Hi c0vert and Welcome to The Forum.
STOP 0x00000124: WHEA_UNCORRECTABLE_ERROR
Usual causes: Hardware, Incompatibility, May be driver corruption
Your latest dump file lists
hardware as the probable cause.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
You're getting a stop0x124, which means blame the hardware.
Stop 0x124 Checks
- Ensure that none of the hardware is being over-clocked.
- Ensure that the machine is adequately cooled. Chase out those dust bunnies!
- Make sure all hardware related drivers are up to date.
- Possibly update the motherboard BIOS according to the manufacturer's instructions.
- Always keep The Windows system itself up to date.
See this post by
H2S04 for additional pointers:
Stop 0x124 - what to try.
Some hardware tests you should be prepared to run:
As a Priority:
Norton is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall Norton using the
Norton Removal Tool in Safe Mode. Download Blue Screen friendly
Microsoft Security Essentials as its replacement. Make sure Windows firewall is enabled!
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck 124, {0, fffffa80076eb788, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
Drivers:
fffff880`00f2f000 fffff880`00f86000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00dea000 fffff880`00df5000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`00db7000 fffff880`00dc0000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00dc0000 fffff880`00dea000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`00cdd000 fffff880`00d9d000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`0195c000 fffff880`0198c000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c7f000 fffff880`00cdd000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01478000 fffff880`014ea000 cng cng.sys Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`0198c000 fffff880`0199a000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01946000 fffff880`0195c000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`019a6000 fffff880`019af000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0199a000 fffff880`019a6000 dump_ataport dump_ataport.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`019af000 fffff880`019c2000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`010a0000 fffff880`010b4000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00c00000 fffff880`00c4c000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`014fb000 fffff880`01505000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0190c000 fffff880`01946000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01819000 fffff880`01863000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`031ed000 fffff800`03236000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`01903000 fffff880`0190c000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff800`00ba6000 fffff800`00bb0000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`013b0000 fffff880`013cb000 ksecdd ksecdd.sys Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`013cb000 fffff880`013f6000 ksecpkg ksecpkg.sys Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`00c5e000 fffff880`00c6b000 mcupdate mcupdate.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`00d9d000 fffff880`00db7000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00f8f000 fffff880`00f99000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01198000 fffff880`011f6000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`018f1000 fffff880`01903000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01505000 fffff880`015f8000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`01400000 fffff880`01460000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff800`02c04000 fffff800`031ed000 nt ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`0120d000 fffff880`013b0000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`00fd9000 fffff880`00fee000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f99000 fffff880`00fcc000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e71000 fffff880`00e78000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fee000 fffff880`00ffe000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`014ea000 fffff880`014fb000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`00c6b000 fffff880`00c7f000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`018b7000 fffff880`018f1000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`018af000 fffff880`018b7000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0102f000 fffff880`010a0000 SYMDS64 SYMDS64.SYS Wed Dec 08 00:16:58 2010 (4CFECE7A)
fffff880`010b4000 fffff880`01198000 SYMEFA64 SYMEFA64.SYS Mon Mar 14 03:20:58 2011 (4D7D899A)
fffff880`01615000 fffff880`01819000 tcpip tcpip.sys Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`00fcc000 fffff880`00fd9000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00e00000 fffff880`00e15000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e15000 fffff880`00e71000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01863000 fffff880`018af000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`00e7c000 fffff880`00f20000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f20000 fffff880`00f2f000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00f86000 fffff880`00f8f000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
Mini Kernel Dump does not contain unloaded driver list
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
