JobeMinacum
As stated. There is a problem with my GF's windows 7 DELL laptop. When you turn it on, the black screen with white text comes up, with start windows normally or repair windows. Both send you to the LOGIN screen, but there is no LOGIN box. It is just a background of the LOGIN page, you CAN move your mouse, but nothing else works. Is there anyway to system restore this, or fix it?
Also, I've tried most every F key to go to a different spot, but I can't seem to figure it out.
If i press f10, it says:
Edit Windows boot options for: Windows 7
Path: /windows/system32/winload.exe
Partition: 3
Hard Disk: a3f78fd4
[ /NOEXECUTE=OPTIN]
Would that be the virus causing the problem? Is there any way to fix it? Please, help!
Thanks
Partition: 3
Hard Disk: a3f78fd4
[ /NOEXECUTE=OPTIN]
Thanks
