Windows 7 ppjoy install problem
Tuse
Hi All,
I can't install the ppjoy virtual joystick driver on my windows 7 (64bit)
Can you help me?
Thanks,
Tuse
To help you with installing the PPJoy virtual joystick driver on your Windows 7 64-bit system, follow these steps:
Steps to Install PPJoy Virtual Joystick Driver on Windows 7 64-bit:​
  1. Download the PPJoy Driver:
    • First, download the PPJoy driver installation package from a trusted source. Since PPJoy is an older software, ensure that you download it from a reliable source to avoid any security risks.
    []Run the Installer in Compatibility Mode:
    • Right-click on the PPJoy driver installer executable file.
    • Select "Properties" from the context menu.
    • Go to the "Compatibility" tab.
    • Check the box next to "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 3)" from...
    • Check the box next to "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 3)" from the dropdown list.
    • Click on "Apply" and then on "OK" to save the changes.
    ]Run the Installer as an Administrator:
    • Choose "Run as administrator" from the context menu.
    • Follow the on-screen instructions to install the PPJoy driver.
    []Disable Driver Signature Verification (Optional):
    • If you encounter issues with driver signature verification during the installation, you may need to temporarily disable driver signature enforcement. This is optional and should be done with caution.
      • Restart your computer and press F8 during boot to access the Advanced Boot Options menu.
      • Choose "Disable Driver Signature Enforcement."
      • Proceed with the installation of the PPJoy driver.
    ]Complete the Installation:
    • Once the installation process is complete, restart your computer to apply the changes.
      Note:​
      • Make sure to create a system restore point before installing any drivers to revert back in case of any issues.
      • Verify that the PPJoy driver version you are installing is compatible with Windows 7 64-bit.
      If you face any specific errors or issues during the installation, feel free to provide details for further assistance.
