I frequently experience BSOD problems ever since I bought this ASUS X53S one and a half month ago. I once reset the whole laptop back to default settings but that did not solve the problem. The OS is Win7 Home 64 bit and I used AVG Free 2011 antivirus and Zonealarm free firewalls.
I recon it might be the problem for the two graphic cards but I should have already installed the newest drivers for these cards.
The problem keep occuring when I run 3D video games.
Here I copied the most recent crash report from WhoCrashed.exe
On Sun 2011/6/12 と 09:30:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061211-32229-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7FCD0)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft? Windows? Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheck+0x0)
Thank you very much for your help.
