Random BSOD every now and then
Since the last week I seem to be getting a random BSOD about two to three times a day. The computer just restarts itself and works normally until the next BSOD. Even though everything else seems to work properly this does worry me. I tried clicking check for solution when Windows gave me the "Windows has shutdown because of an unexpected error" window. I'm using Win7 Ultimate on a Toshiba Satellite L350D. Here's the error log, I hope someone can help me with this.
Thanks in advance.
Log:
Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 2067 Additional information about the problem: BCCode: 19 BCP1: 00000003 BCP2: 8520D3F0 BCP3: 82B493E8 BCP4: 853BF618 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\072511-58827-01.dmp C:\Users\Natasja\AppData\Local\Temp\WER-88780-0.sysdata.xml Read our privacy statement online: Windows 7 Privacy Statement - Microsoft Windows If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
View attachment Minidump.rar
Elmer
Hi InfernuZ and Welcome to The Forum.
STOP 0x00000019: BAD_POOL_HEADER
Usual causes: Device driver
Your latest dump file lists Pool_Corruption which usually indicates bad drivers.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Update as many of the drivers as you can.
If crashes continue you may have to enable DriverVerifier to expose the real culprit.
As a Priority:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct AVG Remover for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download BSOD friendly Microsoft Security Essentials as AVG's replacement. Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the AVG Removal tool(s). Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled!
PS2.sys Mon Jun 04 14:59:59 2001 HP Multimedia Keyboard Driver
Outdated Drivers. Update:
AtiPcie.sys Tue May 05 16:00:16 2009 ATI PCIE Driver for ATI PCIE chipset O.E.M or AMD
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also comes as part of iTunes
HSX_CNXT.sys Fri Feb 13 20:57:25 2009
HSX_DPV.sys Fri Feb 13 21:00:17 2009
HSXHWAZL.sys Fri Feb 13 20:58:15 2009
XAudio32.sys Wed Apr 29 19:20:55 2009
SoftK56 Modem Driver by Conexant Systems
Drivers with Updates:
atikmdag.sys Thu Feb 11 05:46:08 2010 AMD Graphics Drivers
  • Download and install Driver Sweeper.
  • Uninstall your current Graphics setup through Programs and Features
  • Boot to Safe Mode
  • Run Driver Sweeper to clean up the remnants of your current Graphics set up.
  • Reboot to Normal Mode.
  • Install your new Graphics set up.
Rt86win7.sys Thu Aug 20 17:04:54 2009 Realtek PCIe GBE Family Controller v7.046
RTKVHDA.sys Tue Sep 15 12:03:37 2009 Realtek HD Audio R2.63
RTL8187B.sys Thu Aug 13 01:37:37 2009 Possible update. Realtek RTL8187B Wireless 802.11b/g 54Mbps USB 2.0 Network Adapter.
Bugcheck Analysis:
BugCheck 19, {3, 8520d3f0, 82b493e8, 853bf618}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+336 )
Followup: Pool_corruption
1: kd> !analyze -v
BAD_POOL_HEADER (19)
The pool is already corrupt at the time of the current request.
This may or may not be due to the caller.
The internal pool links must be walked to figure out a possible cause of
the problem, and then special pool applied to the suspect tags or the driver
verifier to a suspect driver.
Arguments:
Arg1: 00000003, the pool freelist is corrupt.
Arg2: 8520d3f0, the pool entry being checked.
Arg3: 82b493e8, the read back flink freelist value (should be the same as 2).
Arg4: 853bf618, the read back blink freelist value (should be the same as 2).
Debugging Details:
BUGCHECK_STR:  0x19_3
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  AVGIDSAgent.ex
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from 82b328aa to 82b33996
STACK_TEXT:
807e3e30 82b328aa 82b488c0 00000000 82b32005 nt!ExDeferredFreePool+0x336
807e3e98 9330d94d 850dc8e8 70627375 82a53314 nt!ExFreePoolWithTag+0x8a4
807e3ed0 9330e178 87a3c4e0 861cb270 869c7b5c USBPORT!USBPORT_Core_iCompleteDoneTransfer+0x7c5
807e3efc 933119af 860af028 860af0f0 860afa98 USBPORT!USBPORT_Core_iIrpCsqCompleteDoneTransfer+0x33b
807e3f24 9330bd18 860af028 860afa98 860af002 USBPORT!USBPORT_Core_UsbIocDpc_Worker+0xbc
807e3f48 82a7b4f5 860afaa4 860af002 00000000 USBPORT!USBPORT_Xdpc_Worker+0x173
807e3fa4 82a7b358 807c3120 879b25f0 00000000 nt!KiExecuteAllDpcs+0xf9
807e3ff4 82a7ab1c a241fce4 00000000 00000000 nt!KiRetireDpcList+0xd5
807e3ff8 a241fce4 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2c
WARNING: Frame IP not in any known module. Following frames may be wrong.
82a7ab1c 00000000 0000001a 00d6850f bb830000 0xa241fce4
STACK_COMMAND:  kb
FOLLOWUP_IP:
82b33996 cc              int     3
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExDeferredFreePool+336
FOLLOWUP_NAME:  Pool_corruption
IMAGE_NAME:  Pool_Corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: Pool_Corruption
FAILURE_BUCKET_ID:  0x19_3_nt!ExDeferredFreePool+336
Drivers:
8a797000 8a7df000   ACPI     ACPI.sys     Tue Jul 14 00:11:11 2009 (4A5BBF0F)
8ee5a000 8eeb4000   afd      afd.sys      Mon Apr 25 03:35:37 2011 (4DB4DDF9)
933ca000 933dc000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
932f3000 93305000   amdk8    amdk8.sys    Tue Jul 14 00:11:03 2009 (4A5BBF07)
8a922000 8a92b000   amdxata  amdxata.sys  Tue May 19 18:57:35 2009 (4A12F30F)
8a8f6000 8a8ff000   atapi    atapi.sys    Tue Jul 14 00:11:15 2009 (4A5BBF13)
8a8ff000 8a922000   ataport  ataport.SYS  Tue Jul 14 00:11:18 2009 (4A5BBF16)
93c2d000 940be000   atikmdag atikmdag.sys Thu Feb 11 05:46:08 2010 (4B7399A0)
8ae00000 8ae08000   AtiPcie  AtiPcie.sys  Tue May 05 16:00:16 2009 (4A005480)
9c5bb000 9c5da300   AVGIDSDriver AVGIDSDriver.Sys Thu Apr 14 18:10:38 2011 (4DA72A8E)
8aff9000 8affcf80   AVGIDSEH AVGIDSEH.Sys Tue Feb 22 05:22:33 2011 (4D634819)
9c567000 9c56b400   AVGIDSFilter AVGIDSFilter.Sys Thu Feb 10 04:59:07 2011 (4D53709B)
9c488000 9c48bb80   AVGIDSShim AVGIDSShim.Sys Thu Feb 10 04:59:09 2011 (4D53709D)
93296000 932d1100   avgldx86 avgldx86.sys Fri Jan 07 04:35:29 2011 (4D269811)
8ac1a000 8ac26000   avgmfx86 avgmfx86.sys Tue Mar 01 12:23:55 2011 (4D6CE55B)
8aff2000 8aff8500   avgrkx86 avgrkx86.sys Wed Mar 16 14:05:26 2011 (4D80C3A6)
8a865000 8a870000   BATTC    BATTC.SYS    Tue Jul 14 00:19:15 2009 (4A5BC0F3)
8ac26000 8ac2d000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
93288000 93296000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
8a623000 8a62b000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
94ba3000 94bbc000   bowser   bowser.sys   Wed Feb 23 05:05:24 2011 (4D649594)
996b0000 996ce000   cdd      cdd.dll      unavailable (00000000)
8a970000 8a98f000   cdrom    cdrom.sys    Tue Jul 14 00:11:24 2009 (4A5BBF1C)
8a66d000 8a718000   CI       CI.dll       Tue Jul 14 02:09:28 2009 (4A5BDAC8)
8adc2000 8ade7000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
8a62b000 8a66d000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
93305000 93308700   CmBatt   CmBatt.sys   Tue Jul 14 00:19:18 2009 (4A5BC0F6)
8ab7a000 8abd7000   cng      cng.sys      Tue Jul 14 00:32:55 2009 (4A5BC427)
8a85d000 8a865000   compbatt compbatt.sys Tue Jul 14 00:19:18 2009 (4A5BC0F6)
933bd000 933ca000   CompositeBus CompositeBus.sys Tue Jul 14 00:45:26 2009 (4A5BC716)
94f72000 94f7f000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
9320c000 93270000   csc      csc.sys      Tue Jul 14 00:15:08 2009 (4A5BBFFC)
93270000 93288000   dfsc     dfsc.sys     Wed Apr 27 03:33:45 2011 (4DB78089)
8efac000 8efb8000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
8adb1000 8adc2000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
94eea000 94f03000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
8eef9000 8ef34000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 08:26:59 2011 (4D2EB753)
94f8a000 94f93000   dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
94f7f000 94f8a000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
94f93000 94fa4000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
94fa4000 94fae000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
940be000 94175000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 01:48:33 2009 (4AC54DE1)
94175000 941ae000   dxgmms1  dxgmms1.sys  Tue Jul 14 00:25:25 2009 (4A5BC265)
8a95f000 8a970000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
8a92b000 8a95f000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
8abe5000 8abee000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:11:14 2009 (4A5BBF12)
8ad7f000 8adb1000   fvevol   fvevol.sys   Tue Jul 14 00:13:01 2009 (4A5BBF7D)
8af59000 8af8a000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:12:03 2009 (4A5BBF43)
941f9000 941fe280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:16:53 2009 (4A1151B5)
82e23000 82e5a000   hal      halmacpi.dll Tue Jul 14 00:11:03 2009 (4A5BBF07)
93c00000 93c1f000   HDAudBus HDAudBus.sys Tue Jul 14 00:50:55 2009 (4A5BC85F)
94a03000 94ab8000   HSX_CNXT HSX_CNXT.sys Fri Feb 13 20:57:25 2009 (4995DEB5)
946f2000 947f4000   HSX_DPV  HSX_DPV.sys  Fri Feb 13 21:00:17 2009 (4995DF61)
946b5000 946f2000   HSXHWAZL HSXHWAZL.sys Fri Feb 13 20:58:15 2009 (4995DEE7)
94b1e000 94ba3000   HTTP     HTTP.sys     Tue Jul 14 00:12:53 2009 (4A5BBF75)
8afea000 8aff2000   hwpolicy hwpolicy.sys Tue Jul 14 00:11:01 2009 (4A5BBF05)
93354000 9336c000   i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
9336c000 93379000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
80bb5000 80bbd000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
9461e000 94652000   ks       ks.sys       Tue Jul 14 00:45:13 2009 (4A5BC709)
8ab67000 8ab7a000   ksecdd   ksecdd.sys   Tue Jul 14 00:11:56 2009 (4A5BBF3C)
8ad2d000 8ad52000   ksecpkg  ksecpkg.sys  Fri Dec 11 04:04:22 2009 (4B21C4C6)
94fee000 94ffe000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
94fb9000 94fd4000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
8a607000 8a612000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 00:13:13 2009 (4A5BBF89)
9c48c000 9c48f180   mdmxsdk  mdmxsdk.sys  Mon Jun 19 22:26:59 2006 (449716A3)
94ab8000 94ac5000   modem    modem.sys    Tue Jul 14 00:55:24 2009 (4A5BC96C)
94fae000 94fb9000   monitor  monitor.sys  Tue Jul 14 00:25:58 2009 (4A5BC286)
933b0000 933bd000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8a8e0000 8a8f6000   mountmgr mountmgr.sys Tue Jul 14 00:11:27 2009 (4A5BBF1F)
94bbc000 94bce000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
94bce000 94bf1000   mrxsmb   mrxsmb.sys   Wed May 04 03:43:40 2011 (4DC0BD5C)
9c41a000 9c455000   mrxsmb10 mrxsmb10.sys Wed May 04 03:43:56 2011 (4DC0BD6C)
9c455000 9c470000   mrxsmb20 mrxsmb20.sys Wed May 04 03:43:47 2011 (4DC0BD63)
8a9c0000 8a9cb000   Msfs     Msfs.SYS     Tue Jul 14 00:11:26 2009 (4A5BBF1E)
8a7e8000 8a7f0000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
8ab3c000 8ab67000   msrpc    msrpc.sys    Tue Jul 14 00:11:59 2009 (4A5BBF3F)
8efa2000 8efac000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
8afda000 8afea000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
8ac38000 8acef000   ndis     ndis.sys     Tue Jul 14 00:12:24 2009 (4A5BBF58)
933f4000 933ff000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
94c00000 94c10000   ndisuio  ndisuio.sys  Tue Jul 14 00:53:51 2009 (4A5BC90F)
8efb8000 8efda000   ndiswan  ndiswan.sys  Tue Jul 14 00:54:34 2009 (4A5BC93A)
946a4000 946b5000   NDProxy  NDProxy.SYS  Tue Jul 14 00:54:27 2009 (4A5BC933)
8eeeb000 8eef9000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
8ee28000 8ee5a000   netbt    netbt.sys    Tue Jul 14 00:12:18 2009 (4A5BBF52)
8acef000 8ad2d000   NETIO    NETIO.SYS    Tue Jul 14 00:12:35 2009 (4A5BBF63)
8a9cb000 8a9d9000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
8ef98000 8efa2000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
82a13000 82e23000   nt       ntkrpamp.exe Sat Apr 09 04:57:09 2011 (4D9FD915)
8aa0d000 8ab3c000   Ntfs     Ntfs.sys     Tue Jul 14 00:12:05 2009 (4A5BBF45)
8ae08000 8ae0f000   Null     Null.SYS     Tue Jul 14 00:11:12 2009 (4A5BBF10)
94ac5000 94b0b000   nwifi    nwifi.sys    Tue Jul 14 00:51:59 2009 (4A5BC89F)
8eebb000 8eeda000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
8a84c000 8a85d000   partmgr  partmgr.sys  Tue Jul 14 00:11:35 2009 (4A5BBF27)
8a817000 8a841000   pci      pci.sys      Tue Jul 14 00:11:16 2009 (4A5BBF14)
8a8cb000 8a8d2000   pciide   pciide.sys   Tue Jul 14 00:11:19 2009 (4A5BBF17)
8a8d2000 8a8e0000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:11:15 2009 (4A5BBF13)
8abd7000 8abe5000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
9c490000 9c527000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
94ebb000 94eea000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
93c1f000 93c22720   PS2      PS2.sys      Mon Jun 04 14:59:59 2001 (3B1B945F)
8a612000 8a623000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
933dc000 933f4000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
8efda000 8eff2000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
8ee00000 8ee17000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
8a800000 8a817000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
8ef57000 8ef98000   rdbss    rdbss.sys    Tue Jul 14 00:14:26 2009 (4A5BBFD2)
93200000 9320a000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
8ac2d000 8ac35000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:01:40 2009 (4A5BCAE4)
8a9b0000 8a9b8000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
8a9b8000 8a9c0000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
8ad52000 8ad7f000   rdyboost rdyboost.sys Tue Jul 14 00:22:02 2009 (4A5BC19A)
94b0b000 94b1e000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
941ae000 941e0000   Rt86win7 Rt86win7.sys Thu Aug 20 17:04:54 2009 (4A8D7426)
94c17000 94eba2c0   RTKVHDA  RTKVHDA.sys  Tue Sep 15 12:03:37 2009 (4AAF7489)
94f03000 94f68000   RTL8187B RTL8187B.sys Thu Aug 13 01:37:37 2009 (4A836051)
9c527000 9c531000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
8afd2000 8afda000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
9dc1d000 9dc6f000   srv      srv.sys      Fri Apr 29 03:57:31 2011 (4DBA291B)
9c56c000 9c5bb000   srv2     srv2.sys     Fri Apr 29 03:57:19 2011 (4DBA290F)
9c531000 9c552000   srvnet   srvnet.sys   Fri Apr 29 03:57:12 2011 (4DBA2908)
93c25000 93c26380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
93379000 933af480   SynTP    SynTP.sys    Fri Sep 18 03:29:36 2009 (4AB2F090)
8ae10000 8af59000   tcpip    tcpip.sys    Mon Apr 25 03:36:36 2011 (4DB4DE34)
9c552000 9c55f000   tcpipreg tcpipreg.sys Tue Jul 14 00:54:14 2009 (4A5BC926)
8a9f0000 8a9fb000   TDI      TDI.SYS      Tue Jul 14 00:12:12 2009 (4A5BBF4C)
8a9d9000 8a9f0000   tdx      tdx.sys      Tue Jul 14 00:12:10 2009 (4A5BBF4A)
8ef47000 8ef57000   termdd   termdd.sys   Tue Jul 14 01:01:35 2009 (4A5BCADF)
99680000 99689000   TSDDD    TSDDD.dll    Tue Jul 14 01:01:40 2009 (4A5BCAE4)
932d2000 932f3000   tunnel   tunnel.sys   Tue Jul 14 00:54:03 2009 (4A5BC91B)
94652000 94660000   umbus    umbus.sys    Tue Jul 14 00:51:38 2009 (4A5BC88A)
93c23000 93c24700   USBD     USBD.SYS     Tue Jul 14 00:51:05 2009 (4A5BC869)
941ea000 941f9000   usbehci  usbehci.sys  Tue Jul 14 00:51:14 2009 (4A5BC872)
94660000 946a4000   usbhub   usbhub.sys   Tue Jul 14 00:52:06 2009 (4A5BC8A6)
941e0000 941ea000   usbohci  usbohci.sys  Tue Jul 14 00:51:14 2009 (4A5BC872)
93309000 93354000   USBPORT  USBPORT.SYS  Tue Jul 14 00:51:13 2009 (4A5BC871)
8a841000 8a84c000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
8abee000 8abfa000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
8a98f000 8a9b0000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
8af8a000 8af92380   vmstorfl vmstorfl.sys Tue Jul 14 00:28:44 2009 (4A5BC32C)
8a870000 8a880000   volmgr   volmgr.sys   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8a880000 8a8cb000   volmgrx  volmgrx.sys  Tue Jul 14 00:11:41 2009 (4A5BBF2D)
8af93000 8afd2000   volsnap  volsnap.sys  Tue Jul 14 00:11:34 2009 (4A5BBF26)
94f68000 94f72000   vwifibus vwifibus.sys Tue Jul 14 00:52:02 2009 (4A5BC8A2)
8eeda000 8eeeb000   vwififlt vwififlt.sys Tue Jul 14 00:52:03 2009 (4A5BC8A3)
8ef34000 8ef47000   wanarp   wanarp.sys   Tue Jul 14 00:55:02 2009 (4A5BC956)
8aa00000 8aa0d000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
8a718000 8a789000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
8a789000 8a797000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8eeb4000 8eebb000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
99420000 9966c000   win32k   win32k.sys   Sat Jun 11 03:36:57 2011 (4DF2D4C9)
8a7df000 8a7e8000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
94fd4000 94fee000   WudfPf   WudfPf.sys   Tue Jul 14 00:50:13 2009 (4A5BC835)
9c55f000 9c567000   XAudio32 XAudio32.sys Wed Apr 29 19:20:55 2009 (49F89A87)
Unloaded modules:
9dcd9000 9dcf0000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  00017000
9dc6f000 9dcd9000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
9c470000 9c488000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8ade7000 8adf4000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8adf4000 8adff000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
8ac00000 8ac09000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
8ac09000 8ac1a000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
First of all thanks for the fast and detailed reply. I did what you said step by step and everything seems to be going smoothly now, the computer has been on for a few hours and used for daily stuff and no BSOD's have appeared so I'm assuming the problem is fixed. Thanks once again!
Elmer
Thanks for the feedback InfernuZ. Give it a few days to be sure before you think "Phew, that's over"!!
