Problems connecting to SSL-VPN
I am having a problem when trying to connect to SSL-VPN on a FortiGate 60B. I have 3 customers where I can connect using https on IE or Firefox, with both XP and Vista. But when I try with Windows 7, it does connect to the firewall, the first time add the add-in as it should, it then shows the home page presented by the firewall, with the Connect button as it should, but nothing happen when I click on the Connect.
According to Fortinet, they are supporting W7. I also posted this on Fortinet forum.
Thannks,
RD
