- Thread Author
- #1
SOLVED: problem changing a particular file association
Hello!
I have a problem trying to change the program associated with a particular file extension. I was trying out different programs to find out how they could handle that particular file type, setting them as the default program and trying to open the file. But after setting the default to one program in particular, it seemed to "lock" the file type as its own, and the association will not change any more. When I right-click on the file and choose "open with..." then "choose default program", the "always use the selected program..." check box is disabled. This is true only for that particular file extention, all other extensions have this option enabled and the association can be changed. If I open the default programs control panel, and try to choose a different program to be associated with that particular extension, the entry does not change after choosing the program and clicking "OK" - it stays at the previous setting.
Please help.
edit: solved it myself. The was a "user choice" entry in HKLM/software/classes/file extension. I do not know how it got set, but removing it re-enabled the option to choose the default program for that particular extent ion in explorer
Hello!
Please help.
