Windows 7 Random BSODs, halp!
brosephsaurus
  • Minidumps.rar
Hello and Welcome !
The Dump wasn't very helpful but it did point to Direct X Driver so we can narrow down to Display card. So as a first step i would recommend to run certain stress tests.
Try this free video stress test: FurMark: Graphics Card Stability and Stress Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
FurMark Setup:
- If you have more than one GPU, select Multi-GPU during setup
- In the Run mode box, select "Stability Test" and "Log GPU Temperature"
Click "Go" to start the test
- Run the test until the GPU temperature maxes out - or until you start having problems (whichever comes first).
- Click "Quit" to exit
Try this free stress test: Free Software - GIMPS
Prime95 Setup:
- extract the contents of the zip file to a location of your choice
- double click on the executable file
- select "Just stress testing"
- select the "Blend" test. If you've already run MemTest overnight you may want to run the "Small FFTs" test instead.
- "Number of torture test threads to run" should equal the number of CPU's times 2 (if you're using hyperthreading).
The easiest way to figure this out is to go to Task Manager...Performance tab - and see the number of boxes under CPU Usage History
Then run the test for 6 to 24 hours - or until you get errors (whichever comes first).
The Test selection box and the stress.txt file describes what components that the program stresses.
Run a Hardware Diagnostic: Link Removed - Invalid URL
Also turn on Driver Verifier so we can find it the culprit is a software or a hardware follow this link for instructions Using Driver Verifier to identify issues with Drivers - Windows 7 Forums
Also follow these instructions and post the Log here Blue Screen of Death (BSOD) Posting Instructions - Windows 7 Forums
Good Luck,
Captain
Ran furmark, my gpu started at 63C and levelled out at around 92-93C, no problems, but it definitely seems like it's running a bit hot =p. Maybe a cooling issue?
EDIT: Also prime95 just reported an error:
[Wed Aug 04 22:20:58 2010]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
That seems like an issue with Voltages with RAM or CPU. Run the Memory Test i suggested in the link Link Removed - Invalid URL and make sure you run atleast 6 passes. Also make sure you not Overclocking if so under clock it or reset to default settings. Also make sure you have sufficient power for PSU.
- Captain
Just upgraded my PSU to a Corsair 750w, so that should be fine. My graphics card may be factory overclocked, I'll check that today. Ran memtest86 overnight last night (7 hours 22 min), here's the results from 7 passes.
Pass   Failing Address          Good       Bad       Err-Bits    Count
3      00126b0df64 4715MB       89824ca3   89824ca4  1           6
4      00002739f64 392 MB       8336b4a2   8336b4a3  1           7
4      00129c11f64 4764MB       b3802a0e   b3802a0f  1           8
4      0012cc81f64 4812.5MB     b3802a0e   b3802a0f  1           9
5      000045a1f64 69.6MB       04af3760   04af3761  1           10
5      00005b29f24 91.1MB       2cd9fb0e   2cd9fb0f  1           11
6      0012c001e24 4800MB       939db392   939db393  1           12
6      0012e411f64 4836MB       939db392   939db393  1           13
6      0012d995fd4 4825.5MB     0a40d04e   0a40d04f  1           14
(Pretty sure that's not all of them but I couldn't figure out how to scroll up :x)
Well I'm still getting the crashes with the 750w. The one this comp came with was like 400 or 500, figured I'd need to replace it when I got more powerful vid card.
Oh, I misunderstood the issue to be fixed. (I looked and saw "good" very quickly in your code, lol - I had just woke up! haaha)
Let's see those newer crashes. It will probably help.
For now, you could uninstall all motherboard utilities that were from the manufacturer.
Update your Steam client to latest available.
Use CPU-Z to find out which motherboard it is. Then update the bios if any newer are available from the manufacturer.
Here's the last few via WhoCrashed:
On Wed 8/4/2010 5:03:27 AM your computer crashed
This was likely caused by the following module: watchdog.sys
Bugcheck code: 0xD1 (0x61A8, 0x2, 0x0, 0xFFFFF88002B32150)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\080410-12698-01.dmp
file path: C:\Windows\system32\drivers\watchdog.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Watchdog Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Wed 8/4/2010 3:35:11 AM your computer crashed
Bugcheck code: 0xD1 (0x61A8, 0x2, 0x0, 0xFFFFF88002AB6150)
Dump file: C:\Windows\Minidump\080410-15054-01.dmp
On Wed 8/4/2010 3:21:46 AM your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFFFF, 0x8, 0xFFFFFFFFFFFFFFFF, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Dump file: C:\Windows\Minidump\080410-18096-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
And for good measure an updated folder of minidumps is attached.
  • Minidumps.rar
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [E:\Temp\Rar$DI00.935\080410-12698-01.dmp]
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`03064000 PsLoadedModuleList = 0xfffff800`032a1e50
Debug session time: Thu Aug  5 01:02:44.461 2010 (UTC - 4:00)
System Uptime: 0 days 1:27:49.912
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {61a8, 2, 0, fffff88002b32150}
Unable to load image \SystemRoot\System32\drivers\watchdog.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for watchdog.sys
*** ERROR: Module load completed but symbols could not be loaded for watchdog.sys
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+119cba )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000000061a8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88002b32150, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000330c0e0
 00000000000061a8
CURRENT_IRQL:  2
FAULTING_IP:
watchdog+1150
fffff880`02b32150 4180bcc53061000000 cmp   byte ptr [r13+rax*8+6130h],0
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff88003ce66c0 -- (.trap 0xfffff88003ce66c0)
rax=000000000000000f rbx=0000000000000000 rcx=0000000000000005
rdx=fffffa8004fa31c0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88002b32150 rsp=fffff88003ce6850 rbp=0000000000000000
 r8=0000000000960dcb  r9=000000000000000f r10=0000000000000000
r11=fffff88002b37120 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
watchdog+0x1150:
fffff880`02b32150 4180bcc53061000000 cmp   byte ptr [r13+rax*8+6130h],0 ds:7000:00000000`000061a8=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030d3b69 to fffff800030d4600
STACK_TEXT:
fffff880`03ce6578 fffff800`030d3b69 : 00000000`0000000a 00000000`000061a8 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`03ce6580 fffff800`030d27e0 : fffff880`00000004 fffffa80`04fa31c0 fffffa80`04540010 00000000`04414a88 : nt!KiBugCheckDispatch+0x69
fffff880`03ce66c0 fffff880`02b32150 : fffffa80`05948010 00000000`00000002 fffff880`03ce6940 fffff880`13d81cba : nt!KiPageFault+0x260
fffff880`03ce6850 fffffa80`05948010 : 00000000`00000002 fffff880`03ce6940 fffff880`13d81cba fffff880`13c8063d : watchdog+0x1150
fffff880`03ce6858 00000000`00000002 : fffff880`03ce6940 fffff880`13d81cba fffff880`13c8063d fffffa80`0594c000 : 0xfffffa80`05948010
fffff880`03ce6860 fffff880`03ce6940 : fffff880`13d81cba fffff880`13c8063d fffffa80`0594c000 fffffa80`040a2010 : 0x2
fffff880`03ce6868 fffff880`13d81cba : fffff880`13c8063d fffffa80`0594c000 fffffa80`040a2010 00000000`00000000 : 0xfffff880`03ce6940
fffff880`03ce6870 fffff880`13c8063d : fffffa80`0594c000 fffffa80`040a2010 00000000`00000000 00000000`00000002 : nvlddmkm+0x119cba
fffff880`03ce6878 fffffa80`0594c000 : fffffa80`040a2010 00000000`00000000 00000000`00000002 fffff880`148fd618 : nvlddmkm+0x1863d
fffff880`03ce6880 fffffa80`040a2010 : 00000000`00000000 00000000`00000002 fffff880`148fd618 fffffa80`045cd0a8 : 0xfffffa80`0594c000
fffff880`03ce6888 00000000`00000000 : 00000000`00000002 fffff880`148fd618 fffffa80`045cd0a8 fffffa80`0594c000 : 0xfffffa80`040a2010
STACK_COMMAND:  kb
FOLLOWUP_IP:
nvlddmkm+119cba
fffff880`13d81cba ??              ???
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  nvlddmkm+119cba
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4c37918e
FAILURE_BUCKET_ID:  X64_0xD1_nvlddmkm+119cba
1: kd> lm tn \
Unknown option '\'
fffff800`00bd0000 fffff800`00bda000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff800`0301b000 fffff800`03064000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff800`03064000 fffff800`03640000   nt       ntkrnlmp.exe Sat Feb 27 02:55:23 2010 (4B88CFEB)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`00c77000 fffff880`00c84000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`00c84000 fffff880`00c98000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00c98000 fffff880`00cf6000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00cf6000 fffff880`00db6000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`00db6000 fffff880`00de6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e09000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e09000 fffff880`00e33000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`00e33000 fffff880`00e3e000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00e43000 fffff880`00ee7000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ee7000 fffff880`00ef6000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ef6000 fffff880`00f4d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`00f4d000 fffff880`00f56000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00f56000 fffff880`00f60000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`00f60000 fffff880`00f93000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00f93000 fffff880`00fa0000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00fa0000 fffff880`00fb5000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fb5000 fffff880`00fca000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00fca000 fffff880`00fd1000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fd1000 fffff880`00fe1000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00fe1000 fffff880`00ffb000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`01086000 fffff880`010c0000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`010c8000 fffff880`01114000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01114000 fffff880`01128000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01128000 fffff880`01186000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`01186000 fffff880`011f9000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0121b000 fffff880`01231000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0123f000 fffff880`013e2000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`013e2000 fffff880`013fc000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`01408000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01408000 fffff880`0140f000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`0140f000 fffff880`01421000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01421000 fffff880`0142a000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0142a000 fffff880`01432000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`01437000 fffff880`01529000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`01529000 fffff880`01589000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`01589000 fffff880`015b4000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`015b4000 fffff880`015fe000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`02a00000 fffff880`02a8a000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`02a8a000 fffff880`02a93000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02a93000 fffff880`02ab9000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`02ac4000 fffff880`02aee000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02aee000 fffff880`02af7000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02af7000 fffff880`02afe000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02afe000 fffff880`02b0c000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02b0c000 fffff880`02b31000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`02b31000 fffff880`02b41000   watchdog watchdog.sys unavailable (00000000)
fffff880`02b41000 fffff880`02b4a000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b4a000 fffff880`02b53000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b53000 fffff880`02b5c000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`02b5c000 fffff880`02b67000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`02b67000 fffff880`02b78000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02b78000 fffff880`02b96000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02b96000 fffff880`02ba3000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02ba3000 fffff880`02be8000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`02be8000 fffff880`02bf7000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03800000 fffff880`03856000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`03856000 fffff880`03867000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03867000 fffff880`03884000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`03887000 fffff880`038a4000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`038a4000 fffff880`038bf000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`038bf000 fffff880`038d3000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff880`038d3000 fffff880`03924000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`03924000 fffff880`03930000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff880`03930000 fffff880`0393b000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0393b000 fffff880`0394a000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0394a000 fffff880`03968000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03968000 fffff880`03979000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03979000 fffff880`0397f000   AsUpIO   AsUpIO.sys   Sun Jul 05 22:21:38 2009 (4A515FB2)
fffff880`0397f000 fffff880`03985000   AsIO     AsIO.sys     Mon Apr 06 03:21:08 2009 (49D9AD64)
fffff880`03985000 fffff880`039ab000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`039ab000 fffff880`039c0000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`039c0000 fffff880`039e4000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`039e4000 fffff880`039f0000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`039f0000 fffff880`039f9000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`03a00000 fffff880`03a43000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`03a43000 fffff880`03a55000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`03a55000 fffff880`03aaf000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03aaf000 fffff880`03ac4000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03ada000 fffff880`03aea000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03aea000 fffff880`03b00000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03b00000 fffff880`03b24000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03b24000 fffff880`03b30000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03b30000 fffff880`03b5f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03b5f000 fffff880`03b7a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`03b7a000 fffff880`03b9b000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`03b9b000 fffff880`03bb5000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03bb5000 fffff880`03bc4000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03bc4000 fffff880`03bd3000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03bd3000 fffff880`03bd4480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`03bd5000 fffff880`03bf8000   nvhda64v nvhda64v.sys Mon Jun 21 18:07:25 2010 (4C1FE29D)
fffff880`04807000 fffff880`04844000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`04844000 fffff880`04866000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04866000 fffff880`0486b200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0486c000 fffff880`0491a000   xnacc    xnacc.sys    Mon Jul 13 20:01:05 2009 (4A5BCAC1)
fffff880`0491a000 fffff880`04928000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`04928000 fffff880`04941000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`04941000 fffff880`04949080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0494a000 fffff880`04967000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04967000 fffff880`04975000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`04975000 fffff880`04982000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`04982000 fffff880`049a5000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`049a5000 fffff880`049c6000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`049c6000 fffff880`049db000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`049db000 fffff880`049f3000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04a00000 fffff880`04a01f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04a07000 fffff880`04baf000   viahduaa viahduaa.sys Tue Oct 20 23:30:30 2009 (4ADE8056)
fffff880`04baf000 fffff880`04bbb000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04bbb000 fffff880`04bc9000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04bc9000 fffff880`04bd5000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04bd5000 fffff880`04bde000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04bde000 fffff880`04bf1000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04bf1000 fffff880`04bff000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05200000 fffff880`0524e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0524e000 fffff880`05271000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`052be000 fffff880`05386000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`05386000 fffff880`053a4000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`053a4000 fffff880`053bc000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`053bc000 fffff880`053e9000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05600000 fffff880`05669000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`056b6000 fffff880`0575c000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0575c000 fffff880`05767000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05767000 fffff880`05794000   srvnet   srvnet.sys   Tue Dec 08 03:32:26 2009 (4B1E0F1A)
fffff880`05794000 fffff880`057a6000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0581b000 fffff880`058b3000   srv      srv.sys      Tue Dec 08 03:32:55 2009 (4B1E0F37)
fffff880`05924000 fffff880`0592f000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`13c00000 fffff880`13c46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`13c46000 fffff880`13c59000   L1C62x64 L1C62x64.sys Mon Jul 27 03:04:36 2009 (4A6D5184)
fffff880`13c59000 fffff880`13c64000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`13c68000 fffff880`148f9e00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
fffff880`148fa000 fffff880`148fb180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
fffff880`148fc000 fffff880`149f0000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`149f0000 fffff880`149f8000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff960`000f0000 fffff960`003ff000   win32k   win32k.sys   unavailable (00000000)
fffff960`00500000 fffff960`0050a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
Unloaded modules:
fffff880`058b3000 fffff880`05924000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01231000 fffff880`0123f000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`00de6000 fffff880`00df2000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00df2000 fffff880`00dfb000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`00c5c000 fffff880`00c6f000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Definitely a video issue.
Two things:
1) Open an elevated command prompt. Run this command from it:
sfc /scannow
2) Use Driver Sweeper from Guru3d.com in safe mode to clean out all NVIDIA and ATI files, settings and software. Reboot to normal mode and install the latest NVIDIA driver again:
While playing games, use RivaTuner to set the fan speed to max. See how this goes.
Definitely update the bios as previously advised.
I believe I've found your issue, although please do everything else I've posted about.
AVG is notorious for stuff like this and you have a 0x3b error in one of them.
Please uninstall AVG in safe mode. Then boot to normal and install MSE since it will never cause bsod and is much more resource friendly. *Your pc will thank you.*
Tool to use in safe mode :
AV Uninstallers - Windows 7 Forums
Reference:
Loading Dump File [E:\Temp\Rar$DI40.239\080410-18408-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03050000 PsLoadedModuleList = 0xfffff800`0328de50
Debug session time: Wed Aug  4 22:43:46.007 2010 (UTC - 4:00)
System Uptime: 0 days 10:55:02.583
BugCheck 3B, {c0000005, fffff8801495edf8, fffff88006086130, 0}
Unable to load image \SystemRoot\System32\win32k.sys, Win32 error 0n2
Probably caused by : dxgkrnl.sys ( dxgkrnl!DxgkGetPresentHistory+f0 )
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8801495edf8, Address of the instruction which caused the bugcheck
Arg3: fffff88006086130, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff880`1495edf8 ff90b8000000    call    qword ptr [rax+0B8h]
CONTEXT:  fffff88006086130 -- (.cxr 0xfffff88006086130)
rax=fbfff9600033de90 rbx=000000000000080c rcx=fffffa80064406a0
rdx=0000000000000001 rsi=000000000244f7e0 rdi=fffff8a00105e560
rip=fffff8801495edf8 rsp=fffff88006086b00 rbp=fffff88006086ca0
 r8=000000000244f6a8  r9=0000000000000800 r10=fffff960001fb918
r11=000007fffffd6000 r12=0000000000000001 r13=000000000244f6e8
r14=0000000000000001 r15=0000000000000000
iopl=0         nv up ei ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010286
dxgkrnl!DxgkGetPresentHistory+0xf0:
fffff880`1495edf8 ff90b8000000    call    qword ptr [rax+0B8h] ds:002b:fbfff960`0033df48=????????????????
BUGCHECK_STR:  0x3B
PROCESS_NAME:  dwm.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff960001fb92f to fffff8801495edf8
STACK_TEXT:
fffff880`06086b00 fffff960`001fb92f : fffffa80`03b58b60 00000000`00000001 00000000`00000020 00000000`0244f7e0 : dxgkrnl!DxgkGetPresentHistory+0xf0
fffff880`06086bf0 fffffa80`03b58b60 : 00000000`00000001 00000000`00000020 00000000`0244f7e0 fffffa80`03b58b60 : win32k+0x18b92f
fffff880`06086bf8 00000000`00000001 : 00000000`00000020 00000000`0244f7e0 fffffa80`03b58b60 fffff800`030bf853 : 0xfffffa80`03b58b60
fffff880`06086c00 00000000`00000020 : 00000000`0244f7e0 fffffa80`03b58b60 fffff800`030bf853 fffffa80`00000800 : 0x1
fffff880`06086c08 00000000`0244f7e0 : fffffa80`03b58b60 fffff800`030bf853 fffffa80`00000800 00000000`0244f750 : 0x20
fffff880`06086c10 fffffa80`03b58b60 : fffff800`030bf853 fffffa80`00000800 00000000`0244f750 000007fe`f805d610 : 0x244f7e0
fffff880`06086c18 fffff800`030bf853 : fffffa80`00000800 00000000`0244f750 000007fe`f805d610 fffffa80`00000000 : 0xfffffa80`03b58b60
fffff880`06086c20 000007fe`feaf12fa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0244f6a8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`feaf12fa
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgkrnl!DxgkGetPresentHistory+f0
MODULE_NAME: dxgkrnl
IMAGE_NAME:  dxgkrnl.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ac5509e
STACK_COMMAND:  .cxr 0xfffff88006086130 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_dxgkrnl!DxgkGetPresentHistory+f0
0: kd> lm t n
fffff800`00bc2000 fffff800`00bcc000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff800`03007000 fffff800`03050000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff800`03050000 fffff800`0362c000   nt       ntkrnlmp.exe Sat Feb 27 02:55:23 2010 (4B88CFEB)
fffff880`00c00000 fffff880`00c2a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`00c2a000 fffff880`00c35000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00c35000 fffff880`00c81000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`00c81000 fffff880`00c95000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00c96000 fffff880`00ca3000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`00ca3000 fffff880`00cb7000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00cb7000 fffff880`00d15000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d15000 fffff880`00dd5000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`00dd5000 fffff880`00def000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00def000 fffff880`00df8000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e63000 fffff880`00e73000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00e73000 fffff880`00f17000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f17000 fffff880`00f26000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00f26000 fffff880`00f7d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`00f7d000 fffff880`00f86000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00f86000 fffff880`00f90000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`00f90000 fffff880`00fc3000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fc3000 fffff880`00fd0000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00fd0000 fffff880`00fe5000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fe5000 fffff880`00ffa000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01030000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`0103a000 fffff880`011dd000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01200000 fffff880`0123a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0123a000 fffff880`01274000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01274000 fffff880`0128a000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`012aa000 fffff880`01308000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`01308000 fffff880`01322000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01322000 fffff880`01395000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`01395000 fffff880`013a6000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`013a6000 fffff880`013b0000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`013b0000 fffff880`013fc000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01400000 fffff880`01408000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`0140d000 fffff880`014ff000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`014ff000 fffff880`0155f000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0155f000 fffff880`0158a000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0158a000 fffff880`015d4000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`015d4000 fffff880`015dc000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`015dc000 fffff880`015e3000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`015e3000 fffff880`015f5000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`015f5000 fffff880`015fe000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`02a0d000 fffff880`02a37000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02a37000 fffff880`02a40000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02a40000 fffff880`02a47000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02a47000 fffff880`02a55000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02a55000 fffff880`02a7a000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`02a7a000 fffff880`02a8a000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`02a8a000 fffff880`02a93000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02a93000 fffff880`02a9c000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02a9c000 fffff880`02aa5000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`02aa5000 fffff880`02ab0000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`02ab0000 fffff880`02ac1000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02ac1000 fffff880`02adf000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02adf000 fffff880`02aec000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02aec000 fffff880`02b3d000   avgtdia  avgtdia.sys  Thu Jun 03 17:09:57 2010 (4C081A25)
fffff880`02b3d000 fffff880`02b82000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`02b82000 fffff880`02bc9000   avgldx64 avgldx64.sys Thu Jun 03 17:06:48 2010 (4C081968)
fffff880`02bc9000 fffff880`02bde000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`02bde000 fffff880`02bf6000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03800000 fffff880`03851000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`03851000 fffff880`0385d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff880`0385d000 fffff880`03868000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`03868000 fffff880`03877000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`03877000 fffff880`03895000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03895000 fffff880`038a6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`038a6000 fffff880`038ad080   avgmfx64 avgmfx64.sys Sun Apr 25 17:06:15 2010 (4BD4AEC7)
fffff880`038ae000 fffff880`038b4000   AsUpIO   AsUpIO.sys   Sun Jul 05 22:21:38 2009 (4A515FB2)
fffff880`038b4000 fffff880`038ba000   AsIO     AsIO.sys     Mon Apr 06 03:21:08 2009 (49D9AD64)
fffff880`038c6000 fffff880`03950000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03950000 fffff880`03959000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03959000 fffff880`0397f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`0397f000 fffff880`0398e000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`0398e000 fffff880`039ab000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`039ab000 fffff880`039c6000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`039c6000 fffff880`039da000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff880`039da000 fffff880`03a00000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`03a00000 fffff880`03a16000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03a16000 fffff880`03a3a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03a3a000 fffff880`03a46000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03a46000 fffff880`03a75000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03a75000 fffff880`03a90000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`03a90000 fffff880`03ab1000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`03ab1000 fffff880`03acb000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03acb000 fffff880`03ada000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03ada000 fffff880`03ae9000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03ae9000 fffff880`03aea480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`03afc000 fffff880`03b20000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`03b20000 fffff880`03b33000   L1C62x64 L1C62x64.sys Mon Jul 27 03:04:36 2009 (4A6D5184)
fffff880`03b33000 fffff880`03b3e000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03b3e000 fffff880`03b94000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`03b94000 fffff880`03ba5000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03ba5000 fffff880`03bc2000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`03bc2000 fffff880`03bca000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`03bca000 fffff880`03bd6000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03bd6000 fffff880`03bdf000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`03bdf000 fffff880`03bef000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03c00000 fffff880`03c23000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`03c2f000 fffff880`03c72000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`03c72000 fffff880`03c84000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`03c84000 fffff880`03cde000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03cde000 fffff880`03cf3000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03cf3000 fffff880`03d16000   nvhda64v nvhda64v.sys Mon Jun 21 18:07:25 2010 (4C1FE29D)
fffff880`03d16000 fffff880`03d53000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`03d53000 fffff880`03d75000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`03d75000 fffff880`03d7a200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03d7b000 fffff880`03d98000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`03d98000 fffff880`03da6000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`03da6000 fffff880`03dbf000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`03dbf000 fffff880`03dc7080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`03dc8000 fffff880`03dd6000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`03dd6000 fffff880`03de3000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`03de3000 fffff880`03df8000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04a00000 fffff880`04a0e000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04a0e000 fffff880`04a1a000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04a1a000 fffff880`04a23000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04a23000 fffff880`04a36000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04a36000 fffff880`04a44000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04a44000 fffff880`04a45f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04a48000 fffff880`04bf0000   viahduaa viahduaa.sys Tue Oct 20 23:30:30 2009 (4ADE8056)
fffff880`04bf0000 fffff880`04bfc000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05000000 fffff880`05023000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`05070000 fffff880`05138000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`05138000 fffff880`05156000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`05156000 fffff880`0516e000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0516e000 fffff880`0519b000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0519b000 fffff880`051e9000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`05686000 fffff880`0572c000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0572c000 fffff880`05737000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05737000 fffff880`05764000   srvnet   srvnet.sys   Tue Dec 08 03:32:26 2009 (4B1E0F1A)
fffff880`05764000 fffff880`05776000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`05776000 fffff880`057df000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`05830000 fffff880`058c8000   srv      srv.sys      Tue Dec 08 03:32:55 2009 (4B1E0F37)
fffff880`05939000 fffff880`05944000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`05944000 fffff880`059f2000   xnacc    xnacc.sys    Mon Jul 13 20:01:05 2009 (4A5BCAC1)
fffff880`13c46000 fffff880`13c67000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`13c67000 fffff880`148f8e00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
fffff880`148f9000 fffff880`148fa180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
fffff880`148fb000 fffff880`149ef000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff960`00070000 fffff960`0037f000   win32k   win32k.sys   Sat May 01 11:06:30 2010 (4BDC4376)
fffff960`00400000 fffff960`0040a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00600000 fffff960`00627000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
Unloaded modules:
fffff880`058c8000 fffff880`05939000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0128a000 fffff880`01298000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01298000 fffff880`012a4000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01030000 fffff880`01039000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`011dd000 fffff880`011f0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
I actually uninstalled AVG a few days ago after reading that it loved to crash win7 systems, but I ran that uninstaller utility in safe mode anyway. A question about driver sweeper though; when I run it it detects the ATI and Nvidia driver components and I cleaned them, but when I run it again they're still there. Also, trying to uninstall Nvidia physx via program manager causes a bluescreen:
On Fri 8/6/2010 5:49:35 PM your computer crashed
This was likely caused by the following module: fltmgr.sys
Bugcheck code: 0x50 (0xFFFFF4FFFE066F95, 0x0, 0xFFFFF88000D8923F, 0x7)
Dump file: C:\Windows\Minidump\080610-23821-01.dmp
file path: C:\Windows\system32\drivers\fltmgr.sys
description: Microsoft Filesystem Filter Manager
If you can figure out which files or settings are still present, delete them manually in safe mode.
Use Ccleaner too while doing all this, to clean the registry. Keep at it all in safe mode. Search the registry manually after deleting files and using Ccleaner to clean the registry.
Search for NVIDIA then ATI and delete what you find.
After doing that stuff, reboot to normal and install the latest driver from NVIDIA's site.
(If you have an NVIDIA chipset, be careful not to delete the files/settings for this. Only video card stuff.)
Cleaned out and reinstalled drivers, then tested how a game (Dawn of War 2) ran. Was able to play for maybe 5 or 10 minutes then got a bluescreen:
On Fri 8/6/2010 6:48:41 PM your computer crashed
This was likely caused by the following module: dxgmms1.sys
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0x735B2450, 0x2, 0xFFFFFA8005B10700)
Error: KMODE_EXCEPTION_NOT_HANDLED
Dump file: C:\Windows\Minidump\080610-20436-01.dmp
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
Ummmm... guys... Mind if I inject a thought here?
This is a brand spanking new machine...
Put the original parts back in it and ship it off for warranty service.
This is looking like bad voltage regulators on the motherboard.
You can spend months trying to straighten this out or wait a week for a replacement machine, your choice.
