Windows Vista Power breakdown, vista damaged
Cliffus
Hi
yesterday my computer (with windows vista enterprise) was up and running. Suddenly there was a power breakdown and as it should be the computer restarted. While it was restarting another power breakdown occured... now Vista woun't boot anymore...
This happens:
I have a dual boot system (xp and vista), when I choose Vista it continious and the loading screen of Vista appears, then when normally the login screen appears there is only a black screen.
The vista repair tool doesn't work... but I still can use the computer via Windows XP, so I can repair it probably by myself... I only don't know what to do? Wich files are damaged?
Thank you VERY MUCH!
Cliff
Try booting into XP and do a drive scan. most the time it's caused by a file getting miss written. Normally that will fix the problem.
Top Bottom
