Public Folders
I deleted all my Public Folders. They were empty. I want them back. What can I do? Plese help save me from my stupidaty!! Thanks!
Saltgrass
Opening an administrative command window and typing and enter after:
SFC /scannow
might help.
_________________
Well, that doesn't work...Are they still in the recycle bin?
If you don't find a way, you can put them back one at a time...
Favorites
Libraries
Public Desktop
Public Documents
Public Downloads
Public Music
Public Pictures
Public Recorded TV
Public Videos
I ran that scan and it said I had no "integrity" problems. Thanks!
I tried a system restore twice and it kept saying it could not complete because of a file problem. It suggested truning off virus protection and i did and still would not complete.
If I just put the folders back one by one is it just a matter of creating a new folder or do I need to connect it somehow to something? Thanks!
Saltgrass
I am not sure about how they would interact with the system, so maybe someone else would know a better way.
I was looking and after you create the public folder, right click on it and select restore previous versions. I am not sure what this will do exactly, and do not know if it will effect any other folders. But maybe something to try until someone else comes along.
I tried this and it works, IF you have something to restore from.
Thank you very much!
