Windows 7 realVNC Viewer - he dosn't work ... ?
format
Hey,
i try to connect my Vista Ultimate PC (runs with all updates and VNC Server) from Windows Seven Netbook.
The problem is maybe, the vnc viewer works not yet under Windows 7?
Anyone had the same experience?
The compatibility mode dosn't help me any furter.
Thx in advance, olli
format
Great. Thx mate.
I will try out this next time.
Sorry for my terrible english ;)
/olli
liverpoolatnight
realvnc 4.1.3 on build 7100 x64 works
well im running 4.1.3 free edition and im running build 7100 and im on 64 bits and it works great with no problem but i only used it for the server so i can vnc through my iphone and my nokia n95 8gb.
If you having problems try out some other vnc software, but teamviewer is not VNC, Is just remote desktoping.
TightVNC: VNC-Based Free Remote Control Solution
Download UltraVNC: Remote Support Software, Remote Support tool,Remote Desktop Control, Remote Access Software, PC Remote Control
http://www.teamviewer.com
jeradw
I am able to connect with VNC Viewer on my Windows 7 64 bit build to Windows XP 32 bit builds with the VNC server installed. However, I am not able to get a connection going between Windows 7 PCs.
Aaron Dhiman
The only way I was able to get it working in Windows 7 was to run in Server mode (not as Service). The performance was atrocious, however, as it is not a 64-bit app.
Top Bottom
