OsNi
Hi, I build this system in October and since then I've had this BSOD
MEMORY_MANAGEMENT 0x0000001a
Caused by driver: ntoskrnl.exe
Please someone help me.
I already try checking the ram sticks for errors and there is nothing.
Here are all the dumps: Link Removed - Invalid URL
My system specifications are as follows:
Motherboard: ASUS Crosshair IV Formula
CPU: AMD Phenom II X6 1090T Processor ~3.2GHz
RAM: CORSAIR DOMINATOR 8GB (4 x 2GB) DDR3 1600
Video Card: ATI Radeon HD 4800 Series SAPPHIRE VAPOR-X HD 4890 1GB GDDR5 PCI-E
The MEMORY_MANAGEMENT BSOD (Blue Screen of Death) error with code 0x0000001a can be quite troublesome, but there are steps we can take to troubleshoot and hopefully resolve this issue. The fact that you have already checked the RAM sticks for errors is a good start. Given that the driver causing the issue is \ntoskrnl.exe (Windows Kernel), there are a few other troubleshooting steps we can take:
Troubleshooting Steps:​
  1. Update Drivers:
    • Ensure that all your drivers, especially for the motherboard and graphics card, are up to date. Outdated drivers can sometimes cause these types of errors.
    []Check for System File Corruption:
    • Run the System File Checker (SFC) tool to check for and repair...
  1. Update Drivers:
    • Run the System File Checker (SFC) tool to check for and repair corrupted system files.
      • Open Command Prompt as an administrator and run the command: sfc /scannow
    ]Check for Disk Errors:
    • Run a disk check to detect and repair disk errors.
      • Open Command Prompt as administrator and run: chkdsk /f /r
  2. Review System Log:
    • Check the Windows system event logs for any relevant error messages leading up to the BSOD.
      Updated System Specifications:​
      • Motherboard: ASUS Crosshair IV Formula
      • CPU: AMD Phenom II X6 1090T Processor ~3.2GHz
      • RAM: CORSAIR DOMINATOR 8GB (4 x 2GB) DDR3 1600
      • Video Card: ATI Radeon HD 4800 Series SAPPHIRE VAPOR-X HD 4890 1GB GDDR5 PCI-E
      Dump File Analysis:​
      You mentioned having the dump files available. If you could upload them here, I can analyze them to provide more specific insights into what might be causing the issue. Let's examine the dump files and take further steps to resolve the MEMORY_MANAGEMENT BSOD error you are experiencing.
