Windows 7 Problem When Trying to Open a PDF in FireFox
cgrim29588
When I go to a web page in FireFox and try to open a PDF I get this:
Windows cannot find 'C:\Program Files (x64)\Mozilla Firefox\Eula.exe' Make sure you typed the name correctly, and then try again
I even tried reinstalling FireFox,, but still get the same message help!
I think you'd better tell us which PDF tools are you using.
I have met problems with openning PDF in IE window, and finally found there's some compatibility problem between Adobe Acrobat 8 and IE 8. Now I am using Acrobat 9, it is all OK with IE and Firefox.
Sounds like an issue with Adobe plugins and using a 64bit version of firefox, rather than the regular 32bit version looking at the directory tree you mention.
I'm using Firefox 3.6.3
One way to try is to copy 'plugins' from "C:\Program Files (x86)\Mozilla Firefox\" to "C:\Program Files\Mozilla Firefox\" - a good chance it'll work as it has for my Firefox portable.
Also, make sure to install/update Adobe Reader from Adobe official site.
Adobe - Adobe Reader download - All versions
Actually I have a question, do you really have "C:\Program Files (x64)" ? In my 7x64 I have only "Program Files (x86)" and simply "Program Files", but not (x64).
As mentioned by highwayman, Adobe and 64-bit don't mix well with Firefox..
I'd suggest using Foxit Reader. It also has a firefox/internet explorer plugin and is much similar to Reader.
This is not an advertisement, just a recommendation ;):D
