Windows 7 Problem with font apperance.
I need help here ! I cant get this " 1 " back straight . Most of the word i view in internet and games is all in Italic .
Any suggestion to help me out ?
reghakr
Try right-clicking on the desktop and choose personalize. Now click the Windows color entry, the the Advanced appearance settings and change the fonts here.
Don't mess around with any other entries as you will loose he Aero effects.
Now exit out and see if thisfthe problem./
Yes. i still have that problem . By the way, i have missing font dont know whether u can send me anot if u have it ?
Just wondering if you installed some sort or desktop publishing software and then uninstalled it and wiped out those fonts because the program put them there.........justa a wild guess.
Perform a search for this file:
fms_metadata.xml
i found this post . That you post it .
Its is this problem ... i uninstall left 4 dead. Its remove my tahoma fonts then my font all become italic ..
i dont know how to repair it ..
reghakr
What did you uninstall?
If you know the font names I can upload them for you.
#7
I uninstall left 4 dead then it uninstall my tahoma font. i get it back but still italic.
Do you have all window 7 font ? maybe u send me all i try see whether can ?
reghakr
#8
Yea, sure,
I have 268 of them.
reghakr
#10
Packing which ones up?
reghakr
#12
Packed size ids 197,850.871KB..............way to large to upload
I looked in the registry, I think I know which ones you need..
Hang on, it will take a while
Still too big 6.30MB
Tyhe fonts you need are
Calibri
Cambria
Consolas
Georgia
Segoe UI Symbol
Verdana
You can find them ion the Internet
#13
Calibri
Cambria
Consolas
Georgia
Segoe UI Symbol
Verdana
Where do you find the registry
reghakr
#14
It was under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Font Management
reghakr
#16
What is =X?
#17
Er nevermind just an emotion :razz: How do i find the REgistry ? i put it in the address bar on My Computer cant find .
reghakr
#18
You don't want to mess with the registry, it's om;y for advanced users.
reghakr
#20
Unzip the contents , then right-click and choose install.
