Problem with Photoshop CS4: Drawing with pen
Hey guys,
i hope someone can help me.
I have the problem that when i open photoshop and try to draw with a pen then there is always a short delay... i think its because the normal windows 7 tablet input helper still works when Im in photoshop... cause on every click on the drawing area there is this small circle, the same as when i just click on the desktop, and that shouldn't be there, it wasn't on windows vista.. and it isn't in paint.. or the microsoft journal .. and theres no delay while drawing..
Goregg,
Microsoft does have an official Windows 7 Support Forum located here Windows 7 Category . It is supported by product specialists as well as engineers and support teams. You may want to check the threads available there for additional assistance and feedback.
Jessica
Microsoft Windows Client Team
Me too!
Same problem. Photoshop wont read the strokes properly either. Im using a Wacom Intuos 4. Pen pressure works fine in other programs. I tried downloading updates for everything, Laptop, PS, tablet, still nothing. I even let PS use more RAM. I even swap my pen nib!! Someone please help I cant live without photoshop! (literally)
Fixed it!
It sounds like you had the exact problem I did. Heres how I fixed mine, it might work for you. From the control panel go into Hardware Devices> Pen and touch> Tablet pen settings> pen options tab. Under press and hold (double click it) uncheck the box at the top, apply and your done! It fixed mine perfectly, now it works properly. :D
