Random BSOD in 8.1, please help!
camar0rs
It seems to happen more when im on websites like facebook, etc...
attached are the latest 2 dumps and memory output
camar0rs
Windows Forum Admin
BugCheck D1, {8, 2, 0, fffff80071611b89}
Probably caused by : NETIO.SYS ( NETIO!StreamInvokeCalloutAndNormalizeAction+59 )
Followup: MachineOwner
both your dump files are network related but are a little vague as to the actual culprit or in other words which driver, if any, caused the bsod.
I see you were using chrome around the time of the bsod. Is the Chrome browser fully updated? You can check by opening the settings tab and checking under 'About Google Chrome'.
I couldn't find a date for your Network driver as it had been flagged up by the machine as an unloaded module but in any case it only recently updated Please uninstall the old version before installing the new:
http://www.msi.com/support/nb/GT70-2OD.html#down-driver&Win8.1 64
Now you do have one or two other applications which are network related but before we look at them see if updating the network driver helps. If the bsod continues please post the new dump file.
Windows Forum Admin
Oh and i merged your threads.
camar0rs
Version 43.0.2357.132 m
Google Chrome is up to date
One thing i did was turn off website protection from malwarebytes so far...
i use an intel 7260 wireless and driver is up to date, im updating the onboard nic now but i never use it
wondering if the wireless card could be going bad causing the issue
camar0rs
thanks, I just updated this and will test
Windows Forum Admin
Cool.. Please post any new dump files.
