Neomic
- Joined
- May 23, 2009
- Messages
- 6
- Thread Author
- #1
I downloaded the build-7000 when it came out, and I couldn't get Win7 to go any higher than a resolution of 640x480 with a color depth of 8-bits. I think it might've been a driver problem, since my motherboard is a little out-dated (2002).
I was wondering if I were to download the newest build (7127, x86), with all the updates they've had since build-7000, would I be able to use Win7 with a normal resolution (768 or higher)?
Processor a
2.40 gigahertz Intel Celeron
8 kilobyte primary memory cache
128 kilobyte secondary memory cache
System Model
Gateway ESSEX2 4000811
System Serial Number: 0031817457
Chassis Serial Number: 0031817457
Enclosure Type: Desktop
Main Circuit Board b
Board: Intel Corporation D845GERG3 AAC29595-101
Serial Number: ABRG32821088
Bus Clock: 100 megahertz
BIOS: Intel Corp. RG84510A.15A.0037.P15.0304012013 04/01/2003
Display
Intel(R) 82845G/GL/GE/PE/GV Graphics Controller [Display adapter]
Memory Modules c,d
1534 Megabytes Installed Memory
Slot 'J6G1' has 1024 MB
Slot 'J6G2' has 512 MB
Any information would be helpful. I'm very eager to make the upgrade, but I can't exactly afford a new computer at the moment.
Processor a
System Model
Display
Memory Modules c,d
