Windows 7 Process Page Lock BSOD
Speedingturtle
Attached my recent Minidump folder going back a month to when the crashes started happening. I have just about no idea what is causing them in all honesty. Leading up to the crashes it seemed like the computer was just slowing down more and more as time went by. I used to be able to run Livestream Procaster and photoshop at the same time while staying at about 80% CPU usage, and now even running just the Procaster brings it to 85%. This is something that could be related, but really I have no idea.
If I'm missing any information here that could help I'll try to provide it.
Lenovo
Windows 7, 64 bit
4 gigs of RAM
Intel Duel Core E5700 @ 3.00 Hz
  • Mini Dump Folder.zip
Hi Speedingturtle and Welcome to The Forum.
STOP 0x00000076: PROCESS_HAS_LOCKED_PAGE
Usual causes:
Device driver.
Congratulations!! I've not seen a Stop 76 before!
Your latest dump file lists ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
Drivers that pre-date Windows 7. Update:
Rt64win7.sys Fri May 22 15:52:30 2009 Realtek PCIe GBE Family Controller v7.049 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
scmndisp.sys Wed Jan 17 07:48:03 2007 Link Removed - Invalid URL
spio.sys Mon Mar 10 07:11:55 2008 I think this is a fan speed control driver from Lenovo
wacommousefilter.sys Fri Feb 16 18:12:17 2007 Link Removed due to 404 Error People with a Wacom tablet who don't use the mouse with it have reported no problems if they simply disable this driver.
Drivers with Updates:
RTKVHD64.sys Wed Aug 05 10:46:28 2009 Realtek HD Audio R2.67
nvlddmkm.sys Sat May 21 05:07:04 2011 nVidia Graphics Drivers.
  • Download and install DriverSweeper.
  • Uninstall your current Graphics setup through Programs and Features
  • Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
  • Reboot to Normal Mode.
  • Install your new Graphics set up.
Bugcheck Analysis:
BugCheck 76, {0, fffffa80084de060, 3, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+18026 )
Followup: MachineOwner
0: kd> !analyze -v
PROCESS_HAS_LOCKED_PAGES (76)
Caused by a driver not cleaning up correctly after an I/O.
Arguments:
Arg1: 0000000000000000, Locked memory pages found in process being terminated.
Arg2: fffffa80084de060, Process address.
Arg3: 0000000000000003, Number of locked pages.
Arg4: 0000000000000000, Pointer to driver stacks (if enabled) or 0 if not.
    Issue a !search over all of physical memory for the current process pointer.
    This will yield at least one MDL which points to it.  Then do another !search
    for each MDL found, this will yield the IRP(s) that point to it, revealing
    which driver is leaking the pages.
    Otherwise, set HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory
    Management\TrackLockedPages to a DWORD 1 value and reboot.  Then the system
    will save stack traces so the guilty driver can be easily identified.
    When you enable this flag, if the driver commits the error again you will
    see a different bugcheck - DRIVER_LEFT_LOCKED_PAGES_IN_PROCESS (0xCB) -
    which can identify the offending driver(s).
Debugging Details:
PROCESS_NAME:  audiodg.exe
DEFAULT_BUCKET_ID:  DRIVER_FAULT_0x76
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x76
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80003734069 to fffff800034d7c40
STACK_TEXT:
fffff880`0394a9f8 fffff800`03734069 : 00000000`00000076 00000000`00000000 fffffa80`084de060 00000000`00000003 : nt!KeBugCheckEx
fffff880`0394aa00 fffff800`0378e987 : fffffa80`084de060 fffffa80`03c6ff30 fffffa80`00000000 fffffa80`00000000 : nt! ?? ::NNGAKEGL::`string'+0x18026
fffff880`0394aa40 fffff800`034e1af4 : 00000000`00000000 fffffa80`084de060 fffffa80`084de030 fffff800`03863db5 : nt!PspProcessDelete+0x177
fffff880`0394aaa0 fffff800`035d87d9 : fffffa80`084de060 fffffa80`08b4a000 fffffa80`08b4aeb0 fffffa80`08b4aea8 : nt!ObfDereferenceObject+0xd4
fffff880`0394ab00 fffff800`0392858e : fffffa80`00000562 fffffa80`04d9e000 fffffa80`084de060 fffffa80`08b4aeb0 : nt!MmFreeAccessPfnBuffer+0x29
fffff880`0394ab30 fffff800`03949c70 : fffffa80`05b77b01 00000000`00000080 fffffa80`03cde040 fffff800`0365fda8 : nt!PfpFlushBuffers+0x23e
fffff880`0394abd0 fffff800`03772fee : ffffffff`ff676980 fffffa80`05b77b60 fffffa80`05ae3b60 fffff800`034cf757 : nt!PfTLoggingWorker+0xe0
fffff880`0394ad00 fffff800`034c95e6 : fffff880`009e7180 fffffa80`05b77b60 fffff880`009f1f40 fffff880`01251a20 : nt!PspSystemThreadStartup+0x5a
fffff880`0394ad40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`03734069 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::NNGAKEGL::`string'+18026
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aaa3
FAILURE_BUCKET_ID:  X64_0x76_audiodg.exe_nt!_??_::NNGAKEGL::_string_+18026
Drivers:
fffff880`00f25000 fffff880`00f7c000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01000000 fffff880`01089000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0fdba000 fffff880`0fdd0000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00dec000 fffff880`00df7000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`046c9000 fffff880`046d2000   aswFsBlk aswFsBlk.SYS Mon Nov 28 17:51:52 2011 (4ED3CA38)
fffff880`0468d000 fffff880`046c9000   aswMonFlt aswMonFlt.sys Mon Nov 28 17:52:10 2011 (4ED3CA4A)
fffff880`02dd1000 fffff880`02dde000   aswRdr   aswRdr.SYS   Mon Nov 28 17:52:20 2011 (4ED3CA54)
fffff880`02c3f000 fffff880`02cd5000   aswSnx   aswSnx.SYS   Mon Nov 28 17:54:05 2011 (4ED3CABD)
fffff880`03f18000 fffff880`03f69000   aswSP    aswSP.SYS    Mon Nov 28 17:53:57 2011 (4ED3CAB5)
fffff880`02dbf000 fffff880`02dd1000   aswTdi   aswTdi.SYS   Mon Nov 28 17:52:18 2011 (4ED3CA52)
fffff880`00e5c000 fffff880`00e65000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00db2000 fffff880`00ddc000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff960`00860000 fffff960`008c1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`02d0f000 fffff880`02d16000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03f07000 fffff880`03f18000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0577c000 fffff880`0579a000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`007b0000 fffff960`007d7000   cdd      cdd.dll      unavailable (00000000)
fffff880`043df000 fffff880`043fc000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`015bd000 fffff880`015e7000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01650000 fffff880`01680000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d3a000 fffff880`00d98000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01147000 fffff880`011b9000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`0fd88000 fffff880`0fd98000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0568e000 fffff880`0569c000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03ee9000 fffff880`03f07000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03eda000 fffff880`03ee9000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0163a000 fffff880`01650000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0433a000 fffff880`0435c000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0569c000 fffff880`056a8000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`04751000 fffff880`04764000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`056a8000 fffff880`056b3000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`051f1000 fffff880`051fd000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`03a8f000 fffff880`03b83000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`03b83000 fffff880`03bc9000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`010d5000 fffff880`010e9000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01089000 fffff880`010d5000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0122c000 fffff880`01236000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01600000 fffff880`0163a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`018df000 fffff880`01929000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`03a82000 fffff880`03a8f000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`03412000 fffff800`0345b000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0f06b000 fffff880`0f076000   hamachi  hamachi.sys  Thu Feb 19 10:36:41 2009 (499D3639)
fffff880`03bc9000 fffff880`03bed000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0fd98000 fffff880`0fdb1000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0fdb1000 fffff880`0fdb9080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`043b6000 fffff880`043c4000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`056b3000 fffff880`0577c000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`019dd000 fffff880`019e6000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`0fd6a000 fffff880`0fd88000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03f8f000 fffff880`03fa5000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`03a73000 fffff880`03a82000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bb8000 fffff800`00bc2000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`03e00000 fffff880`03e43000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01200000 fffff880`0121b000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01592000 fffff880`015bd000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0435c000 fffff880`04361200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`0564e000 fffff880`05663000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04200000 fffff880`04223000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`06dd1000 fffff880`06ddb000   mbam     mbam.sys     Wed Nov 02 13:07:48 2011 (4EB140A4)
fffff880`00cd7000 fffff880`00d26000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`05000000 fffff880`0500e000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03fbf000 fffff880`03fce000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`042b0000 fffff880`042bd000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00d98000 fffff880`00db2000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`02cd5000 fffff880`02d06000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`06c71000 fffff880`06c81000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`0579a000 fffff880`057b2000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`057b2000 fffff880`057df000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`04764000 fffff880`047b2000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`047b2000 fffff880`047d6000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00e65000 fffff880`00e70000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`02d74000 fffff880`02d7f000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f85000 fffff880`00f8f000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`010e9000 fffff880`01147000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`03ecf000 fffff880`03eda000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`019cb000 fffff880`019dd000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0143f000 fffff880`01532000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0fdf4000 fffff880`0fe00000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`05663000 fffff880`05676000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`0f000000 fffff880`0f02f000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`042c5000 fffff880`042da000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`02de7000 fffff880`02df6000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`011b9000 fffff880`011fe000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01532000 fffff880`01592000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`06db9000 fffff880`06dd1000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`02d7f000 fffff880`02d90000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03ec3000 fffff880`03ecf000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`0345b000 fffff800`03a44000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01243000 fffff880`013e6000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`02d06000 fffff880`02d0f000   Null     Null.SYS     unavailable (00000000)
fffff880`0fd2c000 fffff880`0fd31000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`042da000 fffff880`042fd000   nvhda64v nvhda64v.sys Mon Jun 21 23:07:25 2010 (4C1FE29D)
fffff880`0f07e000 fffff880`0fd2c000   nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`046fe000 fffff880`04751000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02c00000 fffff880`02c26000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00fcf000 fffff880`00fe4000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f8f000 fffff880`00fc2000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00ddc000 fffff880`00dec000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0121b000 fffff880`0122c000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0624e000 fffff880`062f4000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`042fd000 fffff880`0433a000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d26000 fffff880`00d3a000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`0fdd0000 fffff880`0fdf4000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0f02f000 fffff880`0f04a000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0f04a000 fffff880`0f06b000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`03fa5000 fffff880`03fbf000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03e72000 fffff880`03ec3000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`02d59000 fffff880`02d62000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d62000 fffff880`02d6b000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d6b000 fffff880`02d74000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`04600000 fffff880`04639000   RDPWD    RDPWD.SYS    Sat Nov 20 11:04:37 2010 (4CE7AB45)
fffff880`01991000 fffff880`019cb000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05676000 fffff880`0568e000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0fd31000 fffff880`0fd6a000   Rt64win7 Rt64win7.sys Fri May 22 15:52:30 2009 (4A16BC2E)
fffff880`05010000 fffff880`051f0880   RTKVHD64 RTKVHD64.sys Wed Aug 05 10:46:28 2009 (4A7954F4)
fffff880`05613000 fffff880`0564e000   RtsUStor RtsUStor.sys Fri Jun 26 03:34:22 2009 (4A4433AE)
fffff880`01929000 fffff880`01933000   scmndisp scmndisp.sys Wed Jan 17 07:48:03 2007 (45ADD4B3)
fffff880`062f4000 fffff880`062ff000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`03a67000 fffff880`03a73000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`016b8000 fffff880`016d5000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`062ff000 fffff880`063c0000   Sftfslh  Sftfslh.sys  Mon Sep 13 23:03:14 2010 (4C8E9FA2)
fffff880`06200000 fffff880`0624d000   Sftplaylh Sftplaylh.sys Mon Sep 13 23:03:15 2010 (4C8E9FA3)
fffff880`06dae000 fffff880`06db9000   Sftredirlh Sftredirlh.sys Mon Sep 13 23:03:26 2010 (4C8E9FAE)
fffff880`046d2000 fffff880`046dd000   Sftvollh Sftvollh.sys Mon Sep 13 23:02:56 2010 (4C8E9F90)
fffff880`01987000 fffff880`01991000   speedfan speedfan.sys Fri Mar 18 16:08:46 2011 (4D83838E)
fffff880`0f076000 fffff880`0f077700   spio     spio.sys     Mon Mar 10 07:11:55 2008 (47D4DF3B)
fffff880`0197f000 fffff880`01987000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`06d16000 fffff880`06dae000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06cad000 fffff880`06d16000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`063c0000 fffff880`063f1000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04362000 fffff880`0437e000   stdriver64 stdriver64.sys Fri Mar 18 00:17:45 2011 (4D82A4A9)
fffff880`03bfd000 fffff880`03bfe480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`016db000 fffff880`018df000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`057df000 fffff880`057f1000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`02db2000 fffff880`02dbf000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`063f1000 fffff880`063fc000   tdtcp    tdtcp.sys    Tue Jul 14 01:16:32 2009 (4A5BCE60)
fffff880`02d90000 fffff880`02db2000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`019e6000 fffff880`019fa000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00550000 fffff960`0055a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`057f1000 fffff880`05800000   tssecsrv tssecsrv.sys Sat Nov 20 11:04:09 2010 (4CE7AB29)
fffff880`03f69000 fffff880`03f8f000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`03e43000 fffff880`03e55000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0439b000 fffff880`043b5c80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`0437e000 fffff880`0439b000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0500e000 fffff880`0500ff00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`03a56000 fffff880`03a67000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04256000 fffff880`042b0000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`03a00000 fffff880`03a56000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`043c4000 fffff880`043df000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`03bed000 fffff880`03bfa000   usbuhci  usbuhci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`00fc2000 fffff880`00fcf000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`02d16000 fffff880`02d24000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`02d24000 fffff880`02d49000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fe4000 fffff880`00ff9000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01933000 fffff880`0197f000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`02c26000 fffff880`02c3c000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`042bd000 fffff880`042c5000   wacommousefilter wacommousefilter.sys Fri Feb 16 18:12:17 2007 (45D5F401)
fffff880`03bfa000 fffff880`03bfca00   wacomvhid wacomvhid.sys Tue Sep 22 00:29:14 2009 (4AB80C4A)
fffff880`01400000 fffff880`0141b000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`02d49000 fffff880`02d59000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e72000 fffff880`00f16000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f16000 fffff880`00f25000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02dde000 fffff880`02de7000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00050000 fffff960`00364000   win32k   win32k.sys   unavailable (00000000)
fffff880`00f7c000 fffff880`00f85000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`046dd000 fffff880`046fe000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`06c81000 fffff880`06c93100   xusb21   xusb21.sys   Thu Aug 13 23:10:17 2009 (4A848F49)
Unloaded modules:
fffff880`06c00000 fffff880`06c71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`05600000 fffff880`05613000   xusb21.sys
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06ddb000 fffff880`06dec000   usbaapl64.sy
    Checksum:  00000000
    ImageSize:  00011000
fffff880`06c00000 fffff880`06c31000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`06dec000 fffff880`06dfd000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`06c5b000 fffff880`06c67000   hiber_pciide
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06c81000 fffff880`06c8c000   hiber_msahci
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`06c8c000 fffff880`06c9f000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06c31000 fffff880`06c3d000   hiber_pciide
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06c3d000 fffff880`06c48000   hiber_msahci
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`06c48000 fffff880`06c5b000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06c81000 fffff880`06c8d000   hiber_pciide
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06c8d000 fffff880`06c98000   hiber_msahci
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`06c98000 fffff880`06cab000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`057ea000 fffff880`057f7000   vwifibus.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`056b5000 fffff880`057ea000   bcmwlhigh664
    Checksum:  00000000
    ImageSize:  00135000
fffff880`01680000 fffff880`0168e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0168e000 fffff880`0169a000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0169a000 fffff880`016a5000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`016a5000 fffff880`016b8000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
If after that lot you still get a Stop 76, then there's a registry key we can utilise that should show us the real culprit.
Download 0x76 TrackLockedPages. Unzip and use the TrackLockedPages-Add.reg file. When you get another BSOD this should make it point directly at the culprit. If possible do it a couple of times, adding the .reg file every time.
When finished use the TrackLockedPages-Remove.reg file to clear.
In the meantime keep us up to date with all your dump files.
HTH.
