Hi there, Today I wanted to create a system backup. I have 2 external hard drives, they are pulgged in. I selected one of them erased any files in there and also formated it.
Then I started backup manager, didnt choose an image backup because the systme tells me that that particular drive is not appropiate to do so.
I selected the automatic file selection and started, but a few seconds later the process stopped and showed error message (backup can not be completed). I checekd the disk for erros but it is empty. I ran Iobit disk chek utility and also used the advanced system care program to check entire system.
I tried gain and same, it says error.
Then a tried to do the backup selecting my other hard drive and also the same.
I restarted m,y system, checked it for errors and bla bla and nothing, simply cannot create a backup in any hard drive.
Can anybody help me??
Thanks in advance.
Thanks in advance.
