7000 fffff880`043da000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`04ff0000 fffff880`04ffb000   dump_msahci dump_msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04fca000 fffff880`04fd6000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04408000 fffff880`044fc000   dxgkrnl  dxgkrnl.sys  Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`044fc000 fffff880`04542000   dxgmms1  dxgmms1.sys  Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`04bc7000 fffff880`04be4000   enecir   [COLOR=red] [B]enecir.sys   Mon Jun 29 03:17:30 2009 (4A48243A)[/B][/COLOR]
fffff880`01141000 fffff880`01155000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010f5000 fffff880`01141000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`013ea000 fffff880`013f4000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01885000 fffff880`018bf000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`04be4000 fffff880`04bf1000   GEARAspiWDM [COLOR=red] [B]GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)[/B][/COLOR]
fffff800`033e7000 fffff800`03430000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`045b6000 fffff880`045da000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04e9d000 fffff880`04eb6000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`04e8c000 fffff880`04e9d000   hidir    hidir.sys    Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`04eb6000 fffff880`04ebe080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`043da000 fffff880`043e8000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`01200000 fffff880`0120a000   hpdskflt hpdskflt.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`02abb000 fffff880`02b83000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`013f4000 fffff880`013fd000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`04b8b000 fffff880`04ba9000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03c1d000 fffff880`04324380   igdkmd64 igdkmd64.sys Thu Aug 27 16:07:00 2009 (4A96A114)
fffff880`04e65000 fffff880`04e8c000   IntcHdmi IntcHdmi.sys Fri Jul 10 14:45:10 2009 (4A5745E6)
fffff880`03a26000 fffff880`03a3c000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`04ba9000 fffff880`04bb8000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04ebf000 fffff880`04ecd000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bbd000 fffff800`00bc0000   kdcom    kdcom.dll    Tue May 03 14:43:29 2011 (4DC00681)
fffff880`04360000 fffff880`043a3000   ks       ks.sys       Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`013bf000 fffff880`013d9000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`015b5000 fffff880`015e0000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`04e5f000 fffff880`04e64200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`03be1000 fffff880`03bf6000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03a41000 fffff880`03a64000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00ce6000 fffff880`00d2a000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)[/b][/color]
fffff880`043e8000 fffff880`043f6000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04bb8000 fffff880`04bc7000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04ecd000 fffff880`04eda000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`01974000 fffff880`019a5000   MpFilter MpFilter.sys Wed Sep 15 01:19:28 2010 (4C901110)
fffff880`02bce000 fffff880`02be6000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`01912000 fffff880`0193a000   mrxdav   mrxdav.sys   Tue Jul 14 00:23:57 2009 (4A5BC20D)
fffff880`010bf000 fffff880`010ec000   mrxsmb   mrxsmb.sys   Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`0467a000 fffff880`046c8000   mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`046c8000 fffff880`046eb000   mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`00dc6000 fffff880`00dd1000   msahci   msahci.sys   Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0181b000 fffff880`01826000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fc2000 fffff880`00fcc000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01155000 fffff880`011b3000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`03ac6000 fffff880`03ad1000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`015ea000 fffff880`015fc000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01463000 fffff880`01555000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`04857000 fffff880`04863000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`02a7a000 fffff880`02a8d000   ndisuio  ndisuio.sys  Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`04863000 fffff880`04892000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04f36000 fffff880`04f4b000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02c16000 fffff880`02c25000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02cf0000 fffff880`02d35000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01555000 fffff880`015b5000   NETIO    NETIO.SYS    Fri Apr 09 03:43:59 2010 (4BBE946F)
fffff880`05b5b000 fffff880`05b70000   NisDrvWFP NisDrvWFP.sys Wed Sep 15 01:20:25 2010 (4C901149)
fffff880`01826000 fffff880`01837000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03aba000 fffff880`03ac6000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e0a000 fffff800`033e7000   nt       ntkrnlmp.exe Wed Oct 27 03:43:09 2010 (4CC791BD)
fffff880`0121c000 fffff880`013bf000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`019a5000 fffff880`019ae000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`02a27000 fffff880`02a7a000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02dc8000 fffff880`02dee000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00e0d000 fffff880`00e22000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00fcc000 fffff880`00fff000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00dd1000 fffff880`00de1000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013d9000 fffff880`013ea000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`05a98000 fffff880`05b3e000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04e00000 fffff880`04e3d000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d2a000 fffff880`00d3e000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04833000 fffff880`04857000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`045da000 fffff880`045f5000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04325000 fffff880`04346000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`04346000 fffff880`04360000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03a69000 fffff880`03aba000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`04892000 fffff880`0489d000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01800000 fffff880`01809000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01809000 fffff880`01812000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01812000 fffff880`0181b000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`011b3000 fffff880`011ed000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`02a8d000 fffff880`02aa5000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04b59000 fffff880`04b8b000   Rt64win7 [color=red] [b]Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)[/B][/COLOR]
fffff880`02aa5000 fffff880`02ab1000   RtNdPt60 RtNdPt60.sys Mon Jul 20 03:27:32 2009 (4A63D614)
fffff880`05b3e000 fffff880`05b49000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`015e0000 fffff880`015ea000   speedfan speedfan.sys Sat Dec 18 11:03:51 2010 (4D0C9517)
fffff880`0145a000 fffff880`01462000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`04752000 fffff880`047e7000   srv      srv.sys      Fri Apr 29 04:13:05 2011 (4DBA2CC1)
fffff880`046eb000 fffff880`04752000   srv2     srv2.sys     Fri Apr 29 04:12:51 2011 (4DBA2CB3)
fffff880`02b83000 fffff880`02bb0000   srvnet   srvnet.sys   Fri Apr 29 04:12:35 2011 (4DBA2CA3)
fffff880`04f4b000 fffff880`04fca000   stwrt64  stwrt64.sys  Wed Mar 24 04:01:24 2010 (4BA98E94)
fffff880`0489d000 fffff880`0489e480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Fri Apr 09 03:45:54 2010 (4BBE94E2)
fffff880`05b49000 fffff880`05b5b000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`01855000 fffff880`01862000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01837000 fffff880`01855000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02c40000 fffff880`02c54000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`005a0000 fffff960`005aa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03a00000 fffff880`03a26000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`043b5000 fffff880`043c7000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`03c00000 fffff880`03c1d000   usbccgp  usbccgp.sys  Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`04ffb000 fffff880`04ffcf00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`045a5000 fffff880`045b6000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04edc000 fffff880`04f36000   usbhub   usbhub.sys   Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`0454f000 fffff880`045a5000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`04542000 fffff880`0454f000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`02c54000 fffff880`02c81100   usbvideo usbvideo.sys Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`019b5000 fffff880`019c3000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019c3000 fffff880`019e8000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`0144a000 fffff880`0145a000   vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00e37000 fffff880`00e4c000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e4c000 fffff880`00ea8000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01073000 fffff880`010bf000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`04b4c000 fffff880`04b59000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02c00000 fffff880`02c16000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`02ab1000 fffff880`02abb000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`02c25000 fffff880`02c40000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`019e8000 fffff880`019f8000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00eaf000 fffff880`00f53000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f53000 fffff880`00f62000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02dbf000 fffff880`02dc8000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000b0000 fffff960`003bf000   win32k   win32k.sys   unavailable (00000000)
fffff880`04bf1000 fffff880`04bfa000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fb9000 fffff880`00fc2000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`01862000 fffff880`01883000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`05b70000 fffff880`05be1000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01912000 fffff880`01920000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01920000 fffff880`0192c000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0192c000 fffff880`01937000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01937000 fffff880`0194a000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
