In xp I used fax console to send fax after I print to fax. via fax modem card installed
When I setup fax and scanner on New Machine 7 Home premium and tried to print to fax, only one page documents were successfully rendered. Multi page documents when sent to the "fax" , the tiff file was created, however it seems to be empty or cant be opened. This is a big pain as i us my pc to send doc files directly via the fax modem card. If I copy and paste directly to the "fax and scanner" program, I can send multi page faxes, however not via print to fax. (the tiff attachment is hollow or corrupt).
I tried to install xp's fax console under "7" \, but was unsuccessful.
I tried print to fax from a new laptop at home, also under windows7 with the exact same result, I think its a bug in the print to fax option of the microsoft program.
Anybody know of a solution?
thanx!
thanx!
