Elijah Reeds
There are random pure green pixels appearing and disappearing on my DVI-D monitor. They only appear when something is moving such as a video, or the Minecraft main menu background, but I know they aren't dead, because they move when I move the window.
If it matters i also have a VGA monitor hooked up to the same PC, and it is working fine, I'm using Windows 7 Home Premium, I tightened the cables and everything, My GPU is two AMD Radeon HD 6530D Graphics chip, and the monitor i'm using with the DVI-D worked perfectly with VGA.
Thanks in advance,
-Eli
Thanks in advance,
-Eli
