Windows 7 Problem With Facebook
Spirit789
Honorable Member
Facebook is loading slowly with me, how I can solve it?
I've noticed this from time to time and it may be just how the net is acting that day especially if you regularly keep your system clean with an app like Ccleaner.
That's probably your issue then.. Try running Ccleaner although not the registry cleaner as that isn't needed with windows.
Just to make sure nothing nasty is causing the slowdown try running this app from time to time too as it's very good at removing malware as it's easy for it to sneak onto the system:
https://www.malwarebytes.org/
I'd still try running Malwarebytes personally.. Also I presume you've now tried Ccleaner? If so is Facebook opening any faster?
Yes, it was faster than before
I cleaned 600,000 temporary internet files by CCleaner and not finished yet
it is stuck at 0%
If it's at 0% then that should mean all the temp files have been removed.
In fact, that's mean there a lot of them
cuz if I run it again, it's cleaned more
Oh right gotcha... If you go into advanced options you'll see a checkbox to not delete anything downloaded in the last 24hrs I always uncheck that too. Also try running Ccleaner as administrator too.
here my advanced options
Yeah that's it... Just uncheck the top box.
