Windows 7 Problem with Supreme FX audio on ASUS P5N32-E SLI motherboard
Chris Tanner
Hi, first time posting, and this problem is a doozy.
I just got a desktop from my boss, with the following specs:
ASUS P5N32-E SLI mboard
6g ram
2.4 ghz intel quad core 2
nvidia gtx 260
I am unable to get the onboard sound (Supreme FX) to work with any drivers. I have tried Realtek, I have tried SoundMAX, and nothing seems to work. I have tried using both the 5.1 surround (Logitech X-530) and a pair of cheaper logitech speaers, and a pair of headphones, all with no success.
Please help! (And let me know if you need more info on my system/problems)
EDIT: My OS is Windows 7 Ultimate (64 bit)
if you go to start
type in the search box
dxdiag
select yes from the popup box ( if applicable)
click on sound and let us know what the information says :)
we will sort it im sure ;)
Unfortunately, I got your reply after leaving for work, but I'll be home around 6 pm EDT.
Also, I ran chkdsk and no problems there.
Sorry, i've been really busy.
Nmsuk: The installer says "The audio driver files do not support your computer hardware. If you uninstalled audio hardware without restarting your PC, restart now then run this setup again."
HOWEVER: After fiddling around with the settings in the Sound control panel, I stumbled upon this. Right-clicking on "Speakers" allowed me to choose "configure." Once there, I chose "5.1 surround" since that's what my Logitech system is. When I ran the test, all the speakers EXCEPT for left and right played sound!
This is progress, right?
Yes it is, we noe know the drivers are working. Can you check the physical connections to make sure the front speakers are plugged into the green socket.
Oh, and I ran Dxdiag, and this is what it said:
Sound Devices
Description: Speakers (SoundMAX Integrated Digital HD Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_198B&SUBSYS_104381F2&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ADIHdAud.sys
Driver Version: 6.10.0002.6110 (English)
Driver Attributes: Final Retail
WHQL Logo'd: Yes
Date and Size: 1/16/2007 11:36:20, 411648 bytes
Other Files:
Driver Provider: AnalogDevices
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: SPDIF Interface (SoundMAX Integrated Digital HD Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (SoundMAX Integrated Digital HD Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line In (SoundMAX Integrated Digital HD Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Yes, the front speakers are connected.
EDIT: DOH! No they weren't!
OK guys, fixed. I am a world-class idiot!
Thanks for all the help.
Glad you sorted it.:D
Could not get your link to work:
Installation Failed!
But did download the Vista driver from Asus and it did partially work. I have sound, but cannot get the microphone to work at all .....I used to have a Soundmax config app running in vista..but it does not appear in Win7.
Any help is greatly appreciated.
dxdiag info:
System Information
Time of this report: 12/22/2011, 19:05:30
       Machine name: BLACKLINE
   Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
           Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz (4 CPUs), ~2.4GHz
             Memory: 4096MB RAM
Available OS Memory: 4094MB RAM
          Page File: 1812MB used, 6375MB available
        Windows Dir: F:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
        Sound Tab 4: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce 8800 GT
       Manufacturer: NVIDIA
          Chip type: GeForce 8800 GT
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_C8013842&REV_A2
     Display Memory: 2286 MB
   Dedicated Memory: 495 MB
      Shared Memory: 1791 MB
       Current Mode: 1920 x 1200 (32 bit) (59Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: Acer X243W
         Monitor Id: ACR0000
        Native Mode: 1920 x 1200(p) (59.950Hz)
        Output Type: DVI
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.8562 (English)
     Driver Version: 8.17.12.8562
        DDI Version: 10
       Driver Model: WDDM 1.1
   Driver Date/Size: 10/15/2011 03:53:00, 15693120 bytes
        WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
  Device Identifier: {D7B71E3E-4551-11CF-807A-0DE81CC2C535}
          Vendor ID: 0x10DE
          Device ID: 0x0611
          SubSys ID: 0xC8013842
        Revision ID: 0x00A2
 Driver Strong Name: oem2.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section005:8.17.12.8562:pci\ven_10de&dev_0611
     Rank Of Driver: 00E62001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
       Current Mode: 1920 x 1080 (32 bit) (59Hz)
      Monitor Model: P244W
         Monitor Id: ACR005E
        Native Mode: 1920 x 1080(p) (59.988Hz)
        Output Type: DVI
        DDI Version: 10
        WHQL Logo'd: n/a
          Vendor ID: 0x10DE
          Device ID: 0x0611
        Revision ID: 0x00A2
            DXVA-HD: Supported
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_198B&SUBSYS_104381F2&REV_1004
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
          Date and Size: 12/22/2011 16:13:46, 411648 bytes
            Other Files:
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
              HW Memory: 0
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
            Description: Digital Output (Turtle Beach Montego DDL Wave)
            Hardware ID: PCI\VEN_13F6&DEV_0111&SUBSYS_011113F6&REV_10
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: cmudax3.sys
         Driver Version: 5.12.0001.0008 (English)
            WHQL Logo'd: n/a
          Date and Size: 5/22/2009 14:02:34, 1155072 bytes
            Other Files:
        Driver Provider: C-Media Electronics Inc.
              Cap Flags: 0x0
              HW Memory: 0
            Description: Speakers (Turtle Beach Montego DDL Wave)
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Stereo Mix (Turtle Beach Montego DDL Wave)
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Aux (Turtle Beach Montego DDL Wave)
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Line In (Turtle Beach Montego DDL Wave)
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: SPDIF In (Turtle Beach Montego DDL Wave)
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: CD Player (Turtle Beach Montego DDL Wave)
              Cap Flags: 0x0
           Format Flags: 0x0
              Cap Flags: 0x0
           Format Flags: 0x0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
+-+ USB Input Device
| | Vendor/Product ID: 0x046D, 0xC312
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| +-+ HID Keyboard Device
| | | Matching Device ID: hid_device_system_keyboard
| | | Service: kbdhid
Gameport Devices
PS/2 Devices
+ Razer Naga
| Vendor/Product ID: 0x1532, 0x0015
| Matching Device ID: hid\vid_1532&pid_0015&mi_01
| Upper Filters: RzSynapse
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Razer Naga
| Matching Device ID: hid\vid_1532&pid_0015&mi_00
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 44.0 GB
Total Space: 456.9 GB
File System: NTFS
      Model: Hitachi HDP725050GLA SCSI Disk Device
      Drive: E:
 Free Space: 0.1 GB
Total Space: 0.1 GB
File System: NTFS
      Model: Corsair Force GT SCSI Disk Device
      Drive: F:
 Free Space: 76.0 GB
Total Space: 114.4 GB
File System: NTFS
      Drive: W:
 Free Space: 5.6 GB
Total Space: 20.0 GB
File System: NTFS
      Drive: D:
      Model: HL-DT-ST DVD-RAM GSA-H55N ATA Device
     Driver: f:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&50
   Driver: n/a
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_0C5510DE&REV_A1\3&2411E6FE&2&18
   Driver: n/a
     Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_00000000&REV_A1\3&2411E6FE&2&0A
   Driver: n/a
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_03A1&SUBSYS_00000000&REV_A2\3&2411E6FE&2&00
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_81F21043&REV_A2\3&2411E6FE&2&79
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_00000000&REV_A1\3&2411E6FE&2&10
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_00000000&REV_A1\3&2411E6FE&2&09
   Driver: n/a
     Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&72
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&2&78
   Driver: n/a
     Name: Turtle Beach Montego DDL Wave
Device ID: PCI\VEN_13F6&DEV_0111&SUBSYS_011113F6&REV_10\4&746F448&0&3078
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_00000000&REV_A1\3&2411E6FE&2&06
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_00000000&REV_A1\3&2411E6FE&2&08
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&71
   Driver: n/a
     Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_CB841043&REV_A1\3&2411E6FE&2&68
   Driver: n/a
     Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&746F448&0&5878
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_00000000&REV_A1\3&2411E6FE&2&07
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_00000000&REV_A1\3&2411E6FE&2&01
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&70
   Driver: n/a
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_CB841043&REV_A2\3&2411E6FE&2&59
   Driver: n/a
     Name: NVIDIA GeForce 8800 GT
Device ID: PCI\VEN_10DE&DEV_0611&SUBSYS_C8013842&REV_A2\4&38CB09E4&0&00C0
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_00000000&REV_A1\3&2411E6FE&2&0E
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_00000000&REV_A1\3&2411E6FE&2&04
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_000010DE&REV_A3\3&2411E6FE&2&C0
   Driver: n/a
     Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_CB841043&REV_A1\3&2411E6FE&2&58
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0611&SUBSYS_C8013842&REV_A2\4&3319E72F&0&0018
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_00000000&REV_A1\3&2411E6FE&2&0D
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_00000000&REV_A1\3&2411E6FE&2&02
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0376&SUBSYS_000010DE&REV_A3\3&2411E6FE&2&98
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_CB841043&REV_A2\3&2411E6FE&2&48
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_00000000&REV_A1\3&2411E6FE&2&11
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_00000000&REV_A1\3&2411E6FE&2&0C
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_00000000&REV_A1\3&2411E6FE&2&03
   Driver: n/a
     Name: NVIDIA nForce Networking Controller #2
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&90
   Driver: n/a
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&51
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_00000000&REV_A1\3&2411E6FE&2&12
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_00000000&REV_A1\3&2411E6FE&2&0B
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_00000000&REV_A2\3&2411E6FE&2&05
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_CB841043&REV_A3\3&2411E6FE&2&88
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17514
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17514
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17514
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17514
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
Audio Capture Sources:
Microphone (SoundMAX Integrated,0x00200000,0,0,qcap.dll,6.06.7601.17514
Aux (Turtle Beach Montego DDL W,0x00200000,0,0,qcap.dll,6.06.7601.17514
CD Player (Turtle Beach Montego,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line In (SoundMAX Integrated Di,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line In (Turtle Beach Montego D,0x00200000,0,0,qcap.dll,6.06.7601.17514
SPDIF In (Turtle Beach Montego ,0x00200000,0,0,qcap.dll,6.06.7601.17514
Stereo Mix (Turtle Beach Monteg,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
MPU-401,0x00200000,1,0,quartz.dll,6.06.7601.17514
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SoundMAX HD Audio I,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
Turtle Beach Montego DDL Wave,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
Turtle Beach Montego DDL Digital ,0x00200000,3,3,ksproxy.ax,6.01.7601.17514
MPU-401,0x00200000,3,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HD Audio digital out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
SoundMAX HD Audio O,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (SoundMAX Integrated D,0x00200000,1,0,quartz.dll,6.06.7601.17514
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514
Digital Output (Turtle Beach Mo,0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Digital Output (Turtle Beach Montego DDL Wave),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: SPDIF Interface (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (SoundMAX Integrated Digital HD Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (Turtle Beach Montego DDL Wave),0x00200000,1,0,quartz.dll,6.06.7601.17514
SPDIF Interface (SoundMAX Integ,0x00200000,1,0,quartz.dll,6.06.7601.17514
Speakers (Turtle Beach Montego ,0x00200000,1,0,quartz.dll,6.06.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Top Bottom
