I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if...
* Bugcheck Analysis *
BugCheck 109, {a3a039d89b837503, b3b7465eee004459, fffff80003000110, 1}
Probably caused by : memory_corruption
Followup: memory_corruption
2: kd> !analyze -v
CRITICAL_STRUCTURE_CORRUPTION (109)
This bugcheck is generated when the kernel detects that critical kernel code or
data have been corrupted. There are generally three causes for a corruption:
1) A driver has inadvertently or deliberately modified critical kernel code
or data. See http://www.microsoft.com/whdc/driver/kernel/64bitPatching.mspx
2) A developer attempted to set a normal kernel breakpoint using a kernel
debugger that was not attached when the system was booted. Normal breakpoints,
"bp", can only be set if the debugger is attached at boot time. Hardware
breakpoints, "ba", can be set at any time.
3) A hardware corruption occurred, e.g. failing RAM holding kernel code or data.
Arguments:
Arg1: a3a039d89b837503, Reserved
Arg2: b3b7465eee004459, Reserved
Arg3: fffff80003000110, Failure type dependent information
Arg4: 0000000000000001, Type of corrupted region, can be
0 : A generic data region
1 : Modification of a function or .pdata
2 : A processor IDT
3 : A processor GDT
4 : Type 1 process list corruption
5 : Type 2 process list corruption
6 : Debug routine modification
7 : Critical MSR modification
Debugging Details:
BUGCHECK_STR: 0x109
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
PROCESS_NAME: System
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff80002cdfd00
STACK_TEXT:
fffff880`033a8498 00000000`00000000 : 00000000`00000109 a3a039d8`9b837503 b3b7465e`ee004459 fffff800`03000110 : nt!KeBugCheckEx
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
fffff80003000129 - nt! ?? ::NNGAKEGL::`string'+1ef19
[ f8:d8 ]
1 error : !nt (fffff80003000129)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: ONE_BIT
FAILURE_BUCKET_ID: X64_MEMORY_CORRUPTION_ONE_BIT
fffff880`07400000 fffff880`0743e000 1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`00e0f000 fffff880`00e66000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`01400000 fffff880`01489000 afd afd.sys Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`07fd3000 fffff880`07fe9000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01150000 fffff880`0115b000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`098cc000 fffff880`098ee000 asmthub3 asmthub3.sys Wed Dec 08 10:14:14 2010 (4CFF5A76)
fffff880`07580000 fffff880`075de000 asmtxhci asmtxhci.sys Wed Dec 08 10:14:06 2010 (4CFF5A6E)
fffff880`0afa4000 fffff880`0afaf000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`0107e000 fffff880`01087000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01087000 fffff880`010b1000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`08bab000 fffff880`08bcc000 AtihdW76 AtihdW76.sys Thu Mar 31 08:15:43 2011 (4D942A1F)
fffff880`0762f000 fffff880`07f6e000 atikmdag atikmdag.sys Wed May 25 03:40:32 2011 (4DDC6C20)
fffff880`0752f000 fffff880`07580000 atikmpag atikmpag.sys Wed May 25 03:25:42 2011 (4DDC68A6)
fffff880`0187e000 fffff880`01885000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`074f8000 fffff880`07509000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`08123000 fffff880`08141000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`0ae32000 fffff880`0ae99000 btath_a2dp btath_a2dp.sys Tue Feb 15 01:47:47 2011 (4D59DB43)
fffff880`08af1000 fffff880`08afc000 btath_bus btath_bus.sys Thu Jun 24 07:17:43 2010 (4C22F887)
fffff880`0af11000 fffff880`0af20000 btath_flt btath_flt.sys Thu Jun 24 07:17:38 2010 (4C22F882)
fffff880`0ae99000 fffff880`0aefc000 btath_hcrp btath_hcrp.sys Tue Jun 29 10:30:43 2010 (4C29BD43)
fffff880`0af20000 fffff880`0af33000 btath_lwflt btath_lwflt.sys Mon Sep 13 09:26:54 2010 (4C8DE04E)
fffff880`09a99000 fffff880`09abde00 btath_rcp btath_rcp.sys Thu Jun 24 07:17:21 2010 (4C22F871)
fffff880`09c00000 fffff880`09c48000 btfilter btfilter.sys Tue Mar 08 06:15:22 2011 (4D75C97A)
fffff880`09a69000 fffff880`09a79000 BthEnum BthEnum.sys Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`09a79000 fffff880`09a99000 bthpan bthpan.sys Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`09c60000 fffff880`09cec000 bthport bthport.sys Thu Apr 28 04:58:42 2011 (4DB8E5F2)
fffff880`09c48000 fffff880`09c60000 BTHUSB BTHUSB.sys Thu Apr 28 04:58:34 2011 (4DB8E5EA)
fffff960`00610000 fffff960`00637000 cdd cdd.dll unavailable (00000000)
fffff880`098af000 fffff880`098cc000 cdfs cdfs.sys Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`0162b000 fffff880`01655000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00e97000 fffff880`00f57000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01bcc000 fffff880`01bfc000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cfd000 fffff880`00d5b000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`084aa000 fffff880`087d5000 cmudaxp cmudaxp.sys Thu Mar 10 07:44:15 2011 (4D78814F)
fffff880`014ba000 fffff880`0152c000 cng cng.sys Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`08295000 fffff880`082a5000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`08010000 fffff880`08019000 cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`0991c000 fffff880`0992a000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`09835000 fffff880`09838180 dadder dadder.sys Thu Aug 02 10:33:03 2007 (46B1A4CF)
fffff880`074da000 fffff880`074f8000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`074cb000 fffff880`074da000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01bb6000 fffff880`01bcc000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0843d000 fffff880`0845f000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`01838000 fffff880`0187e000 dtsoftbus01 dtsoftbus01.sys Mon Mar 14 13:15:36 2011 (4D7E14F8)
fffff880`0992a000 fffff880`09936000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`09941000 fffff880`09954000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`09936000 fffff880`09941000 dump_msahci dump_msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`098a3000 fffff880`098af000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`082c2000 fffff880`083b6000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`083b6000 fffff880`083fc000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`08235000 fffff880`08284000 e1c62x64 e1c62x64.sys Tue Sep 21 22:34:15 2010 (4C9924D7)
fffff880`08019000 fffff880`0804f000 fastfat fastfat.SYS Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`011a7000 fffff880`011bb000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0115b000 fffff880`011a7000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0153d000 fffff880`01547000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01b7c000 fffff880`01bb6000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a89000 fffff880`01ad3000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`02c17000 fffff800`02c60000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`08200000 fffff880`08224000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`09847000 fffff880`098a3000 HdAudio HdAudio.sys Tue Jul 14 01:06:59 2009 (4A5BCC23)
fffff880`08224000 fffff880`08235000 HECIx64 HECIx64.sys Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`0980e000 fffff880`09827000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`082ac000 fffff880`082b4080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`09800000 fffff880`0980e000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`0805a000 fffff880`08123000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01b73000 fffff880`01b7c000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`087d5000 fffff880`087eb000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00c6c000 fffff880`00c8d000 jraid jraid.sys Tue Aug 10 10:28:44 2010 (4C611BCC)
fffff880`08ad1000 fffff880`08ae0000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`09827000 fffff880`09835000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bae000 fffff800`00bb8000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`0845f000 fffff880`084a2000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013a8000 fffff880`013c3000 ksecdd ksecdd.sys Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01600000 fffff880`0162b000 ksecpkg ksecpkg.sys Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`084a2000 fffff880`084a7200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`099ad000 fffff880`099c2000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`098ee000 fffff880`09911000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c9a000 fffff880`00ce9000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`09982000 fffff880`09990000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`08ae0000 fffff880`08aef000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`09839000 fffff880`09846000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`01064000 fffff880`0107e000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`01547000 fffff880`01578000 MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`08000000 fffff880`08010000 MpNWMon MpNWMon.sys Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`08141000 fffff880`08159000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`08159000 fffff880`08186000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`08186000 fffff880`081d4000 mrxsmb10 mrxsmb10.sys Wed Apr 27 03:39:40 2011 (4DB781EC)
fffff880`081d4000 fffff880`081f8000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`010b1000 fffff880`010bc000 msahci msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01593000 fffff880`0159e000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e6f000 fffff880`00e79000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`074c0000 fffff880`074cb000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01b61000 fffff880`01b73000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`010bc000 fffff880`01148000 mv91xx mv91xx.sys Fri Aug 27 10:49:22 2010 (4C778A22)
fffff880`01148000 fffff880`01150000 mvxxmm mvxxmm.sys Fri Aug 27 10:49:03 2010 (4C778A0F)
fffff880`01683000 fffff880`01776000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`082b5000 fffff880`082c1000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`08a4c000 fffff880`08a7b000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`08b96000 fffff880`08bab000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`015de000 fffff880`015ed000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`011bb000 fffff880`01200000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01776000 fffff880`017d6000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`09d84000 fffff880`09d9c000 NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`0159e000 fffff880`015af000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`074b4000 fffff880`074c0000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c60000 fffff800`03249000 nt ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`01205000 fffff880`013a8000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01655000 fffff880`0165e000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`01492000 fffff880`014b8000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00d8e000 fffff880`00da3000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d5b000 fffff880`00d8e000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00e86000 fffff880`00e8d000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0152c000 fffff880`0153d000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`09af9000 fffff880`09b9f000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`08400000 fffff880`0843d000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00ce9000 fffff880`00cfd000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`07600000 fffff880`07624000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`08a7b000 fffff880`08a96000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`08a96000 fffff880`08ab7000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`08ab7000 fffff880`08ad1000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`07463000 fffff880`074b4000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01578000 fffff880`01581000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01581000 fffff880`0158a000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0158a000 fffff880`01593000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01b27000 fffff880`01b61000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`09dcd000 fffff880`09df9000 rfcomm rfcomm.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`099df000 fffff880`099f7000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`00db8000 fffff880`00de7000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`09b9f000 fffff880`09baa000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01b1f000 fffff880`01b27000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`09cec000 fffff880`09d84000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`09a00000 fffff880`09a69000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`09baa000 fffff880`09bdb000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`08aef000 fffff880`08af0480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01885000 fffff880`01a89000 tcpip tcpip.sys Mon Apr 25 03:37:30 2011 (4DB4DE6A)
fffff880`09bdb000 fffff880`09bed000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`015d1000 fffff880`015de000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`015af000 fffff880`015d1000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`013de000 fffff880`013f2000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`004e0000 fffff960`004ea000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`07509000 fffff880`0752f000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`08afc000 fffff880`08b0e000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`099c2000 fffff880`099df000 usbccgp usbccgp.sys Fri Mar 25 03:23:03 2011 (4D8C0A97)
fffff880`099ab000 fffff880`099acf00 USBD USBD.SYS Fri Mar 25 03:22:51 2011 (4D8C0A8B)
fffff880`08284000 fffff880`08295000 usbehci usbehci.sys Fri Mar 25 03:22:57 2011 (4D8C0A91)
fffff880`08b0e000 fffff880`08b68000 usbhub usbhub.sys Fri Mar 25 03:23:22 2011 (4D8C0AAA)
fffff880`07f6e000 fffff880`07fc4000 USBPORT USBPORT.SYS Fri Mar 25 03:23:03 2011 (4D8C0A97)
fffff880`09990000 fffff880`099ab000 USBSTOR USBSTOR.SYS Fri Mar 11 04:31:17 2011 (4D79A595)
fffff880`00e79000 fffff880`00e86000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0165e000 fffff880`0166c000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`017d6000 fffff880`017fb000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00da3000 fffff880`00db8000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01ad3000 fffff880`01b1f000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`07fc4000 fffff880`07fd2a00 vrtaucbl vrtaucbl.sys Mon Feb 15 17:07:10 2010 (4B797F3E)
fffff880`013c3000 fffff880`013de000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`0166c000 fffff880`0167c000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00f57000 fffff880`00ffb000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00e00000 fffff880`00e0f000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`01489000 fffff880`01492000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d3000 win32k win32k.sys unavailable (00000000)
fffff880`087ec000 fffff880`087f5000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00e66000 fffff880`00e6f000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`09954000 fffff880`09975000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`09d9c000 fffff880`09dcd000 WUDFRd WUDFRd.sys Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`0af33000 fffff880`0afa4000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`0aefc000 fffff880`0af11000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`099ad000 fffff880`099be000 AthDfu.sys
Checksum: 00000000
ImageSize: 00011000
fffff880`099df000 fffff880`099f4000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
Checksum: 00000000
ImageSize: 00015000
fffff880`099ad000 fffff880`099c2000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`09980000 fffff880`09982000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`0996b000 fffff880`09980000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`09969000 fffff880`0996b000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`09954000 fffff880`09969000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`0991a000 fffff880`0991c000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`09905000 fffff880`0991a000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`09903000 fffff880`09905000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`098ee000 fffff880`09903000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`01800000 fffff880`0180e000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`0180e000 fffff880`0181a000 dump_pciidex
Checksum: 00000000
ImageSize: 0000C000
fffff880`0181a000 fffff880`01825000 dump_msahci.
Checksum: 00000000
ImageSize: 0000B000
fffff880`01825000 fffff880`01838000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
fffff880`08b94000 fffff880`08b96000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`08b7f000 fffff880`08b94000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`08b7d000 fffff880`08b7f000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`08b68000 fffff880`08b7d000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`087ea000 fffff880`087ec000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`087d5000 fffff880`087ea000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
fffff880`082aa000 fffff880`082ac000 USBD.SYS
Checksum: 00000000
ImageSize: 00002000
fffff880`08295000 fffff880`082aa000 tsusbflt.sys
Checksum: 00000000
ImageSize: 00015000
Checksum: 00000000
ImageSize: 00002000
Checksum: 00000000
ImageSize: 00015000
Checksum: 00000000
ImageSize: 00002000
Checksum: 00000000
ImageSize: 00015000
In your bios could you raise your mem voltage to 1.60V or as close to that as possible.
Elmer said:You are getting a lot of unloaded modules related to USB's. Do you have an Atheros Bluetooth device (also mentioned)?
The manuafacturer website lists the standard test voltage of this ram as 1.5V, may I ask why raising it 1.6V might help?
The raising of Vdimm to 1.6V could help stabilize the memory\system. It's entirely up to you though. Was helping a member earlier in the week with a very similar system to yours. Same cpu and after fighting with it for hours it turned out a small bump is vdimm solved his problem.
You could also disable BT in the bios
I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Win7 Startup Repair feature).
In Windows 7 you can make a Startup Repair disk by going to Start....All Programs...Maintenance...Create a System Repair Disc - with Windows Vista you'll have to use your installation disk or the "Repair your computer" option at the top of the Safe Mode menu .
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
Just remember, any time Memtest reports errors, it can be either bad RAM or a bad motherboard slot.
It can also be caused by misconfigured memory timings. Ken I hope you don't mind me dropping that in too
