Windows 7 Recurring and growing in frequency BSOD's...
Javaslinger
I'm running Windows 7 64 bit... it is not OEM. I installed it fresh over a clean hard drive a few months ago. The laptop is a Gateway P-7811fx. It's about 3 years old and it a gaming laptop with a dedicated GPU.
Since the issues began I have run extensive MemTests, DriveSweeper, and Seatools... Checkdsk... I did find a few bad sectors but they were corrected. Other than that no issues. I am running the latest Nvidia driver.
The BSOD's are usually related to nvdlmkm.sys, dxgmms1.sys and a very few times mshaci.sys.
My core temps were high maxing out in the mid 70's and idling in the 50's, but I blew out the fan and heatsinks with compressed air and the temps dropped to idling in the low 40's and maxing in the mid 50's.
I have tried to run Malwarebyes full scan 3 times now and each time it has crashed to a BSOD somewhere during it....
I am getting BSOD's 3-4 times a day. I have still had one since blowing out the fans and heatsink.
I am running an external 1TB toshiba HD connected via eSATA. I started using this right about the same time I installed Windows 7 x64.
I have attached the files requested.
Thanks VERY much for any advice and/or suggestions,
  • Seven Forums.zip
Yeah, so while getting all this attached info something occured to me.... CPU-Z is showing a single 2GB stick installed in slot 2... Nothing in slot one...
However, I'm fairly certain when I bought this sucker it came with 4GB installed.. likely in 2x2GB sticks.... And I'm pretty sure when I was blowing it out I saw 2 sticks...
Hmmm, seems one's dead.... could that be the culprit?
Javasligner
False alarm... when I was cleaning the laptop, I reseated the memory chips and I hadn't correctly seated the one in Slot 1.... oops...
Here is it's CPU-Z SPD test...
BugCheck 7F, {8, 80050031, 6f8, fffff8800109abd2}
Probably caused by : msahci.sys ( msahci!AhciHwInterrupt+36 )
BugCheck 7F, {8, 80050031, 6f8, fffff8800fe0e68b}
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiUpdateCurrentIsrFrameTime+8f )
BugCheck 7F, {8, 80050031, 6f8, fffff8800f38652c}Probably caused by : nvlddmkm.sys ( nvlddmkm+13852c )
BugCheck 7F, {8, 80050031, 6f8, fffff80002c93214}
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )
1. I see nvClock.sys -- do not overclock untill BSOD's completely go away.
And also update it: nvoclk64.sys Tue Sep 15 17:59:25 2009
2. ZoneAlarm + Avast is not a good idea. Uninstall both and replace them with MSE:
avast! Uninstall Utility
Link Removed due to 404 Error
3. Update Marvell Yukon Ethernet Controller
yk62x64.sys Mon Feb 23 10:02:27 2009
4. RAM looks good, 2 Samsung's 2048Mb 1066 7-7-7-20.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031611-28017-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02c4b000 PsLoadedModuleList = 0xfffff800`02e90e90
Debug session time: Wed Mar 16 10:53:10.031 2011 (UTC - 4:00)
System Uptime: 0 days 0:40:46.733
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
1: kd> !analyze -v
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault).  The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
        use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
        use .trap on that value
Else
        .trap on the appropriate frame will show where the trap was taken
        (on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000006f8
Arg4: fffff8800109abd2
Debugging Details:
BUGCHECK_STR:  0x7f_8
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  9
LAST_CONTROL_TRANSFER:  from fffff80002ccabe9 to fffff80002ccb640
STACK_TEXT:
fffff880`009ecc68 fffff800`02ccabe9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000006f8 : nt!KeBugCheckEx
fffff880`009ecc70 fffff800`02cc90b2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009ecdb0 fffff880`0109abd2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`02f16000 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : msahci!AhciHwInterrupt+0x36
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`0109abd2 e89f350000      call    msahci!AtaPortReadRegisterUlong (fffff880`0109e176)
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  msahci!AhciHwInterrupt+36
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: msahci
IMAGE_NAME:  msahci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7a416
FAILURE_BUCKET_ID:  X64_0x7f_8_msahci!AhciHwInterrupt+36
Loading Dump File [F:\a\Minidump\D M P\DMP\092910-24476-01.dmp]
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02a4b000 PsLoadedModuleList = 0xfffff800`02c88e50
Debug session time: Wed Sep 29 11:44:07.871 2010 (UTC - 4:00)
System Uptime: 0 days 2:37:36.728
1: kd> !analyze -v
Else
Endif
Arguments:
Arg4: fffff8800fe0e68b
Debugging Details:
CURRENT_IRQL:  5
LAST_CONTROL_TRANSFER:  from fffff80002abaca9 to fffff80002abb740
STACK_TEXT:
fffff880`009ecc68 fffff800`02abaca9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000006f8 : nt!KeBugCheckEx
fffff880`009ecc70 fffff800`02ab9172 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009ecdb0 fffff880`0fe0e68b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`02f15fe0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiUpdateCurrentIsrFrameTime+0x8f
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`0fe0e68b ff156f290000    call    qword ptr [dxgmms1!_imp_KeQueryPerformanceCounter (fffff880`0fe11000)]
SYMBOL_NAME:  dxgmms1!VidSchiUpdateCurrentIsrFrameTime+8f
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc578
FAILURE_BUCKET_ID:  X64_0x7f_8_dxgmms1!VidSchiUpdateCurrentIsrFrameTime+8f
Loading Dump File [F:\a\Minidump\D M P\DMP\031611-28298-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c5f000 PsLoadedModuleList = 0xfffff800`02ea4e90
Debug session time: Wed Mar 16 10:11:10.934 2011 (UTC - 4:00)
System Uptime: 0 days 0:20:56.635
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
1: kd> !analyze -v
Else
Endif
Arguments:
Arg4: fffff8800f38652c
Debugging Details:
CURRENT_IRQL:  5
LAST_CONTROL_TRANSFER:  from fffff80002cdebe9 to fffff80002cdf640
STACK_TEXT:
fffff880`009ecc68 fffff800`02cdebe9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000006f8 : nt!KeBugCheckEx
fffff880`009ecc70 fffff800`02cdd0b2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009ecdb0 fffff880`0f38652c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`03115fa0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nvlddmkm+0x13852c
STACK_COMMAND:  kb
FOLLOWUP_IP:
nvlddmkm+13852c
fffff880`0f38652c e8679eeeff      call    nvlddmkm+0x22398 (fffff880`0f270398)
SYMBOL_NAME:  nvlddmkm+13852c
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d27c6da
FAILURE_BUCKET_ID:  X64_0x7f_8_nvlddmkm+13852c
Loading Dump File [F:\a\Minidump\D M P\DMP\031611-24008-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c17000 PsLoadedModuleList = 0xfffff800`02e5ce90
Debug session time: Wed Mar 16 13:30:01.876 2011 (UTC - 4:00)
System Uptime: 0 days 0:51:59.577
1: kd> !analyze -v
Else
Endif
Arguments:
Arg4: fffff80002c93214
Debugging Details:
CURRENT_IRQL:  9
LAST_CONTROL_TRANSFER:  from fffff80002c96be9 to fffff80002c97640
STACK_TEXT:
fffff880`009ecc68 fffff800`02c96be9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000006f8 : nt!KeBugCheckEx
fffff880`009ecc70 fffff800`02c950b2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`009ecdb0 fffff800`02c93214 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`03115fc0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiScanInterruptObjectList+0x4
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02c950b2 90              nop
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiDoubleFaultAbort+b2
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
FAILURE_BUCKET_ID:  X64_0x7f_8_nt!KiDoubleFaultAbort+b2
Drivers:
fffff880`0478f000 fffff880`047cd000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00f7e000 fffff880`00fd5000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`01400000 fffff880`01489000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`03e77000 fffff880`03e8d000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`065e1000 fffff880`065e9000   ALSysIO64 ALSysIO64.sys Sun Apr 19 15:41:04 2009 (49EB7E50)
fffff880`011db000 fffff880`011e6000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`04e30000 fffff880`04e39000   aswFsBlk aswFsBlk.SYS Tue Sep 07 10:47:09 2010 (4C86506D)
fffff880`04c00000 fffff880`04c3a000   aswMonFlt aswMonFlt.sys Tue Sep 07 10:47:32 2010 (4C865084)
fffff880`01489000 fffff880`01493000   aswRdr   aswRdr.SYS   Tue Sep 07 10:47:47 2010 (4C865093)
fffff880`02f4e000 fffff880`02f71000   aswSP    aswSP.SYS    Tue Sep 07 10:52:07 2010 (4C865197)
fffff880`01581000 fffff880`01591000   aswTdi   aswTdi.SYS   Tue Sep 07 10:52:27 2010 (4C8651AB)
fffff880`065d6000 fffff880`065e1000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`0118d000 fffff880`01196000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01196000 fffff880`011c0000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`00880000 fffff960`008e1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00e5e000 fffff880`00e6a000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`017b2000 fffff880`017b9000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02f3d000 fffff880`02f4e000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`04982000 fffff880`049a0000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
fffff880`018c1000 fffff880`018eb000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00d15000 fffff880`00dd5000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01859000 fffff880`01889000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00cb7000 fffff880`00d15000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`047ed000 fffff880`047f1500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`014c1000 fffff880`01533000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`00e55000 fffff880`00e5e000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`02e79000 fffff880`02e89000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`066e9000 fffff880`066f2000   cpuz135_x64 cpuz135_x64.sys Wed Jan 19 11:42:06 2011 (4D37145E)
fffff880`04875000 fffff880`04883000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02e9c000 fffff880`02f1f000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`02f1f000 fffff880`02f3d000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`03e68000 fffff880`03e77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01843000 fffff880`01859000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04b69000 fffff880`04b8b000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04883000 fffff880`0488f000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0489a000 fffff880`048ad000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0488f000 fffff880`0489a000   dump_msahci dump_msahci.sys Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`04f63000 fffff880`04f6f000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0fee6000 fffff880`0ffda000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`0f200000 fffff880`0f246000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`0104c000 fffff880`01060000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01000000 fffff880`0104c000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01544000 fffff880`0154e000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01809000 fffff880`01843000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01af9000 fffff880`01b43000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff800`03201000 fffff800`0324a000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`0f264000 fffff880`0f288000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`04ad0000 fffff880`04b2c000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`04fd8000 fffff880`04ff1000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`04ff1000 fffff880`04ff9080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`04fca000 fffff880`04fd8000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`048b9000 fffff880`04982000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01800000 fffff880`01809000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`04000000 fffff880`0401e000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`02e63000 fffff880`02e79000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`048ad000 fffff880`048b9000   ISWKL    ISWKL.sys    Thu Sep 02 06:48:35 2010 (4C7F8103)
fffff880`0ffda000 fffff880`0ffe9000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00ba5000 fffff800`00baf000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`00c00000 fffff880`00c43000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`013d0000 fffff880`013eb000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01787000 fffff880`017b2000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`04b8b000 fffff880`04b90200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`04c3a000 fffff880`04c4f000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04e0d000 fffff880`04e30000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c54000 fffff880`00ca3000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`04f2b000 fffff880`04f3a000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`04fbc000 fffff880`04fca000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0ffe9000 fffff880`0fff8000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04e00000 fffff880`04e0d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01123000 fffff880`0113d000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`049a0000 fffff880`049b8000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`049b8000 fffff880`049e5000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`06678000 fffff880`066c5000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`066c5000 fffff880`066e9000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`011c0000 fffff880`011cb000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`0161b000 fffff880`01626000   Msfs     Msfs.SYS     unavailable (00000000)
fffff880`00fde000 fffff880`00fe8000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01060000 fffff880`010be000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`03e5d000 fffff880`03e68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01be8000 fffff880`01bfa000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01634000 fffff880`01727000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`02e89000 fffff880`02e95000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04dca000 fffff880`04ddd000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`00e7f000 fffff880`00eae000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`04abb000 fffff880`04ad0000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`03f77000 fffff880`03f86000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`01591000 fffff880`015d6000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01727000 fffff880`01787000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`04023000 fffff880`04782000   NETw5s64 NETw5s64.sys Wed Jan 13 11:37:13 2010 (4B4DF6B9)
fffff880`0154e000 fffff880`0155f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03e51000 fffff880`03e5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c17000 fffff800`03201000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0122d000 fffff880`013d0000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`018eb000 fffff880`018f4000   Null     Null.SYS     unavailable (00000000)
fffff880`0fee4000 fffff880`0fee5180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`04f3a000 fffff880`04f63000   nvhda64v nvhda64v.sys Thu Nov 11 18:10:36 2010 (4CDC77EC)
fffff880`0f289000 fffff880`0fee3d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`03e8d000 fffff880`03e9d000   nvoclk64 nvoclk64.sys Tue Sep 15 17:59:25 2009 (4AB00E3D)
fffff880`04a00000 fffff880`04a53000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03f3b000 fffff880`03f61000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`011cb000 fffff880`011db000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01533000 fffff880`01544000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`066f2000 fffff880`06798000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04b2c000 fffff880`04b69000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ca3000 fffff880`00cb7000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03fb5000 fffff880`03fd9000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`03fd9000 fffff880`03ff4000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`015d6000 fffff880`015f7000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`01493000 fffff880`014ad000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e00000 fffff880`03e51000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`02fed000 fffff880`02ff8000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01600000 fffff880`01609000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01609000 fffff880`01612000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01612000 fffff880`0161b000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01bae000 fffff880`01be8000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`04ddd000 fffff880`04df5000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`047cd000 fffff880`047ed000   sdbus    sdbus.sys    Sat Nov 20 04:37:42 2010 (4CE796E6)
fffff880`06798000 fffff880`067a3000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01ba7000 fffff880`01bae000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`01b9f000 fffff880`01ba7000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`064cc000 fffff880`06565000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`06600000 fffff880`0666b000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`067a3000 fffff880`067d4000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`047fb000 fffff880`047fc480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`018f5000 fffff880`01af9000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`067d4000 fffff880`067e6000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`01626000 fffff880`01633000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`0155f000 fffff880`01581000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`03fa1000 fffff880`03fb5000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00410000 fffff960`0041a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`02f71000 fffff880`02f97000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`04820000 fffff880`04875000   udfs     udfs.sys     Sat Nov 20 04:26:11 2010 (4CE79433)
fffff880`014ad000 fffff880`014bf000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`04f6f000 fffff880`04f8c000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`04f8c000 fffff880`04f8df00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0f253000 fffff880`0f264000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04a61000 fffff880`04abb000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`02f97000 fffff880`02fed000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0f246000 fffff880`0f253000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`04f8e000 fffff880`04fbb280   usbvideo usbvideo.sys Sat Nov 20 05:44:34 2010 (4CE7A692)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`017b9000 fffff880`017c7000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`017c7000 fffff880`017ec000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0113d000 fffff880`01179000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`01b43000 fffff880`01b53000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`00e6a000 fffff880`00e7f000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`010c7000 fffff880`01123000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01b53000 fffff880`01b9f000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`03e9d000 fffff880`03f32000   vsdatant vsdatant.sys Sun May 09 12:28:58 2010 (4BE6E2CA)
fffff880`04b91000 fffff880`04be3000   VSTAZL6  VSTAZL6.SYS  Wed Oct 15 20:53:42 2008 (48F69096)
fffff880`04e60000 fffff880`04f2b000   VSTCNXT6 VSTCNXT6.SYS Wed Oct 15 20:52:22 2008 (48F69046)
fffff880`04c56000 fffff880`04dca000   VSTDPV6  VSTDPV6.SYS  Wed Oct 15 20:57:45 2008 (48F69189)
fffff880`04782000 fffff880`0478f000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`03f61000 fffff880`03f77000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03f86000 fffff880`03fa1000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`017ec000 fffff880`017fc000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ecb000 fffff880`00f6f000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f6f000 fffff880`00f7e000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03f32000 fffff880`03f3b000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00030000 fffff960`00341000   win32k   win32k.sys   unavailable (00000000)
fffff880`01179000 fffff880`0118d000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`047f2000 fffff880`047fb000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fd5000 fffff880`00fde000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`04e39000 fffff880`04e5a000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`02e00000 fffff880`02e63000   yk62x64  yk62x64.sys  Mon Feb 23 10:02:27 2009 (49A2BA83)
Unloaded modules:
fffff880`065e9000 fffff880`065ef000   RTCore64.sys
    Checksum:  00000000
    ImageSize:  00006000
fffff880`06565000 fffff880`065d6000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01889000 fffff880`01897000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01897000 fffff880`018a3000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018a3000 fffff880`018ae000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`018ae000 fffff880`018c1000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Top Bottom
