crates
I am having an intermittent problem with my network connection dropping out for no apparent reason.
When it drops, I still see the lights blinking on the NIC card, but cannot pass packets even to the router.
Windows does not report the connection or the cable as disconnected when this problem is occurring.
The problem will persist until I disconnect and reconnect the CAT-5e wire, or disable and re-enable the NIC.
As soon as I do one of those 2 things, connectivity immediately returns (and works for another hour or so).
I am running a legitimate copy of Windows 7 Home Premium 64-bit on an HP Pavilion.
All of the latest Windows updates and the latest firmware drivers are installed.
My ethernet connection is a wired Local Area Connection with a static IP address, gateway and DNS.
The IP address, gateway and DNS settings are accurate and work for several other computers here.
The Network Interface Card is a Realtek PCIe FE Family Controller (VEN_10EC / DEV_8136 / REV_05).
NIC Power Management, Energy Efficient Ethernet, and Link Down Power Saving are all turned off.
On the NIC, ARP/Large Send/IPv4,TCP,UDP Checksum/NS Offload, Flow Control, and are all on.
Receive Buffer Size on the NIC is 64Kb (512 buffers). Receive Side Scaling on. 128 Transmit Buffers.
Interrupt Moderation is turned on. Magic Packet features are turned off. Optimal Performance enabled.
NIC Speed and Duplex are set to 100mbps Full Duplex wherever possible (automatic was also tried).
802.1X authentication (EAP or PEAP) is disabled. Auto connection logic is disabled.
Connection routes through two switches into a Belkin router; other devices on same networks unaffected.
Much of my data is stored on a Network Attached Storage device, with UNC shares mapped to drive letters.
Other Windows, Mac and Linux devices connected to the same NAS device have no problems staying connected.
When the issue occurs, I can't ping the gateway, do DNS lookups or pass any packets as far as I can tell.
I have tried swapping out the CAT-5e cables for other cables and even ran them through a cable tester.
_____________________________________________________________________________
Network fixes I have attempted from the OS level so far include:
~ Switching the dynamic port range to start at 10,000 and run for approximately 54,000 ports
~ Systematically reviewing every running service to make certain that only the essential ones are on
~ Disabling all NIC stacks except Client for Microsoft Networks, IPv4, File and Printer Sharing and Comodo
~ Attempted connections with Comodo turned completely off and its NIC driver disabled
~ Attempted rolling back the RealTek driver to an earlier one from the same family and device line
Using netsh I have tried the following settings:
~ netsh winsock reset catalog
~ netsh int ipv4 reset reset.log
~ netsh int ipv6 reset reset.log
~ netsh int tcp set global rss=enabled
~ netsh int tcp set global chimney=automatic
~ netsh int tcp set global autotuninglevel=disabled
~ netsh int tcp set global congestionprovider=ctcp
~ netsh int tcp set global ecncapability=disabled
~ netsh int tcp set global timestamps=disabled
~ netsh int tcp set global netdma=enabled
~ netsh int tcp set global dca=enabled
I have ruled out any malware, spyware, virus or trojan horse as a possibility after extensive scans with:
~ MalwareBytes Anti-malware 1.60.1.1000 (subsequently updated to latest DB)
~ Kaspersky TDSSKiller
~ Microsoft Antimalware Security Essentials
~ Avira AntiVir
~ GMER
~ RootkitRevealer
~ Sophos SAR 15 SFX
~ PrevX v3.0 CSI Free Edition
All virus definitions and malware databases were successfully updated prior to these scans.
Software I am currently running on this PC (and that have not posed a problem for me in the past) includes:
~ Privoxy
~ Polipo
~ I2P
~ Comodo Internet Security / Comodo Firewall / Comodo Dragon
~ Avira Antivir
~ PeerBlock
~ uTorrent
~ Bitcoin
~ DAEMON Tools Pro
~ Tor with Vidalia
~ Steam
~ Skype
~ Pidgin
~ ooVoo
~ Pandora Desktop
~ Every Adobe Product in CS5/CS5.5
~ Microsoft Office 2010
~ mDesktop
~ Acunetix 8
~ Rainmeter
~ Prevx
~ Audacity
~ Avidemux
~ Celemony Melodyne
~ QuickBooks 2011 Pro Plus
~ Google Chrome
~ Mozilla Firefox
~ PowerISO
~ Evernote
~ Calibre
~ GoToManage Professional
~ Cisco VPN Service
~ SmartFTP Client
~ KVIrc
~ Process Explorer
~ SyncToy
~ WinDirStat
When the connection is working, an ICMP test responds normally:
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time=1ms TTL=64
Reply from 192.168.2.1: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.2.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
When the connection is not working, it responds with no joy:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 57, Received = 0, Lost = 57 (100% loss),
Control-C
^C
Here's the output from an IP Config command:
C:\>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : User-HP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 3C-D9-FE-ED-FA-CE
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.2.130(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.2.1
DNS Servers . . . . . . . . . . . : 91.191.136.152
62.141.58.13
85.214.73.63
NetBIOS over Tcpip. . . . . . . . : Enabled
Not that it means anything, but here's the output of a simple "nbtstat -n" command:
C:\>nbtstat -n
Node IpAddress: [192.168.2.130] Scope Id: []
NetBIOS Local Name Table
Name Type Status
USER-HP <00> UNIQUE Registered
WORKGROUP <00> GROUP Registered
USER-HP <20> UNIQUE Registered
WORKGROUP <1E> GROUP Registered
Here's the obligatory TrendMicro HiJackThis scan log:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 9:02:54 AM, on 3/23/2012
Platform: Windows 7 SP1 (WinNT 6.00.3505)
MSIE: Internet Explorer v9.00 (9.00.8112.16421)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Hewlett-Packard\HP Odometer\hpsysdrv.exe
C:\Windows\PixArt\Pac207\Monitor.exe
C:\Users\User\AppData\Local\Citrix\GoToAssist Express Expert\363\g2ax_start.exe
C:\Program Files (x86)\Adobe\Adobe Bridge CS5.1\Bridge.exe
C:\Program Files (x86)\Steam\Steam.exe
C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe
C:\Program Files (x86)\Hp\HP Software Update\hpwuschd2.exe
C:\Users\User\AppData\Local\Citrix\GoToAssist Express Expert\363\g2ax_comm_expert.exe
C:\Program Files (x86)\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe
C:\Users\User\AppData\Local\Citrix\GoToAssist Express Expert\363\g2ax_user_expert.exe
C:\Program Files (x86)\Intuit\QuickBooks 2011\QBW32.EXE
C:\Program Files (x86)\Evernote\Evernote\EvernoteClipper.exe
C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\acrotray.exe
C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe
C:\Program Files (x86)\DAEMON Tools Pro\DTShellHlp.exe
C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
C:\Program Files (x86)\Intuit\QuickBooks 2011\QBHelp.exe
C:\Program Files (x86)\PowerISO\PWRISOVM.EXE
C:\Program Files (x86)\Comodo\Dragon\dragon.exe
C:\Program Files (x86)\Pandora\Pandora.exe
C:\Users\User\AppData\Local\Google\Chrome\Application\chrome.exe
C:\Program Files (x86)\Privoxy\privoxy.exe
C:\Windows\System32\procexp.exe
C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS5.5\Dreamweaver.exe
C:\Program Files (x86)\Common Files\Adobe\CS5.5ServiceManager\CS5.5ServiceManager.exe
C:\Program Files (x86)\Tor\App\vidalia.exe
C:\Program Files (x86)\Tor\App\tor.exe
C:\Users\User\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
C:\Program Files (x86)\mDesktop\mDesktop.exe
C:\PROGRAM FILES (X86)\FOXIT SOFTWARE\FOXIT READER\FOXIT READER.EXE
C:\Program Files (x86)\Skype\Phone\Skype.exe
C:\Program Files (x86)\Microsoft Office\Office14\OUTLOOK.EXE
C:\Program Files (x86)\uTorrent\uTorrent.exe
C:\Windows\SysWOW64\rundll32.exe
C:\Program Files (x86)\HiJackThis\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = Link Removed
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = Link Removed
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = Link Removed
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = Link Removed
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = localhost; 127.0.0.1; <local>
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe
O1 - Hosts: ::1 localhost
O2 - BHO: ContributeBHO Class - {074C1DC5-9320-4A9A-947D-C042949C6216} - C:\Program Files (x86)\Adobe\Adobe Contribute CS5.1\Plugins\IEPlugin\contributeieplugin.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~2\MICROS~1\Office14\GROOVEEX.DLL
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre6\bin\ssv.dll
O2 - BHO: ZoneAlarm Toolbar Registrar - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (file missing)
O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\PROGRA~2\MICROS~1\Office14\URLREDIR.DLL
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O2 - BHO: SmartSelect - {F4971EE7-DAA0-4053-9964-665D8EE6A077} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O3 - Toolbar: Contribute Toolbar - {517BDDE4-E3A7-4570-B21E-2B52B6139FC7} - C:\Program Files (x86)\Adobe\Adobe Contribute CS5.1\Plugins\IEPlugin\contributeieplugin.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O3 - Toolbar: ZoneAlarm Toolbar - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (file missing)
O4 - HKLM\..\Run: [StartCCC] "c:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
O4 - HKLM\..\Run: [HP Software Update] c:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [Norton Online Backup] C:\Program Files (x86)\Symantec\Norton Online Backup\NOBuClient.exe
O4 - HKLM\..\Run: [PDF Complete] C:\Program Files (x86)\PDF Complete\pdfsty.exe
O4 - HKLM\..\Run: [BCSSync] "C:\Program Files (x86)\Microsoft Office\Office14\BCSSync.exe" /DelayServices
O4 - HKLM\..\Run: [Intuit SyncManager] C:\Program Files (x86)\Common Files\Intuit\Sync\IntuitSyncManager.exe startup
O4 - HKLM\..\Run: [SwitchBoard] C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O4 - HKLM\..\Run: [AdobeCS5.5ServiceManager] "C:\Program Files (x86)\Common Files\Adobe\CS5.5ServiceManager\CS5.5ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [Adobe Acrobat Speed Launcher] "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat_sl.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [Cisco AnyConnect Secure Mobility Agent for Windows] "C:\Program Files (x86)\Cisco\Cisco AnyConnect Secure Mobility Client\vpnui.exe" -minimized
O4 - HKLM\..\Run: [NBAgent] "C:\Program Files (x86)\Nero\Nero 11\Nero BackItUp\NBAgent.exe" /WinStart
O4 - HKLM\..\Run: [COMODO] C:\Program Files\COMODO\COMODO GeekBuddy\CLPSLA.exe
O4 - HKLM\..\Run: [CPA] C:\Program Files\COMODO\COMODO GeekBuddy\VALA.exe
O4 - HKLM\..\Run: [avgnt] "C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files (x86)\PowerISO\PWRISOVM.EXE -startup
O4 - HKLM\..\Run: [KVIrc] C:\Program Files (x86)\KVIrc\kvirc.exe
O4 - HKLM\..\RunOnce: [CD] C:\Windows\temp\dragon_setup.exe /S
O4 - HKLM\..\RunOnce: [Malwarebytes Anti-Malware] C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [Google Update] "C:\Users\User\AppData\Local\Google\Update\GoogleUpdate.exe" /c
O4 - HKCU\..\Run: [GoToAssist Express Expert] "C:\Users\User\AppData\Local\Citrix\GoToAssist Express Expert\363\g2ax_start.exe" "/Trigger RunAtLogon"
O4 - HKCU\..\Run: [DAEMON Tools Pro Agent] "C:\Program Files (x86)\DAEMON Tools Pro\DTAgent.exe" -autorun
O4 - HKCU\..\Run: [PeerBlock] C:\Program Files\PeerBlock\peerblock.exe
O4 - HKCU\..\Run: [mDesktop] "C:\Program Files (x86)\mDesktop\mDesktop.exe"
O4 - HKCU\..\Run: [AdobeBridge] "C:\Program Files (x86)\Adobe\Adobe Bridge CS5.1\Bridge.exe" -stealth
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [Skype] "C:\Program Files (x86)\Skype\Phone\Skype.exe" /minimized /regrun
O4 - HKCU\..\Run: [Steam] "C:\Program Files (x86)\Steam\steam.exe" -silent
O4 - HKCU\..\Run: [LightScribe Control Panel] C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe -hidden
O4 - HKCU\..\Run: [Growl] C:\Program Files (x86)\Growl for Windows\Growl.exe
O4 - HKCU\..\Run: [Vidalia] "C:\Program Files (x86)\Tor\App\vidalia.exe"
O4 - HKCU\..\Run: [ooVoo.exe] C:\Program Files (x86)\ooVoo\oovoo.exe /minimized
O4 - HKCU\..\Run: [uTorrent] "C:\Program Files (x86)\uTorrent\uTorrent.exe" /MINIMIZED
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'QBDataServiceUser21')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\Run: [mDesktop] "C:\Program Files (x86)\mDesktop\mDesktop.exe" (User 'QBDataServiceUser21')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\Run: [AdobeBridge] "C:\Program Files (x86)\Adobe\Adobe Bridge CS5.1\Bridge.exe" -stealth (User 'QBDataServiceUser21')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\Run: [Skype] "C:\Program Files (x86)\Skype\Phone\Skype.exe" /minimized /regrun (User 'QBDataServiceUser21')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\Run: [Steam] "C:\Program Files (x86)\Steam\Steam.exe" -silent (User 'QBDataServiceUser21')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\Run: [LightScribe Control Panel] C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe -hidden (User 'QBDataServiceUser21')
O4 - HKUS\S-1-5-21-1617474927-1116081613-3671628581-1005\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'QBDataServiceUser21')
O4 - Startup: EvernoteClipper.lnk = C:\Program Files (x86)\Evernote\Evernote\EvernoteClipper.exe
O4 - Startup: Growl.lnk = ?
O4 - Startup: Live Update.lnk = C:\Program Files (x86)\Symantec\Symantec Endpoint Protection\12.1.601.4699.105\Bin\SepLiveUpdate.exe
O4 - Startup: Pandora.lnk = C:\Program Files (x86)\Pandora\Pandora.exe
O4 - Startup: Pidgin.lnk = C:\Program Files (x86)\Pidgin\pidgin.exe
O4 - Startup: Start Freenet.lnk = User\AppData\Local\Freenet\freenet.exe
O4 - Startup: SyncToy 2.1(x64).lnk = ?
O4 - Global Startup: Intuit Data Protect.lnk = C:\Program Files (x86)\Common Files\Intuit\DataProtect\IntuitDataProtect.exe
O4 - Global Startup: Privoxy.lnk = C:\Program Files (x86)\Privoxy\privoxy.exe
O4 - Global Startup: QuickBooks Update Agent.lnk = C:\Program Files (x86)\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe
O4 - Global Startup: QuickBooks_Standard_21.lnk = C:\Program Files (x86)\Intuit\QuickBooks 2011\QBW32.EXE
O4 - Global Startup: Rainmeter.lnk = C:\Program Files\Rainmeter\Rainmeter.exe
O8 - Extra context menu item: Add to Evernote 4.0 - res://C:\Program Files (x86)\Evernote\Evernote\EvernoteIE.dll/204
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office14\EXCEL.EXE/3000
O8 - Extra context menu item: Se&nd to OneNote - res://C:\PROGRA~2\MICROS~1\Office14\ONBttnIE.dll/105
O9 - Extra button: @C:\Program Files (x86)\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1004 - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: @C:\Program Files (x86)\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1003 - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O9 - Extra button: @C:\Program Files (x86)\Evernote\Evernote\Resource.dll,-101 - {A95fe080-8f5d-11d2-a20b-00aa003c157a} - res://C:\Program Files (x86)\Evernote\Evernote\EvernoteIE.dll/204 (file missing)
O9 - Extra 'Tools' menuitem: @C:\Program Files (x86)\Evernote\Evernote\Resource.dll,-101 - {A95fe080-8f5d-11d2-a20b-00aa003c157a} - res://C:\Program Files (x86)\Evernote\Evernote\EvernoteIE.dll/204 (file missing)
O10 - Unknown file in Winsock LSP: c:\program files (x86)\common files\microsoft shared\windows live\wlidnsp.dll
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O15 - Trusted Zone: http://*.citrixonline.com
O15 - Trusted Zone: http://*.gotomanage.com
O15 - Trusted Zone: http://www.samsungsetup.com
O16 - DPF: {CC679CB8-DC4B-458B-B817-D447B3B6AC31} (Cisco AnyConnect Secure Mobility Client Web Control) - Link Removed - Invalid URL
O17 - HKLM\System\CCS\Services\Tcpip\..\{48244C80-E889-42E1-8EAF-645DA4D7458D}: NameServer = 91.191.136.152,62.141.58.13,85.214.73.63
O17 - HKLM\System\CCS\Services\Tcpip\..\{4B23851B-4665-4455-8BA2-DD71D630ADC9}: NameServer = 8.8.8.8,4.2.2.2
O18 - Protocol: intu-help-qb4 - {ACE22922-D07C-4860-B51B-8CF472FEC2CB} - C:\Program Files (x86)\Intuit\QuickBooks 2011\HelpAsyncPluggableProtocol.dll
O18 - Protocol: qbwc - {FC598A64-626C-4447-85B8-53150405FD57} - mscoree.dll (file missing)
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
O18 - Protocol: wlpg - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll
O18 - Filter hijack: text/xml - {807573E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE14\MSOXMLMF.DLL
O20 - AppInit_DLLs: C:\Windows\SysWOW64\guard32.dll
O23 - Service: Acunetix WVS Scheduler v8 (AcuWVSSchedulerv8) - Unknown owner - C:\Program Files (x86)\Acunetix\Web Vulnerability Scanner 8\WVSScheduler.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: AMD External Events Utility - Unknown owner - C:\Windows\system32\atiesrxx.exe (file missing)
O23 - Service: Avira Scheduler (AntiVirSchedulerService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira Realtime Protection (AntiVirService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\AntiVir Desktop\avguard.exe
O23 - Service: COMODO livePCsupport Service (CLPSLS) - COMODO - C:\Program Files\COMODO\COMODO GeekBuddy\CLPSLS.exe
O23 - Service: COMODO Internet Security Helper Service (cmdAgent) - COMODO - C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe
O23 - Service: CSIScanner - Prevx - C:\Program Files\Prevx\prevx.exe
O23 - Service: COMODO Dragon Update Service (DragonUpdater) - Unknown owner - C:\Program Files (x86)\Comodo\Dragon\dragon_updater.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: HP Client Services (HPClientSvc) - Hewlett-Packard Company - C:\Program Files\Hewlett-Packard\HP Client Services\HPClientServices.exe
O23 - Service: HP Quick Synchronization Service (HPDrvMntSvc.exe) - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe
O23 - Service: HP Software Framework Service (hpqwmiex) - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\Shared\hpqWmiEx.exe
O23 - Service: I2P Service (i2p) - Tanuki Software, Ltd. - C:\Program Files (x86)\i2p\I2Psvc.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: PDF Document Manager (pdfcDispatcher) - PDF Complete Inc - C:\Program Files (x86)\PDF Complete\pdfsvc.exe
O23 - Service: Polipo Proxy Svc (poliproxy) - Unknown owner - c:\Users\User\AppData\Roaming\polipo\poli.cmd
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: QBCFMonitorService - Intuit - C:\Program Files (x86)\Common Files\Intuit\QuickBooks\QBCFMonitorService.exe
O23 - Service: Intuit QuickBooks FCS (QBFCService) - Intuit Inc. - C:\Program Files (x86)\Common Files\Intuit\QuickBooks\FCS\Intuit.QuickBooks.FCS.exe
O23 - Service: QBIDPService (QBVSS) - Intuit Inc. - C:\Program Files (x86)\Common Files\Intuit\DataProtect\QBIDPService.exe
O23 - Service: QuickBooksDB21 - Intuit, Inc. - C:\PROGRA~2\Intuit\QUICKB~1\QBDBMgrN.exe
O23 - Service: RoxioNow Service - Roxio - C:\Program Files (x86)\Roxio\RoxioNow Player\RNowSvc.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: Adobe SwitchBoard (SwitchBoard) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: Cisco AnyConnect Secure Mobility Agent (vpnagent) - Cisco Systems, Inc. - C:\Program Files (x86)\Cisco\Cisco AnyConnect Secure Mobility Client\vpnagent.exe
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
This problem only started happening a couple of days ago. I haven't rebooted in about three weeks.
If at all possible, I would like to resolve this issue WITHOUT a reboot, as that can take several hours.
(I have over 1000 suspended Google Chrome tabs & over 500 Comodo tabs; reloading them is a massive chore).
Other users with the same (or similar) NIC cards from Realtek have reported issues similar to mine:
~ Link Removed
~ Link Removed
~ windows vista - How do I resolve a looping configuration issue on my broadband modem configuration? - Super User
~ Link Removed due to 404 Error
~ Link Removed - Invalid URL
~ Network card problems... please help - Windows 7 Forums
~ Link Removed
~ Link Removed
~ Link Removed
I will be posting this problem in several different forums in hopes that someone might be able to solve it.
Chances are, if you think this is a simple issue you've encountered before, you're not digging deep enough.
Serious responses only from people who know what they're talking about and have READ the WHOLE post, please.
It seems like you have exhaustively investigated and tried numerous troubleshooting steps to address the intermittent network connection issue you are experiencing with your Realtek PCIe FE Family Controller on Windows 7. Here are some additional suggestions and insights based on the information you provided: 1. Power Management Settings: - Ensure that the power management settings for your network adapter are properly configured. Sometimes, allowing the computer to turn off this device to save power can cause connectivity issues. You mentioned that NIC Power Management is disabled, which is good. 2. Driver and Firmware Updates: - While you mentioned having the latest firmware and drivers installed, it's worth...
It seems like you have exhaustively investigated and tried numerous troubleshooting steps to address the intermittent network connection issue you are experiencing with your Realtek PCIe FE Family Controller on Windows 7. Here are some additional suggestions and insights based on the information you provided: 1. Power Management Settings: - Ensure that the power management settings for your network adapter are properly configured. Sometimes, allowing the computer to turn off this device to save power can cause connectivity issues. You mentioned that NIC Power Management is disabled, which is good. 2. Driver and Firmware Updates: - While you mentioned having the latest firmware and drivers installed, it's worth double-checking if there are any newer updates available directly from Realtek or HP for your network adapter and system BIOS. Installing the latest drivers can sometimes resolve compatibility issues. 3. Advanced Adapter Settings: - Review and adjust advanced settings specific to the network adapter. While you've already made some adjustments, you may consider experimenting with different configurations. For example, you might try disabling features like Checksum Offload and Receive Side Scaling one at a time to see if they impact the issue. 4. Network Troubleshooting: - Test with another known working computer on the same Ethernet port and cable to verify if the issue is specific to your system. This can help determine if the problem lies with the network infrastructure or your computer. 5. System Restore Point: - If this issue started recently and you haven't rebooted for weeks, creating a system restore point and trying to revert to a state before the problem occurred might be helpful. This could potentially roll back any recent changes causing the issue. 6. Hardware Check: - Consider testing the NIC on another machine if possible or try a different NIC in your current system to rule out hardware failure. Given the comprehensive nature of your troubleshooting efforts, it might also be worth reaching out directly to Realtek support or HP support for further assistance. They may have additional insights or specific solutions tailored to your hardware configuration. It's important to keep track of any changes you make so that you can revert them if they do not improve the situation. Network connectivity issues can be complex and sometimes require a combination of solutions to resolve effectively.
