nmadhu
I too keep on getting this crash error sometimes i dont get to see the error sometimes i get to see it.I get this error mainly when i encode videos or play games sometimes i get this error randomly even at the startup of windows or even during browsing web pages i thought it was a problem with my graphics card but this occured on the onboard as well.
my specs are:
MSI 790GX-G65
AMD Phenom 2 x4 945 processor
XFX ATI 5770
4 gigs Kingston DDR3 RAM
You memory is set very unwell in the bios and overclocked drastically, causing failures.
Must be set at 667 MHz and not 800 MHz like you have it now.
Best bet is to load the Optimized Defaults in the bios, save, boot to Windows, and post a new memory tab screen shot to make sure changes are well.
If not, you'll have to set it manually.
Hello, welcome. I've moved your post to its own new thread because each machine and its conditions are different and must be treated as such.
1) Uninstall Daemon Tools. Then use the installer/uninstaller found here to remove sptd.sys, being careful to click "Uninstall" while using:
Reboot and install PowerISO to replace it. The disc emulation part of the software is free forever:
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
2) Uninstall the XBOX360 controller software, MotionJoy, or similar, to remove this old driver:
xusb21 xusb21.sys Fri Feb 16 21:22:28 2007
3) Update the BlackBerry software from Research In Motion's site:
RimUsb RimUsb.sys Wed Apr 16 10:51:55 2008
RimSerial RimSerial.sys Mon Nov 24 12:02:13 2008
4) Update Realtek HD Audio driver. Run the installer once, reboot and run it again:
RTKVHDA RTKVHDA.sys Tue Oct 06 06:52:46 2009
5) Very important to remove McAfee with the removal tool you can Google and find, in safe mode:
mfetdik mfetdik.sys Thu Sep 18 19:06:11 2008
mfehidk mfehidk.sys Thu Sep 18 19:04:38 2008
Reboot and install MSE to replace it.
I tried all the steps you suggested me i even had removed blackberry desktop manager,removed daemon tools,mcafee but the problem has minimised but today i tried need for speed undercover and i got the error again.Please help me
I would also update your Realtek 8101E/8168/8169 PCI/PCIe Adapters:
Rt86win7.sys Thu Aug 20 12:04:54 2009
But at the same time I doubt it's causing a false positive 0x124 in this case:
120310-30343-01.dmp
0x124_AuthenticAMD_PROCESSOR_CACHE
Process: Solitair.exe
Stack: nt hal
So, the drivers are good now. Test the hardware.
Loading Dump File [F:\a\Minidump\D M P\120310-30343-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x86 compatible
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x82c16000 PsLoadedModuleList = 0x82d5e810
Debug session time: Thu Dec  2 16:07:12.140 2010 (UTC - 5:00)
System Uptime: 0 days 1:48:23.328
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
3: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 00000000, Machine Check Exception
Arg2: 8555601c, Address of the WHEA_ERROR_RECORD structure.
Arg3: f669c000, High order 32-bits of the MCi_STATUS value.
Arg4: 00000135, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  Solitaire.exe
CURRENT_IRQL:  1f
STACK_TEXT:
8db3e8cc 83034f3f 00000124 00000000 8555601c nt!KeBugCheckEx+0x1e
8db3e908 82ce4f04 866a22b9 8555601c 82c7e4f0 hal!HalBugCheckSystem+0xab
8db3e938 830351f1 86699008 83042e40 12091306 nt!WheaReportHwError+0x230
8db3ea4c 830352e3 86699008 86699058 00000000 hal!HalpMcaReportError+0x3b
8db3ea70 8303554f 00000000 86699058 8db3eb90 hal!HalpMceHandler+0x8b
8db3ea80 8302b5f5 00000000 33956f08 2b130600 hal!HalpHandleMachineCheck+0x3b
8db3eb90 83028261 00000000 8db39750 11030a2b hal!HalpMcaExceptionHandler+0x87
8db3eb90 00000000 00000000 8db39750 11030a2b hal!HalpMcaExceptionHandlerWrapper+0x89
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  0x124_AuthenticAMD_PROCESSOR_CACHE
Followup: MachineOwner
start    end        module name
910a5000 910d1000   1394ohci 1394ohci.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
833a7000 833ef000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
90c3e000 90c98000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
91157000 91169000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
9185c000 9186c000   amdiox86 amdiox86.sys Thu Feb 18 10:17:49 2010 (4B7D5A1D)
91057000 91068000   amdppm   amdppm.sys   Mon Jul 13 19:11:03 2009 (4A5BBF07)
8b903000 8b90c000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
8b8d7000 8b8e0000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b8e0000 8b903000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
918cf000 918ec000   AtihdW73 AtihdW73.sys Fri Sep 24 01:43:53 2010 (4C9C3A99)
91e1b000 924ae000   atikmdag atikmdag.sys Tue Oct 26 22:26:21 2010 (4CC78DCD)
91068000 910a5000   atikmpag atikmpag.sys Tue Oct 26 22:14:03 2010 (4CC78AEB)
8bdcc000 8bdd4000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:16 2009 (4A005480)
8bdf5000 8bdfc000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8b9ed000 8b9fb000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
83233000 8323b000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
919b9000 919d2000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
9fa30000 9fa4e000   cdd      cdd.dll      unavailable (00000000)
8bc11000 8bc30000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
8327d000 83328000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8bda7000 8bdcc000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
8323b000 8327d000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8bb9c000 8bbf9000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
9114a000 91157000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
a067b000 a067e580   cpuz134_x32 cpuz134_x32.sys Fri Jul 09 07:18:04 2010 (4C37056C)
9df38000 9df45000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
90d78000 90ddc000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
90ddc000 90df4000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
90d6c000 90d78000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8bd96000 8bda7000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
9191b000 91934000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
9df50000 9df59000   dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
9df45000 9df50000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
9df59000 9df6a000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
9df6a000 9df74000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
924ae000 92565000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 19:26:15 2009 (4A5BC297)
92565000 9259e000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
8b940000 8b951000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8b90c000 8b940000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8ba0e000 8ba17000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8bd64000 8bd96000   fvevol   fvevol.sys   Mon Jul 13 19:13:01 2009 (4A5BBF7D)
8bf49000 8bf7a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
925ef000 925f4280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
83026000 8305d000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
9259e000 925bd000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
9df8e000 9dfa1000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
9dfa1000 9dfa7480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
9df83000 9df8e000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
91934000 919b9000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
8bff7000 8bfff000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
9111c000 91134000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
91134000 91141000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
80bb7000 80bbf000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
91828000 9185c000   ks       ks.sys       Mon Jul 13 19:45:13 2009 (4A5BC709)
8bb89000 8bb9c000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8bd2f000 8bd54000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:34:00 2009 (4A5BC468)
9dc00000 9dc10000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
9dfc0000 9dfdb000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
83217000 83222000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 19:13:13 2009 (4A5BBF89)
9dfb5000 9dfc0000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
91000000 9100d000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
9dfaa000 9dfb5000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8b8c1000 8b8d7000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
8b951000 8b974000   MpFilter MpFilter.sys Sat Mar 20 00:03:26 2010 (4BA4490E)
a074e000 a0756e00   MpNWMon  MpNWMon.sys  Sat Mar 20 00:03:24 2010 (4BA4490C)
919d2000 919e4000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
91800000 91823000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:14:24 2009 (4A5BBFD0)
a060d000 a0648000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:14:34 2009 (4A5BBFDA)
a0648000 a0663000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:14:29 2009 (4A5BBFD5)
8b9b2000 8b9bd000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
833f8000 83400000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8bb5e000 8bb89000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
90d62000 90d6c000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8bd54000 8bd64000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8bc3a000 8bcf1000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
91181000 9118c000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
9118c000 911ae000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
918be000 918cf000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
90cbe000 90ccc000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
90c0c000 90c3e000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
8bcf1000 8bd2f000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
8b9bd000 8b9cb000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
90d58000 90d62000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82c16000 83026000   nt       ntkrpamp.exe Mon Jul 13 19:15:19 2009 (4A5BC007)
8ba2f000 8bb5e000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8bc30000 8bc37000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
90c9f000 90cbe000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8b840000 8b851000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
8b816000 8b840000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8b8ac000 8b8b3000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
8b8b3000 8b8c1000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8ba00000 8ba0e000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
a067f000 a0716000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
918ec000 9191b000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
83222000 83233000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
91169000 91181000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
911ae000 911c6000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
911c6000 911dd000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
911dd000 911f4000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
90d17000 90d58000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
911f4000 911fe000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
8ba23000 8ba2b000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8b9a2000 8b9aa000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8b9aa000 8b9b2000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8bfca000 8bff7000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
9dc10000 9dc23000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
925bd000 925ef000   Rt86win7 Rt86win7.sys Thu Aug 20 12:04:54 2009 (4A8D7426)
9dc25000 9df379c0   RTKVHDA  RTKVHDA.sys  Tue Nov 02 07:18:52 2010 (4CCFF39C)
90d09000 90d16a60   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:44:34 2010 (4BC2DD72)
a0716000 a0720000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
9100d000 91012f00   seehcri  seehcri.sys  Wed Jan 09 03:41:37 2008 (478488C1)
91e0f000 91e19000   serenum  serenum.sys  Mon Jul 13 19:45:27 2009 (4A5BC717)
90ccc000 90ce6000   serial   serial.sys   Mon Jul 13 19:45:33 2009 (4A5BC71D)
8bfc2000 8bfca000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
a443d000 a44a7000   spsys    spsys.sys    Mon May 11 12:37:10 2009 (4A085436)
a07a6000 a07f7000   srv      srv.sys      Mon Jul 13 19:15:10 2009 (4A5BBFFE)
a0757000 a07a6000   srv2     srv2.sys     Mon Jul 13 19:14:52 2009 (4A5BBFEC)
a0720000 a0741000   srvnet   srvnet.sys   Mon Jul 13 19:14:45 2009 (4A5BBFE5)
91e19000 91e1a380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8be00000 8bf49000   tcpip    tcpip.sys    Mon Jul 13 19:13:18 2009 (4A5BBF8E)
a0741000 a074e000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
8b9e2000 8b9ed000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8b9cb000 8b9e2000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
90cf9000 90d09000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
9fa00000 9fa09000   TSDDD    TSDDD.dll    unavailable (00000000)
91036000 91057000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
9186c000 9187a000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
9dfa8000 9dfa9700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
91e00000 91e0f000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
9187a000 918be000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
925f5000 925ff000   usbohci  usbohci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
910d1000 9111c000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
a44a7000 a44be000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
83200000 8320b000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8ba17000 8ba23000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8b974000 8b995000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8bf7a000 8bf82380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8b851000 8b861000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8b861000 8b8ac000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8bf83000 8bfc2000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
90ce6000 90cf9000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8b995000 8b9a2000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
83328000 83399000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
83399000 833a7000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
90c98000 90c9f000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
9fba0000 9fdea000   win32k   win32k.sys   unavailable (00000000)
91141000 9114a000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
833ef000 833f8000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
9dfdb000 9dff5000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
Unloaded modules:
9df74000 9df83000   xusb21.sys
    Checksum:  00000000
    ImageSize:  0000F000
a403d000 a406b000   AODDriver2.s
    Checksum:  00000000
    ImageSize:  0002E000
a0663000 a067b000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8bdd4000 8bde1000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8bde1000 8bdec000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
8bdec000 8bdf5000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
8bc00000 8bc11000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
I formatted my system and reloaded windows 7 with all the updated drivers and ran the torture test every time i ran the torture test as suggested i got the blue screen.I have attached the minidump and the pictures as asked using cpuid.
How can i set the ram to 800mhz i tried searching in the bios and all i found was DRAM ratio which was set to auto and was showing 1600mhz
Come on dude....I said "must be set to 667 MHz"....
Anyhow, if you've used your powers of observation, 800 is half of 1600, which are both wrong.
So what is 667 half of?
I think i reduced the speed of the ram this timp check it out in the pics its 480mhz which is the lowest possible still no effects i still get a BSOD when i run prime95 i have even attached a picture till where prime95 runs and then i get a BSOD
I set it to 9-9-9-24 but a cmos error appears and after that still in cpu id i can se 9-9-9-25.After running prime95 the pc still crashes again.Is there any hope
I checked it with memtest86 no problems i guess its the processor cause when i ran the rating when it accessed the processor i got a bsod so i guess its the processor
