So I cloned my old 250gb hd into my new hdd. It is my new boot disk and etc. I started up the computer and everything seems to be working fine. However, I am running into a problem when I try to use windows 7 back up utility:
I get an error message that says
"Windows backup failed while determining libraries location of one of the users included in backup. details: bitlocker drive encryption cannot be used because critical bitlocker system files are missing or corrupted. Use windows startup repair to restore these files to your computer."
If I manually select each of the library folders, it works ok. If I just click on "my libraries," the problem appears
So I created a repair disk, ran the startup repair, it found a problem and repaired it. I ran it again and it found no more problems. However, the back up problem remains. I cannot run back up because this message comes up. How can I fix it? Anyone else experienced this? I never actively used bitlocker, so unless it sets itself up I dont know how this has come up.
EDIT:
Fixed it. Cloning somehow messed up the index and the libraries. I restored library folders to default, then rechose the folders again, and reindexed the drive. That fixed it.
EDIT:
