Hi koksu and Welcome to The Forum.
Latest:
STOP 0x0000001E: KMODE_EXCEPTION_NOT_HANDLED
Usual causes: Device driver, hardware, System service, compatibility, Remote control programs, memory, BIOS.
Previous 5:
STOP 0x00000101: CLOCK_WATCHDOG_TIMEOUT
Usual causes: Device driver, BIOS bug, hardware defect.
Your latest dump file lists
nwifi.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes often indicate hardware issues.
As a Priority:
athrxusb.sys Tue Jul 29 13:47:13 2008 Atheros Wireless LAN driver
Outdated Drivers. Update:
hamachi.sys Thu Feb 19 10:36:41 2009 LogMeIn Hamachi Virtual Network Driver
Drivers with Updates:
Rt64win7.sys Mon Oct 25 10:33:07 2010 Realtek PCIe GBE Family Controller v7.046
RTKVHD64.sys Tue Nov 23 10:14:08 2010 Realtek HD Audio R2.64
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck 1E, {0, 0, 0, 0}
Unable to load image \SystemRoot\system32\DRIVERS\athrxusb.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athrxusb.sys
*** ERROR: Module load completed but symbols could not be loaded for athrxusb.sys
Probably caused by : nwifi.sys ( nwifi!Pt6RepackRecvNBL+58d )
Followup: MachineOwner
0: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) - The operation completed successfully.
FAULTING_IP:
+3632366562393638
00000000`00000000 ?? ???
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000000
ERROR_CODE: (NTSTATUS) 0 - STATUS_WAIT_0
BUGCHECK_STR: 0x1E_0
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 2
EXCEPTION_RECORD: fffff800044c5ff8 -- (.exr 0xfffff800044c5ff8)
ExceptionAddress: fffff8800383ebf1 (nwifi!Pt6RepackRecvNBL+0x000000000000058d)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME: fffff800044c60a0 -- (.trap 0xfffff800044c60a0)
rax=3ddc0385060024f6 rbx=0000000000000000 rcx=00000000000005c8
rdx=fffff800044c62a0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800383ebf1 rsp=fffff800044c6230 rbp=fffffa8005c01018
r8=0000000000000000 r9=0000000000000000 r10=fffff88003874110
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na po nc
nwifi!Pt6RepackRecvNBL+0x58d:
fffff880`0383ebf1 488b00 mov rax,qword ptr [rax] ds:9410:3ddc0385`060024f6=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000308c5fe to fffff80003094c10
STACK_TEXT:
fffff800`044c50d8 fffff800`0308c5fe : 00000000`00000000 fffffa80`05ed53e0 fffff800`044c5850 fffff800`030c0830 : nt!KeBugCheck
fffff800`044c50e0 fffff800`030c04fd : fffff800`0329e71c fffff800`031dbc30 fffff800`03018000 fffff800`044c5ff8 : nt!KiKernelCalloutExceptionHandler+0xe
fffff800`044c5110 fffff800`030bf2d5 : fffff800`031df0fc fffff800`044c5188 fffff800`044c5ff8 fffff800`03018000 : nt!RtlpExecuteHandlerForException+0xd
fffff800`044c5140 fffff800`030d0361 : fffff800`044c5ff8 fffff800`044c5850 fffff800`00000000 fffffa80`00000005 : nt!RtlDispatchException+0x415
fffff800`044c5820 fffff800`030942c2 : fffff800`044c5ff8 3ddc0385`060024f6 fffff800`044c60a0 fffff800`044c62a0 : nt!KiDispatchException+0x135
fffff800`044c5ec0 fffff800`03092bca : 00000000`00000000 fffff800`044c6990 00000000`00000000 fffff880`1005a30d : nt!KiExceptionDispatch+0xc2
fffff800`044c60a0 fffff880`0383ebf1 : 00000000`00000000 fffff880`1005a565 fffffa80`05b7f560 fffff800`044c6990 : nt!KiGeneralProtectionFault+0x10a
fffff800`044c6230 fffff880`0383f021 : fffffa80`0480d650 00000000`00000000 00000000`00000000 fffffa80`06004010 : nwifi!Pt6RepackRecvNBL+0x58d
fffff800`044c6280 fffff880`0383f6fc : fffffa80`06004010 fffffa80`05b3e275 fffffa80`00001275 fffffa80`06004010 : nwifi!Pt6RepackRecvNBL+0x9bd
fffff800`044c64d0 fffff880`0142a4f7 : fffffa80`05b361a0 fffffa80`05c27750 00000000`00000001 fffffa80`05baebe8 : nwifi!Pt6Receive+0x1a4
fffff800`044c6530 fffff880`038a4202 : 00000000`00000000 fffff880`00fb9130 fffffa80`04c0f660 fffffa80`05b36000 : ndis! ?? ::FNODOBFM::`string'+0xcf1f
fffff800`044c6580 00000000`00000000 : fffff880`00fb9130 fffffa80`04c0f660 fffffa80`05b36000 fffffa80`00000001 : athrxusb+0x11202
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 7
SYMBOL_NAME: nwifi!Pt6RepackRecvNBL+58d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nwifi
IMAGE_NAME: nwifi.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bcc3b
FAILURE_BUCKET_ID: X64_0x1E_0_nwifi!Pt6RepackRecvNBL+58d
Drivers:
fffff880`02d95000 fffff880`02dd3000 1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00e00000 fffff880`00e57000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`0400f000 fffff880`04098000 afd afd.sys Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`048e2000 fffff880`048f8000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01137000 fffff880`01142000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`05cea000 fffff880`05d0c000 asmthub3 asmthub3.sys Wed Dec 08 10:14:14 2010 (4CFF5A76)
fffff880`02c00000 fffff880`02c5e000 asmtxhci asmtxhci.sys Wed Dec 08 10:14:06 2010 (4CFF5A6E)
fffff880`00c7a000 fffff880`00c83000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0108f000 fffff880`010b9000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`03893000 fffff880`039a0000 athrxusb athrxusb.sys Tue Jul 29 13:47:13 2008 (488F1151)
fffff880`01699000 fffff880`016a0000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`02d08000 fffff880`02d19000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`081a6000 fffff880`081c4000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00780000 fffff960`007a7000 cdd cdd.dll unavailable (00000000)
fffff880`01666000 fffff880`01690000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00e72000 fffff880`00f32000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01600000 fffff880`01630000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00ce8000 fffff880`00d46000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01072000 cng cng.sys Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`048d2000 fffff880`048e2000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`039a0000 fffff880`039ae000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`02c67000 fffff880`02cea000 csc csc.sys Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`02cea000 fffff880`02d08000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`041cf000 fffff880`041de000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`019e7000 fffff880`019fd000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04c3d000 fffff880`04c5f000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`039ba000 fffff880`039c3000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`039ae000 fffff880`039ba000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`039c3000 fffff880`039d6000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05d61000 fffff880`05d6d000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`10a76000 fffff880`10b6a000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`10b6a000 fffff880`10bb0000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0118e000 fffff880`011a2000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01142000 fffff880`0118e000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01211000 fffff880`0121b000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`019ad000 fffff880`019e7000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`018aa000 fffff880`018f4000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`03601000 fffff800`0364a000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`049ad000 fffff880`049b8000 hamachi hamachi.sys Thu Feb 19 10:36:41 2009 (499D3639)
fffff880`10bb0000 fffff880`10bd4000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`10bd4000 fffff880`10be5000 HECIx64 HECIx64.sys Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`05d7b000 fffff880`05d94000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05d94000 fffff880`05d9c080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05d6d000 fffff880`05d7b000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`080dd000 fffff880`081a6000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`019a4000 fffff880`019ad000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`04886000 fffff880`048a4000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`048bc000 fffff880`048d2000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`048a4000 fffff880`048b3000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00ba2000 fffff800`00bac000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04cf6000 fffff880`04d39000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013e1000 fffff880`013fc000 ksecdd ksecdd.sys Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`0155a000 fffff880`01585000 ksecpkg ksecpkg.sys Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`04c5f000 fffff880`04c64200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`03821000 fffff880`03836000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`039d6000 fffff880`039f9000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c85000 fffff880`00cd4000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`05dac000 fffff880`05dba000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`049c3000 fffff880`049d2000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05d9f000 fffff880`05dac000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c10000 fffff880`00c2a000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`081c4000 fffff880`081dc000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`08000000 fffff880`0802d000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0802d000 fffff880`0807b000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0807b000 fffff880`0809f000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`015e3000 fffff880`015ee000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e60000 fffff880`00e6a000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`011a2000 fffff880`01200000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`041c4000 fffff880`041cf000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01992000 fffff880`019a4000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`010b9000 fffff880`01100000 mv61xx mv61xx.sys Wed Oct 06 04:54:31 2010 (4CABF2F7)
fffff880`0112f000 fffff880`01137000 mv61xxmm mv61xxmm.sys Wed Oct 06 04:54:18 2010 (4CABF2EA)
fffff880`01407000 fffff880`014fa000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0491c000 fffff880`04928000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`05dba000 fffff880`05dcd000 ndisuio ndisuio.sys Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04928000 fffff880`04957000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04da5000 fffff880`04dba000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`0410c000 fffff880`0411b000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04098000 fffff880`040dd000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`014fa000 fffff880`0155a000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`015ee000 fffff880`015ff000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`041b8000 fffff880`041c4000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03018000 fffff800`03601000 nt ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`0123e000 fffff880`013e1000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01690000 fffff880`01699000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`10a71000 fffff880`10a76000 nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`04dba000 fffff880`04de7000 nvhda64v nvhda64v.sys Tue May 10 10:41:18 2011 (4DC9083E)
fffff880`0fe0d000 fffff880`10a71000 nvlddmkm nvlddmkm.sys Wed Aug 03 10:08:32 2011 (4E391010)
fffff880`03836000 fffff880`03889000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`040e6000 fffff880`0410c000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00d79000 fffff880`00d8e000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d46000 fffff880`00d79000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00ff2000 fffff880`00ff9000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c00000 fffff880`00c10000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`08484000 fffff880`0852a000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04c00000 fffff880`04c3d000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cd4000 fffff880`00ce8000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`048f8000 fffff880`0491c000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04957000 fffff880`04972000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04972000 fffff880`04993000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04993000 fffff880`049ad000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04167000 fffff880`041b8000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`049b8000 fffff880`049c3000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`015c8000 fffff880`015d1000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015d1000 fffff880`015da000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015da000 fffff880`015e3000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01958000 fffff880`01992000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05dcd000 fffff880`05de5000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04815000 fffff880`0487a000 Rt64win7 Rt64win7.sys Mon Oct 25 10:33:07 2010 (4CC54ED3)
fffff880`05a79000 fffff880`05ce9c00 RTKVHD64 RTKVHD64.sys Tue Nov 23 10:14:08 2010 (4CEB93F0)
fffff880`01100000 fffff880`0112f000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`0852a000 fffff880`08535000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0487a000 fffff880`04886000 serenum serenum.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0411b000 fffff880`04138000 serial serial.sys Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01950000 fffff880`01958000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`086e5000 fffff880`0877d000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`08578000 fffff880`085e1000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`08535000 fffff880`08566000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`049d2000 fffff880`049d3480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`016a6000 fffff880`018aa000 tcpip tcpip.sys Tue Jun 21 04:33:55 2011 (4E001123)
fffff880`08566000 fffff880`08578000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01072000 fffff880`0107f000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0121b000 fffff880`0123d000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04153000 fffff880`04167000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00500000 fffff960`0050a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`02d19000 fffff880`02d3f000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`05d0c000 fffff880`05d61000 udfs udfs.sys Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`04d39000 fffff880`04d4b000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05d9d000 fffff880`05d9ef00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`10be5000 fffff880`10bf6000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04d4b000 fffff880`04da5000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`02d3f000 fffff880`02d95000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`0877d000 fffff880`08798000 USBSTOR USBSTOR.SYS Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`00fe5000 fffff880`00ff2000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01585000 fffff880`01593000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01593000 fffff880`015b8000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00c2a000 fffff880`00c66000 vmbus vmbus.sys Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`018f4000 fffff880`01904000 vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00d8e000 fffff880`00da3000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00da3000 fffff880`00dff000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01904000 fffff880`01950000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`04138000 fffff880`04153000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`015b8000 fffff880`015c8000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00f32000 fffff880`00fd6000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00fd6000 fffff880`00fe5000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`040dd000 fffff880`040e6000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00333000 win32k win32k.sys unavailable (00000000)
fffff880`00c66000 fffff880`00c7a000 winhv winhv.sys Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`048b3000 fffff880`048bc000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00e57000 fffff880`00e60000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`03800000 fffff880`03821000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`01630000 fffff880`0163e000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`0163e000 fffff880`0164a000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`0164a000 fffff880`01653000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`01653000 fffff880`01666000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
