Loading Dump File [F:\a\Minidump\D M P\DMP\013011-16894-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e19000 PsLoadedModuleList = 0xfffff800`03056e50
Debug session time: Sun Jan 30 12:40:40.265 2011 (UTC - 5:00)
System Uptime: 0 days 0:00:10.982
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
BugCheck 124, {0, fffffa80069202a8, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa80069202a8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`02fa86f0 fffff800`030d3a89 : fffffa80`06920280 fffffa80`05397040 00000000`0000000b 00000000`00000001 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`02fa8c10 fffff800`02fb5667 : fffffa80`06920280 fffff800`0302e5f8 fffffa80`05397040 00000002`00000005 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`02fa8c40 fffff800`02f1dc45 : fffff800`03090360 fffffa80`0695c138 fffffa80`0695c130 fffffa80`05397040 : nt!WheapProcessWorkQueueItem+0x57
fffff880`02fa8c80 fffff800`02e96961 : fffff880`00dcde00 fffff800`02f1dc20 fffffa80`05397040 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`02fa8cb0 fffff800`0312dc06 : 00000538`00000000 fffffa80`05397040 00000000`00000080 fffffa80`05310890 : nt!ExpWorkerThread+0x111
fffff880`02fa8d40 fffff800`02e67c26 : fffff880`02d63180 fffffa80`05397040 fffff880`02d6dfc0 00000538`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`02fa8d80 00000000`00000000 : fffff880`02fa9000 fffff880`02fa3000 fffff880`035c45e0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
