Windows 7 Random BSOD, Freezes, and Restarts
Xeizell
Hi there. I'm getting this random BSOD since 2 or 3 weeks ago. Sometimes when idle, browsing, and gaming. But sometimes I'm not getting any at all for a whole day. And I also getting this random hangs, freezes, and restarts. Can this be caused by bad hardware? I hope someone can help. :frown:
Please visit Windows Update and get ALL available updates.
Windows 7 doesn't like wireless USB network devices. Here's my rant on the subject:
I do not recommend using wireless USB devices. Especially in Win7 systems.
These wireless USB devices have many issues with Win7 - and using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
Please un-install MSI Afterburner - it, along with Riva Tuner and EVGA Precision are known to cause BSOD's on some Win7 systems.
Please post back if this...
Please post back if this doesn't solve the BSOD issues. While waiting for a reply (if still getting BSOD's), please run Driver Verifier according to these instructions: Link Removed
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Wed Oct 17 20:42:35.774 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101812-13275-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 1:48:28.054[/B]
BugCheck Code: [B]BugCheck D1, {18, 2, 0, fffff88000f211d2}[/B]
Probably caused by :[B]Wdf01000.sys ( Wdf01000!FxRequestBase::CompleteSubmitted+11e )[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_Wdf01000!FxRequestBase::CompleteSubmitted+11e[/B]
  BIOS Version                  080015
  BIOS Release Date             05/30/2011
  Manufacturer                  BIOSTAR Group
  Product Name                  TA890GXB HD
[/font]
3rd Party Drivers:
amdxata.sys        Fri Mar 19 12:18:18 2010 (4BA3A3CA)
ElbyCDIO.sys       Thu Dec 16 17:58:13 2010 (4D0A9985)
VClone.sys         Sat Jan 15 11:21:04 2011 (4D31C970)
athurx.sys         Wed Apr 20 06:07:45 2011 (4DAEB071)
ALSysIO64.sys      Sat Jul  9 20:27:45 2011 (4E18F201)
LHidFilt.Sys       Fri Sep  2 02:23:09 2011 (4E60764D)
LMouFilt.Sys       Fri Sep  2 02:23:15 2011 (4E607653)
LUsbFilt.Sys       Fri Sep  2 02:23:19 2011 (4E607657)
[B]RTCore64.sys       Tue Sep  6 08:24:50 2011 (4E661112)[/B]
epfwwfpr.sys       Wed Mar  7 09:28:53 2012 (4F5770A5)
eamonm.sys         Wed Mar  7 09:32:36 2012 (4F577184)
ehdrv.sys          Wed Mar  7 09:33:42 2012 (4F5771C6)
Rt64win7.sys       Wed Apr 11 12:29:16 2012 (4F85B15C)
HWiNFO64A.SYS      Thu May 10 09:05:19 2012 (4FABBD0F)
RTKVHD64.sys       Tue Aug 14 08:24:34 2012 (502A4382)
idmwfp.sys         Thu Sep 27 04:07:16 2012 (50640934)
nvlddmkm.sys       Tue Oct  2 14:21:13 2012 (506B3099)
[/font]
Link Removed - Invalid URL
Analysis:
[FONT=lucida console]**************************Wed Oct 17 20:42:35.774 2012 (UTC - 4:00)**************************
BUGCHECK_STR:  0xD1
  BIOS Version                  080015
[/FONT]
3rd Party Drivers:
[/FONT]
Sorry for the wait. But it turns out that the culprit was my RAM, somehow I can only use one instead both (2x2gb). So I'm gonna replace them soon. Thank you so much for the time, good sir John. :)
I'm glad that you were able to solve it. Thanks for letting us know!
