Windows 7 Recruing BSOD problem
Yaro
Hello,
I seem to be having this ongoing BSOD problem. It happens at least once a day usually at least twice a day. Usually when running any variety of programs / games. I can browse the web fine. I am including the dump file that I have and hope someone would be kind enough to take a look at it for me. I have a feeling that this is being caused by a driver related to my video card, but I'm not sure and would like to be certain.
Any help is appreciated.
  • 080311-24991-01.zip
Hi Yaro and Welcome to The Forum.
STOP 0x00000124: WHEA_UNCORRECTABLE_ERROR
Usual causes:
Hardware, Incompatibility, May be driver corruption.
Your latest dump file lists hardware as the probable cause.
Old and incompatible drivers can and do cause issues with Windows 7.
As a Priority:
AsIO.sys Mon Dec 17 09:11:49 2007 ASUS Probe Utility - Has issues with Windows 7. Uninstall.
You're getting a stop0x124, which means blame the hardware.
Stop 0x124 Checks
  • Ensure that none of the hardware is being overclocked.
  • Ensure that the machine is adequately cooled. Chase out those dust bunnies!
  • Make sure all hardware related drivers are up to date.
  • Possibly update the motherboard BIOS according to the manufacturer's instructions.
  • Always keep The Windows system itself up to date.
See this thread for additional pointers: Stop 0x124 - what it means and what to try
Some hardware tests you should be prepared to run:
Bugcheck Analysis:
BugCheck 124, {0, fffffa8004a62028, b614c000, 135}
Probably caused by : hardware
Followup: MachineOwner
Drivers:
 fffff880`04000000 fffff880`0403e000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f17000 fffff880`00f6e000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03e93000 fffff880`03f1c000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0446f000 fffff880`04485000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0417c000 fffff880`04191000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`010b7000 fffff880`010c2000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`04442000 fffff880`0444a000   ASACPI   ASACPI.sys   Thu May 14 02:25:17 2009 (4A0B72FD)
fffff880`0414f000 fffff880`04156000   AsIO     AsIO.sys     Mon Dec 17 09:11:49 2007 (47663D55)
fffff880`067e6000 fffff880`067f1000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00c50000 fffff880`00c59000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00dd0000 fffff880`00dfa000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01600000 fffff880`01608000   AtiPcie  AtiPcie.sys  Tue May 05 16:00:22 2009 (4A005486)
fffff960`00960000 fffff960`009c1000   ATMFD    ATMFD.DLL    Sat Feb 19 09:00:32 2011 (4D5F86B0)
fffff880`0145c000 fffff880`01463000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0413e000 fffff880`0414f000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`05b59000 fffff880`05b77000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00770000 fffff960`00797000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`05a72000 fffff880`05a8f000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`01640000 fffff880`0166a000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00cf6000 fffff880`00db6000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`019cc000 fffff880`019fc000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c98000 fffff880`00cf6000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01180000 fffff880`011f2000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`0445f000 fffff880`0446f000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05bbc000 fffff880`05bca000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0409d000 fffff880`04120000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`04120000 fffff880`0413e000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03e68000 fffff880`03e77000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`019b6000 fffff880`019cc000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`057d5000 fffff880`057f7000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05be1000 fffff880`05bf4000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05bd6000 fffff880`05be1000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`05bca000 fffff880`05bd6000   dump_pciidex dump_pciidex.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`04d57000 fffff880`04d63000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`14b04000 fffff880`14bf8000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`13e00000 fffff880`13e46000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0110e000 fffff880`01122000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010c2000 fffff880`0110e000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`013d0000 fffff880`013da000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0197c000 fffff880`019b6000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01879000 fffff880`018c3000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`031fc000 fffff800`03245000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0441e000 fffff880`04442000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`04d06000 fffff880`04d1f000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0560e000 fffff880`05616080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05600000 fffff880`0560e000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05a90000 fffff880`05b59000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01973000 fffff880`0197c000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`04545000 fffff880`04554000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04d49000 fffff880`04d57000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00b98000 fffff800`00ba2000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04565000 fffff880`045a8000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013a4000 fffff880`013bf000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`057f7000 fffff880`057fc200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`04db5000 fffff880`04dca000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04d71000 fffff880`04d94000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c77000 fffff880`00c84000   mcupdate mcupdate.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`04d63000 fffff880`04d71000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04554000 fffff880`04563000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04d3c000 fffff880`04d49000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00db6000 fffff880`00dd0000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0142b000 fffff880`0145c000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`062b4000 fffff880`062c4000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`05b77000 fffff880`05b8f000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05b8f000 fffff880`05bbc000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`05a00000 fffff880`05a4e000   mrxsmb10 mrxsmb10.sys Wed Apr 27 03:39:40 2011 (4DB781EC)
fffff880`05a4e000 fffff880`05a72000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00c59000 fffff880`00c64000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`015f3000 fffff880`015fe000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f77000 fffff880`00f81000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01122000 fffff880`01180000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03e5d000 fffff880`03e68000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01961000 fffff880`01973000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01042000 fffff880`01088000   mv61xx   mv61xx.sys   Fri Mar 20 03:48:21 2009 (49C31205)
fffff880`0148e000 fffff880`01581000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`044a9000 fffff880`044b5000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`044b5000 fffff880`044e4000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04cb4000 fffff880`04cc9000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03f90000 fffff880`03f9f000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03f1c000 fffff880`03f61000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01581000 fffff880`015e1000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0675d000 fffff880`06775000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`01000000 fffff880`01011000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03e51000 fffff880`03e5d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c13000 fffff800`031fc000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`01201000 fffff880`013a4000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0166a000 fffff880`01673000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`14aff000 fffff880`14b04000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`13e51000 fffff880`14aff000   nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`03f6a000 fffff880`03f90000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00fc1000 fffff880`00fd6000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f81000 fffff880`00fb4000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00feb000 fffff880`00ffb000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013bf000 fffff880`013d0000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0620e000 fffff880`062b4000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04cc9000 fffff880`04d06000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c84000 fffff880`00c98000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04485000 fffff880`044a9000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`044e4000 fffff880`044ff000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`044ff000 fffff880`04520000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04520000 fffff880`0453a000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03e00000 fffff880`03e51000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`0453a000 fffff880`04545000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01481000 fffff880`0148a000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015e1000 fffff880`015ea000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015ea000 fffff880`015f3000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01927000 fffff880`01961000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`04dca000 fffff880`04de2000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04191000 fffff880`041f8000   Rt64win7 Rt64win7.sys Fri Jan 21 07:34:00 2011 (4D3936E8)
fffff880`01088000 fffff880`010b7000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`062c4000 fffff880`062cf000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0444a000 fffff880`04456000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`03f9f000 fffff880`03fbc000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`0191f000 fffff880`01927000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`066c5000 fffff880`0675d000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06312000 fffff880`0637b000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`062cf000 fffff880`06300000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04563000 fffff880`04564480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01675000 fffff880`01879000   tcpip    tcpip.sys    Mon Apr 25 03:37:30 2011 (4DB4DE6A)
fffff880`06300000 fffff880`06312000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01033000 fffff880`01040000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01011000 fffff880`01033000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03fd7000 fffff880`03feb000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04156000 fffff880`0417c000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`045bf000 fffff880`045d1000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`04d1f000 fffff880`04d3c000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`05617000 fffff880`05618f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`03e77000 fffff880`03e88000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04c5a000 fffff880`04cb4000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`13e46000 fffff880`13e51000   usbohci  usbohci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`0403e000 fffff880`04094000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00fb4000 fffff880`00fc1000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01463000 fffff880`01471000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0561e000 fffff880`057d5000   viahduaa viahduaa.sys Sat May 15 11:22:39 2010 (4BEE75EF)
fffff880`013da000 fffff880`013ff000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00c00000 fffff880`00c3c000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`018c3000 fffff880`018d3000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00fd6000 fffff880`00feb000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`018d3000 fffff880`0191f000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`03fbc000 fffff880`03fd7000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01471000 fffff880`01481000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e64000 fffff880`00f08000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f08000 fffff880`00f17000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03f61000 fffff880`03f6a000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00373000   win32k   win32k.sys   Sat Jun 11 04:06:57 2011 (4DF2DBD1)
fffff880`00c3c000 fffff880`00c50000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`045a8000 fffff880`045acd00   WmBEnum  WmBEnum.sys  Tue Apr 27 21:10:19 2010 (4BD744AB)
fffff880`04456000 fffff880`0445f000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f6e000 fffff880`00f77000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`045ad000 fffff880`045be480   WmXlCore WmXlCore.sys Tue Apr 27 21:09:26 2010 (4BD74476)
fffff880`04d94000 fffff880`04db5000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`06775000 fffff880`067e6000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01608000 fffff880`01616000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01616000 fffff880`01622000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01622000 fffff880`0162d000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`0162d000 fffff880`01640000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
