In the pre beta 6801 build the powercfg -energy command line command saved a file called energy-report.html to the system32 file folder. It worked perfectly. But now in the beta build when i ran the command it successfully runs and i go search for the file and when i search it shows up but says file cannot be found. So i manually go to C:\Windows\System32\energy-report.html and can not see the file. I have tried saving the file as a different name and even changing the directory where it is saved at it is a no go. Both were 64 bit. Any thoughts?
