Problem with MSE
Discussion in 'Windows 7 Software' started by Sonny, Jun 28, 2011.
  1. Sonny
    Sonny Fantastic Member
    Nov 17, 2009
    1,297
    106
    Every time I restart my computer, I am told I haven't scanned for awhile. The icon stays orange until I do a scan. The problem started this morning when I first turned computer on. Since then I had to restart my computer twice and the same thing happened. The first two times I did a scan only to be told on the next restart that I had not scanned for awhile. Anyone know why this has started happening? It also tells me that I am potentially unprotected.
    #1 Sonny, Jun 28, 2011
  2. Ciara
    Ciara New Member
    May 19, 2011
    2,352
    53
  3. Sonny
    Nov 17, 2009
    1,297
    106
    Hi Ciara,
    I did download from the Microsoft site. I will uninstall and re-install it and see what happens. I am sure I got the right version the first time. I am running Win7 64-bit. Thanks for answering. I will let you know how it turns out.
  4. Ciara
    Ciara New Member
    May 19, 2011
    2,352
    53
    I would say you have not ... but you don't have any other AV or malware apps running ?
  5. Sonny
    Nov 17, 2009
    1,297
    106
    I may have got the wrong version. No, MSE is the only anti-virus I have. I did have Norton Security 2011 but took it out with Norton un-installer tool. Just restarted and it seems to be working ok now.
  6. Ciara
    Ciara New Member
    May 19, 2011
    2,352
    53
    Oh well, I would just keep n eye on it Sonny :)
  7. Sonny
    Nov 17, 2009
    1,297
    106
    That I will do. I should know in a couple of weeks if it is going to be ok.:) That is about as long as I had it originally.
  8. Saltgrass
    Saltgrass Excellent Member
    Oct 16, 2009
    15,157
    393
    I have changed my settings for testing to Scan one day a week and not get definition updates prior to the scan. It also might matter if you are doing a full scan or quick scan.
    If your system is broken somehow, maybe just changing some of the settings will reset it.
  9. kaos
    kaos Senior Member
    May 9, 2011
    1,747
    33
    Ok try this
    Uninstall mse
    Reinstall it
    Reboot
    If it works great if not continue reading
    Update the program
    Run a full scan
    Continue if not working
    Go to admin tools in control panel
    Services policy
    Go down to I think windows family safety right click , properties , and on the start type make.sure its.ok automatic click ok
    Reboot
Share This Page
Loading...
