- Thread Author
- #1
Hi guys,
I was wondering bout something: at the moment I have Windows 7 32-Bit installed on 3 of my PC's at home. 2 of them support 64-Bit and I anyways wanted to use 64-Bit when Windows 7 RTM comes out. Now I wanted to get the 64-Bit version of the RC and wanted to ask if it's possible to do an upgrade from Windows 7 RC 32-Bit to 64-Bit or if I have to do a clean install.
Hope for answers!
Regards,
UBF
Hope for answers!
Regards,
UBF
Super Sarge
- Joined
- Jun 4, 2009
- Messages
- 1,734
- Thread Author
- #3
Super Sarge
- Joined
- Jun 4, 2009
- Messages
- 1,734
On that I am not sure, I personally did a clean install as I prefer those, I am running it on a separate HD so I can boot between Visa and W-7, I would recommend a clean install format the disc and or partition you are going to install it on. Clean installs give you less chance of file corruption than an upgrade does. When W-7 comes out in October you will have to a clean install anyway or could upgrade your Vista. You will not be able to upgrade W7 RC-1
Radenight
- Joined
- Nov 16, 2008
- Messages
- 4,504
Super Sarge
- Joined
- Jun 4, 2009
- Messages
- 1,734
Similar threads
- Replies
- 2
- Views
- 6K
- Replies
- 2
- Views
- 1K
- Solved
- Replies
- 4
- Views
- 949
- Replies
- 2
- Views
- 1K
