Randomly Occuring BSOD
KingSaber
View attachment W7F_15-10-2012.zip
I have been having BSOD occuring randomly. I can go the entire day without seeing one or I could have one within an hour. It seems to happen mostly when my computer is idle. I appreciate the help :)
usasma
Fantastic Member
Only 101 updates since SP1 - most systems have 130 to 140. Please visit Windows Updates and get all available updates
Please un-install AsrAppCharger - it may cause BSOD's on some systems. If needed, feel free to reinstall the latest version after we've stopped the BSOD's
Please un-install Asrock XFastUSB and XFastLAN - these are known to cause BSOD's on some Win7 systems.
Please un-install MSI Afterburner. It (along with Riva Tuner and EVGA Precision) are known to cause BSOD's on some Win7 systems.
If overclocking, please return the system to stock (non-overclocked) values while we're troubleshooting. Feel free to resume the overclock once the system is stable again (no more BSOD's).
FNETURPX.SYS Fri Oct 3 22:27:02 2008 (48E6D476)
FNet Turbo HDD USB Driver - Also part of AsRock XFastUSB package
http://www.carrona.org/drivers/driver.php?id=FNETURPX.SYS
Please un-install the AsRock XFastUSB and XFastLAN packages from your system. DO NOT update this one!!!
LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
Logitech Keyboard
http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys
LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
Logitech Gamepanel Virtual HID Device Driver
Link Removed - Invalid URL
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon Oct 15 22:23:31.051 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101512-20389-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:47:26.957[/B]
BugCheck Code: [B]BugCheck 1A, {5003, fffff70001080000, 2ac0, 2abe00045580}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2983f )[/B]
BugCheck Info: [B]MEMORY_MANAGEMENT (1a)[/B]
BUGCHECK_STR:  0x1a_5003
PROCESS_NAME: [B]AvastSvc.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_5003_nt!_??_::FNODOBFM::_string_+2983f[/B]
CPUID:        "Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz"
MaxSpeed:     3300
CurrentSpeed: [B]3292[/B]
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
  BIOS Version                  P1.30
  BIOS Release Date             09/30/2011
**************************Sun Oct 14 05:10:36.885 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-28251-01.dmp]
System Uptime:[B]0 days 12:07:23.165[/B]
BugCheck Code: [B]BugCheck 1A, {41790, fffffa80022d4450, ffff, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35054 )[/B]
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME: [B]waterfox.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35054[/B]
MaxSpeed:     3300
  BIOS Version                  P1.30
**************************Sun Oct  7 12:08:03.246 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100712-19188-01.dmp]
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:05:46.526[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+355e4 )[/B]
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+355e4[/B]
MaxSpeed:     3300
  BIOS Version                  P1.30
[/font]
3rd Party Drivers:
[COLOR=RED][B]FNETURPX.SYS                Fri Oct  3 22:27:02 2008 (48E6D476)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsrAppCharger.sys           Fri Jun 11 02:37:12 2010 (4C11D998)
RTKVHD64.sys                Wed Jul 28 06:01:36 2010 (4C500000)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
EtronXHCI.sys               Fri Jan 28 16:46:43 2011 (4D433943)
EtronHub3.sys               Fri Jan 28 16:46:45 2011 (4D433945)
Rt64win7.sys                Wed Feb 16 04:03:57 2011 (4D5B92FD)
AsrHidFilter.sys            Thu Feb 17 04:50:28 2011 (4D5CEF64)
SASKUTIL64.SYS              Tue Jul 12 17:00:01 2011 (4E1CB5D1)
SASDIFSV64.SYS              Thu Jul 21 19:03:00 2011 (4E28B024)
LGSHidFilt.Sys              Tue Feb  7 08:12:39 2012 (4F312347)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
oahlp64.sys                 Thu Jul  5 13:30:59 2012 (4FF5CF53)
rzudd.sys                   Fri Aug 17 03:01:22 2012 (502DEC42)
rzvkeyboard.sys             Fri Aug 17 03:01:26 2012 (502DEC46)
rzdaendpt.sys               Fri Aug 17 03:01:28 2012 (502DEC48)
aswFsBlk.SYS                Tue Aug 21 05:04:55 2012 (50334F37)
aswMonFlt.sys               Tue Aug 21 05:05:00 2012 (50334F3C)
aswTdi.SYS                  Tue Aug 21 05:05:01 2012 (50334F3D)
aswrdr2.sys                 Tue Aug 21 05:05:16 2012 (50334F4C)
aswSP.SYS                   Tue Aug 21 05:05:54 2012 (50334F72)
aswSnx.SYS                  Tue Aug 21 05:05:56 2012 (50334F74)
OADriver.sys                Tue Oct  2 09:01:51 2012 (506AE5BF)
OAmon.sys                   Tue Oct  2 09:01:55 2012 (506AE5C3)
oanet.sys                   Tue Oct  2 09:02:00 2012 (506AE5C8)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
RTCore64.sys                Tue Sep  6 08:24:50 2011 (4E661112)
nvlddmkm.sys                Thu Aug 30 11:50:16 2012 (503F8BB8)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=AsrHidFilter.sys
http://www.carrona.org/drivers/driver.php?id=SASKUTIL64.SYS
http://www.carrona.org/drivers/driver.php?id=SASDIFSV64.SYS
http://www.carrona.org/drivers/driver.php?id=LGSHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=rzudd.sys
http://www.carrona.org/drivers/driver.php?id=rzvkeyboard.sys
http://www.carrona.org/drivers/driver.php?id=rzdaendpt.sys
http://www.carrona.org/drivers/driver.php?id=aswrdr2.sys
http://www.carrona.org/drivers/driver.php?id=aswSP.SYS
http://www.carrona.org/drivers/driver.php?id=aswSnx.SYS
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
