RANDOM BSOD please help
hey guys since last week or so ive been getting random bsod. ive had this pc for almost three years now without any issues. the things i have tried so far are cleaning inside the case and reseating the cpu cooler and installing windows. but the issue still persists.
my specs are,
Intel i7-930 @ 4.0GHz 1.28 volts using offset method
Asus GTX 680 directcu ii TOP at 7000mhz mem clock
Asus P6X58D Premium Motherboard
Corsair 1600 DDR3 4GB x3 @ 1531MHz 8-8-8-24 1.64v
Corsair HX850
Samsung 23a950d @ 1920x1080
Logitech g9x + CM Storm Trigger +
Asus Xonar DX + Logitech X-540 + Audio Technica AD700
any help would be much appreciated
anyone knows whats going on with my system cus im at my wits end trying to figure this one out :(
usasma
Fantastic Member
Please stop overclocking while we're troubleshooting. Once we've stopped the BSOD's, feel free to resume the overclock.
Only 115 updates since SP1 - most systems have 130 to 140. Please visit Windows Update and get ALL available updates
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
10 Nov 2012 - I'm seeing an upswing in SSD errors - but most appear due to older storage controller drivers. I strongly suggest NOT using storage controller drivers that don't date from 2012 (if none are available, don't connect an SSD to that controller)
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
Daemon Tools (and Alcohol 120% software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions). I strongly suspect that this hold true for Win8 systems also.
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
MSI Afterburner (along with Riva Tuner and EVGA Precision) are known to cause BSOD's on some Win7 systems. Please un-install it immediately.
Your Asus ATK0110 ACPI Utility driver (ASACPI.sys) dates from 2005. This version is known to cause BSOD's in Win7 systems.
Please download the latest version for your system from the Asus website. It's in the Utilities section, is named "ATK0110 driver for WindowsXP/Vista/Win7 32&64-bit" and is the 10th one down on the list.
ASACPI.sys Sun Mar 27 22:30:36 2005 (42476C4C)
Asus ATK0110 ACPI Utility (a known BSOD maker in Win7). Also a part of the Asus PCProbe and AISuite Utilities
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
WinRing0x64.sys Sat Jul 26 09:29:37 2008 (488B26C1)
many different programs that center around the using of the WinRing libraries (RealTemp, Corsair Link2 (known BSOD issues w/Win8), etc)
http://www.carrona.org/drivers/driver.php?id=WinRing0x64.sys
RTCore64.sys Tue Sep 6 08:24:50 2011 (4E661112)
RivaTuner/EVGA Precision/MSI Afterburner (known BSOD issues w/Win7)
http://www.carrona.org/drivers/driver.php?id=RTCore64.sys
sptd.sys Sat Aug 18 17:05:38 2012 (503003A2)
SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Win7)
http://www.carrona.org/drivers/driver.php?id=sptd.sys
If the BSOD's continue after taking all of the above steps, please run these free hardware diagnostics: Hardware Diagnostics
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Wed Jan  9 05:19:13.699 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010913-6723-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 1:11:11.605[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+209dca )[/B]
BugCheck [B]3B, {c000001d, fffff880036c49e6, fffff880036c3fa0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c000001d, Exception code that caused the bugcheck
Arg2: fffff880036c49e6, Address of the instruction which caused the bugcheck
Arg3: fffff880036c3fa0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]MSIAfterburner[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nvlddmkm+209dca[/B]
CPUID:        "Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz"
MaxSpeed:     2800
CurrentSpeed: [B]4009[/B]
Processor may be overclocked!
Expected Frequency:   2800
Actual Frequency:     4009
Overclock Ratio:      [color=red]1.43179[/color]
  BIOS Version                  1501
  BIOS Release Date             05/10/2011
**************************Mon Jan  7 23:48:05.714 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010813-6099-01.dmp]
System Uptime:[B]0 days 0:18:46.620[/B]
Probably caused by :[B]storport.sys ( storport!RaidAdapterRaiseIrqlAndExecuteXrb+18 )[/B]
BugCheck [B]D1, {0, 2, 1, fffffa800e2a96a1}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffffa800e2a96a1, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]IAStorDataMgrS[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_storport!RaidAdapterRaiseIrqlAndExecuteXrb+18[/B]
MaxSpeed:     2800
  BIOS Version                  1501
[/font]
3rd Party Drivers:
[COLOR=RED][B]ASACPI.sys                  Sun Mar 27 22:30:36 2005 (42476C4C)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
DKRtWrt.sys                 Mon Feb 14 05:03:42 2011 (4D58FDFE)
[COLOR=RED][B]RTCore64.sys                Tue Sep  6 08:24:50 2011 (4E661112)[/B][/COLOR]
yk62x64.sys                 Thu Sep  8 03:34:54 2011 (4E68701E)
a5miocjk.SYS                Wed Dec 28 04:10:52 2011 (4EFADD1C)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
kl1.sys                     Tue Jun 19 09:27:15 2012 (4FE07E33)
klim6.sys                   Thu Aug  2 07:09:23 2012 (501A5FE3)
klflt.sys                   Fri Aug  3 12:10:13 2012 (501BF7E5)
kneps.sys                   Mon Aug 13 08:45:42 2012 (5028F6F6)
[COLOR=RED][B]sptd.sys                    Sat Aug 18 17:05:38 2012 (503003A2)[/B][/COLOR]
klkbdflt.sys                Mon Sep  3 09:55:35 2012 (5044B6D7)
klmouflt.sys                Mon Sep  3 10:21:58 2012 (5044BD06)
iaStorA.sys                 Fri Sep 21 14:40:55 2012 (505CB4B7)
dump_iaStorA.sys            Fri Sep 21 14:40:55 2012 (505CB4B7)
iaStorF.sys                 Fri Sep 21 14:40:58 2012 (505CB4BA)
cmudaxp.sys                 Wed Oct  3 03:36:12 2012 (506BEAEC)
kltdi.sys                   Thu Oct 18 06:50:34 2012 (507FDEFA)
kerneld.x64                 Sun Oct 28 07:04:11 2012 (508D112B)
klif.sys                    Fri Nov  2 07:41:30 2012 (5093B16A)
nvlddmkm.sys                Sat Dec 29 01:47:52 2012 (50DE9218)
[COLOR=RED][B]WinRing0x64.sys             Sat Jul 26 09:29:37 2008 (488B26C1)[/B][/COLOR]
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=DKRtWrt.sys
http://www.carrona.org/drivers/driver.php?id=yk62x64.sys
a5miocjk.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=kl1.sys
http://www.carrona.org/drivers/driver.php?id=klim6.sys
http://www.carrona.org/drivers/driver.php?id=klflt.sys
http://www.carrona.org/drivers/driver.php?id=kneps.sys
http://www.carrona.org/drivers/driver.php?id=klkbdflt.sys
http://www.carrona.org/drivers/driver.php?id=klmouflt.sys
http://www.carrona.org/drivers/driver.php?id=iaStorA.sys
http://www.carrona.org/drivers/driver.php?id=dump_iaStorA.sys
http://www.carrona.org/drivers/driver.php?id=iaStorF.sys
http://www.carrona.org/drivers/driver.php?id=cmudaxp.sys
http://www.carrona.org/drivers/driver.php?id=kltdi.sys
http://www.carrona.org/drivers/driver.php?id=kerneld.x64
http://www.carrona.org/drivers/driver.php?id=klif.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
i downloaded the acpi utility driver from asus site but when i go to device manager and try to update it it says i have the latest driver for it :/
and im unable update winring0x64.sys as well cus i cannot find an update for it
could it be that my marvell yukon NICs are acting up ??
usasma
Fantastic Member
You can't update it from Device Manager.
You have to run the AsAcpiIns.exe in the 64 folder in order to install it
What program do you have that's associated with the winring0x64.sys file.
Have you tried uninstalling that?
IMO it's not likely to be the NIC - but it won't hurt to update them anyway.
#7
oh damn didnt see the exe file.. well thats updated now.. :)
winring is used by realtemp. i have the latest version of realtemp 3.70 so not sure how to update that.
BSOD again this time with a tcpip.sys error..
usasma
Fantastic Member
#10
Please remove RealTemp in order to test and see if the WinRing stuff is at fault. If it's not, feel free to re-install it AFTER the system stops BSOD'ing. BTW - what temps are you getting from RealTemp?
Try using this free temp monitoring utility while we're testing: HWiNFO, HWiNFO32 & HWiNFO64 - Hardware Information and Analysis Tools
Please remove the overclock, we cannot get good troubleshooting results without it being removed. Feel free to resume the overclock AFTER the system stops BSOD'ing.
Please remove MSI Afterburner.
Please remove Daemon Tools/Alcohol % software, then use the free tool to remove the sptd.sys driver
This is a problem that's either hardware or low-level driver based. That means that we've got to:
1) remove the overclock to make sure it isn't interfering with the tools/causing the BSOD's (as time goes on, sometimes the ability to hold an overclock without problems will degrade).
2) remove known problem low-level drivers
Once that's done - if the problem still exists - then we start troubleshooting the hardware (because we'll have ruled out the overclock and the 3rd party drivers).
Please remove these older drivers by uninstalling the program using the instructions given previously.
Analysis:
[font=lucida console]**************************Thu Jan 10 04:45:12.356 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\011013-6739-01.dmp]
System Uptime:[B]0 days 0:00:03.262[/B]
Probably caused by :[B]GenuineIntel[/B]
BugCheck [B]124, {0, fffffa800ae0f8f8, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000124]WHEA_UNCORRECTABLE_ERROR (124)[/url]
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800ae0f8f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
BUGCHECK_STR:  0x124_GenuineIntel
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x124_GenuineIntel_PROCESSOR_CACHE_PRV[/B]
**************************Wed Jan  9 21:00:49.829 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\011013-6754-01.dmp]
System Uptime:[B]0 days 1:25:47.735[/B]
Probably caused by :[B]tcpip.sys ( tcpip!UdpBeginDelivery+1c )[/B]
BugCheck [B]D1, {8c, 2, 0, fffff880024e950c}[/B]
Arguments:
Arg1: 000000000000008c, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff880024e950c, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]linpack64.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_tcpip!UdpBeginDelivery+1c[/B]
MaxSpeed:     2800
  BIOS Version                  1501
[/font]
3rd Party Drivers:
ASACPI.sys                  Wed Jul 15 23:31:29 2009 (4A5E9F11)
vpcnfltr.sys                Tue Sep 22 21:32:30 2009 (4AB97AAE)
vpchbus.sys                 Tue Sep 22 21:32:32 2009 (4AB97AB0)
vpcusb.sys                  Tue Sep 22 21:32:39 2009 (4AB97AB7)
vpcvmm.sys                  Thu Dec 31 02:27:33 2009 (4B3C5265)
arwpsgs2.SYS                Wed Dec 28 04:10:52 2011 (4EFADD1C)
[/font]
http://www.carrona.org/drivers/driver.php?id=vpcnfltr.sys
http://www.carrona.org/drivers/driver.php?id=vpchbus.sys
http://www.carrona.org/drivers/driver.php?id=vpcusb.sys
http://www.carrona.org/drivers/driver.php?id=vpcvmm.sys
arwpsgs2.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
#11
ok i took out the cpu overclock and ran intel burn test on 10000mb memory size and n extreme stress mode.. so it seems my cpu overclock was failing but then i tried upping the cpu voltage and qpi and ran IBT but i kept getting different bsods like e and d and 124 and irql
usasma
Fantastic Member
#12
Sound to me like the CPU is damaged. Try other CPU stress tests to be sure.
#13
looks like its all stable now.. it seems having load line calibration disabled fixed my issues. i had it enabled all this time so not sure why it went bad on me. hopefully this'll be it.. thanks for all the help :)
