* Bugcheck Analysis *
BugCheck F4, {3, fffffa800a52fb30, fffffa800a52fe10, fffff800039ca8b0}
Probably caused by : wininit.exe
Followup: MachineOwner
0: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa800a52fb30, Terminating object
Arg3: fffffa800a52fe10, Process image file name
Arg4: fffff800039ca8b0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa800a52fb30
IMAGE_NAME: wininit.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: wininit
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: wininit.exe
EXCEPTION_CODE: (NTSTATUS) 0xc000012f - The specified image file did not have the correct format, it did not have an initial MZ.
BUGCHECK_STR: 0xF4_C000012F
CUSTOMER_CRASH_COUNT: 1
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`02d419c8 fffff800`03a515e2 : 00000000`000000f4 00000000`00000003 fffffa80`0a52fb30 fffffa80`0a52fe10 : nt!KeBugCheckEx
fffff880`02d419d0 fffff800`039fe99b : ffffffff`ffffffff fffffa80`0a521b60 fffffa80`0a52fb30 fffffa80`0a52fb30 : nt!PspCatchCriticalBreak+0x92
fffff880`02d41a10 fffff800`0397e448 : ffffffff`ffffffff 00000000`00000001 fffffa80`0a52fb30 0000007f`00000008 : nt! ?? ::NNGAKEGL::`string'+0x176d6
fffff880`02d41a60 fffff800`036c5ed3 : fffffa80`0a52fb30 00000000`c000012f fffffa80`0a521b60 000007ff`fffda000 : nt!NtTerminateProcess+0xf4
fffff880`02d41ae0 00000000`76d015da : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0026f298 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76d015da
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_C000012F_IMAGE_wininit.exe
