Ok I have been almost everywhere and still i cannot find a solution to this
So like everytime i move my Taskbar anywhere from left to right up or down it goes milky and then i get the infamous Windows explorer is not responding.... I have tried SFC/scannow repair install spyware scanners and still this problem continues this is what my event viewer tells me.
Log Name: Application
Source: Application Hang
Date: 8/1/2010 9:17:09 PM
Event ID: 1002
Task Category: (101)
Level: Error
Keywords: Classic
User: N/A
Computer: Jey-PC
Description:
The program Explorer.EXE version 6.1.7600.16450 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: 76c
Start Time: 01cb31f934f8d6e0
Termination Time: 31
Application Path: C:\Windows\Explorer.EXE
Report Id: cef18e41-9dec-11df-b139-001bfce0d7f7
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/…
<System>
<Provider Name="Application Hang" />
<EventID Qualifiers="0">1002</EventID>
<Level>2</Level>
<Task>101</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-08-02T04:17:09.00000000… />
<EventRecordID>6684</EventRecordID>
<Channel>Application</Channel>
<Computer>Jey-PC</Computer>
<Security />
</System>
<EventData>
<Data >Explorer.EXE</Data>
<Data>6.1.7600.16450</Data>
<Data>76c</Data>
<Data>01cb31f934f8d6e0</Data>
<Data>31</Data>
<Data>C:\Windows\Explorer.EXE</Data>
<Data>cef18e41-9dec-11df-b139-001bfce0…
<Binary>430072006F00730073002D00740068…
</EventData>
</Event>
The shell stopped unexpectedly and explorer.exe was restarted.I'm desperate,Somebody help?
Event ID: 1002
Level: Error
Keywords: Classic
User: N/A
Computer: Jey-PC
Description:
Process ID: 76c
Event Xml:
<System>
<Level>2</Level>
<Task>101</Task>
<Security />
</System>
<EventData>
<Data>76c</Data>
<Data>31</Data>
</EventData>
</Event>
