gamer88
oke i have W7 ultimate and i have installed pes 2011...
i enter the game and start chose option to play but then my sistem crash(restart) and i don't know why :(
can anybody help me please...
It seems like you're experiencing a system crash or restart issue when trying to play PES 2011 on Windows 7 Ultimate. System crashes or restarts during gameplay can be caused by various factors. Here are some troubleshooting steps you can try to resolve this issue:
Steps to Troubleshoot System Crashes when Playing PES 2011:​
  1. Update Graphics Drivers:
    • Ensure that your graphics card drivers are up to date. Outdated or corrupt graphics drivers can cause crashes during gameplay.
    []Check System Requirements:
    • Make sure your system meets the minimum requirements to run PES 2011. If your system falls short of the requirements, it can lead to crashes.
    ]Disable Background Programs...
    ]Disable Background Programs:
    • Close any unnecessary programs running in the background. Some applications can conflict with games and cause stability issues.
    []Run the Game in Compatibility Mode:
    • Right-click on the game's shortcut or executable file, go to Properties, and under the Compatibility tab, try running the game in compatibility mode for an older version of Windows like Windows XP.
    ]Check for Game Updates:
    • Ensure that PES 2011 is updated to the latest version. Developers often release patches to address known issues.
    []Monitor System Temperature:
    • Overheating can also cause system crashes. Use software to monitor your system's temperature during gameplay.
    ]Run System File Checker:
    • Open a command prompt as an administrator and run the command sfc /scannow to check for and repair corrupted system files.
    []Check Event Viewer:
    • Look for any error messages in the Windows Event Viewer related to the system crash. This can provide more insights into the cause.
    ]Update Windows:
    • Make sure Windows is up to date with the latest updates and security patches.
      Additional Recommendations:​
      • Consider upgrading to a newer version of Windows for better performance and compatibility with modern games.
      • Ensure your system meets the recommended hardware specifications for PES 2011.
      Try these steps and see if they help resolve the issue. If the problem persists, feel free to provide more details, and we can further assist you in troubleshooting the crash issue.
