bestmitbbs
The PC randomly BSoD. Sometimes, it happens during mid night when the computer is idle. Sometimes, right when I edit a file. There are four instances in the attached file.
Thank you very much!
View attachment Minidump.rar
Windows 7 Enterprise
Dell XPS 8100
Intel Core i7-870 processor(8MB Cache, 2.93GHz)
12GB DDR3 SDRAM at 1333MHz-2X2GB/2x4GB
ATI Radeon HD 5770 1024MB GDDR5 (320-9990)
1TB Serial ATA 2 Hard Drive 7200 RPM (342-0171)
Hey there, welcome.
1) Install this Microsoft patch to update iaStorv.sys:
iaStorV iaStorV.sys Wed Apr 08 12:57:17 2009
An update that improves the compatibility of Windows 7 and Windows Server 2008 R2 with Advanced Format Disks is available
2) Uninstall Daemon Tools. Then use this installer/uninstaller to remove the notorious sptd.sys which crashed you (do not update instead while using):
PowerISO is perfectly stable and the disc emulation is free forever. Install that to replace DT:
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
3) Definitely uninstall notorious Norton/Symantec in safe mode with this tool:
AV Uninstallers -...
Hey there, welcome.
AV Uninstallers - Windows 7 Forums
Reboot and install MSE to replace it.
Enjoy. :)
Thanks, but I don't think I have Daemon Tools installed. Also, I don't see the sptd.sys using BlueScreenView. Could you please check it again? Thanks a lot!
Please follow what I said. Both Daemon Tools and sptd.sys need to be removed.
BSV is not professional by any means.
You're welcome.
