pls help
can anyone help.. everytime i install windows 7 x64 i always got blue screen i dunno why it appears... it appears during the finalization of the installation.....here are the specs of my pc.....
Athlon64 X2 5000+
4x 2gig ddr2 ram
seagate 80 gig ATA
Asus M2A-VM board
Samsung DVDRW
thanks in advance...
can anyone help.. everytime i install windows 7 x64 i always got blue screen.
Is this a clean install? Is this a factory disk?
At what point does it fail?
it occurs during the last phase of the installation.... i think its finishing or finalization
..... but when i install 32 bit of win7 it works fine but when i install 64 bit version it has errors and have blue screens...
like when i install vista x64 i have the same problem... pls help... thanks
Unless you have 4+ GB ram there is no advantage to install 64 bit.
i have 8 gigs of ram... i tried using 2 gig during installation and it works but when i put back all the remaining ram sticks the blue screen appears again... so i remove it again and windows says in the desktop that... windows recover from critical error i think.... and this also appear in that box...
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA80042F8280
BCP2: FFFFF88003A3B7F8
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\111509-16863-01.dmp
C:\Users\bxell_nash\AppData\Local\Temp\WER-35880-0.sysdata.xml
pls help me so that i can use all my rams
Probably have to go into your bios and reset to factory setting... or maybe even clear your cmos.
