Red X on network icon atfer installing Bluesoleil (8.0.356.0 ).
Hi guys,
I recently installed Bluesoleil 8.0.356.0 on my pc and my network icon gives me a red x symbol even though I'm connected to a network or if there are networks available. I tried uninstalling and rebooting, but no luck. Anyone else have this problem? Any help would be appreciated.
patcooke
Microsoft MVP
Microsoft MVP
Is your network adapter showing as fully working in device manager? And what does your ipconfig listing show for it?
No ! or ? in my device manager, and my Network adapter says it's working properly. As for my ipconfig listing...
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Jay>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Jay-MSI
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : ADAB-F.local
Ethernet adapter Local Area Connection 5:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TAP-Win32 Adapter V9 for VPNReactor #2
Physical Address. . . . . . . . . : 00-FF-C2-F2-0B-B5
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection 3:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #
2
Physical Address. . . . . . . . . : 68-5D-43-08-ED-AB
Wireless LAN adapter Wireless Network Connection 2:
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Killer e2200 PCI-E Gigabit Ethernet Contr
oller (NDIS 6.20)
Physical Address. . . . . . . . . : 8C-89-A5-00-55-33
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : ADAB-F.local
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230
Physical Address. . . . . . . . . : 68-5D-43-08-ED-AA
Link-local IPv6 Address . . . . . : fe80::bcdc:1c0b:234e:8dc%11(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.51.63(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, December 07, 2012 10:42:24 AM
Lease Expires . . . . . . . . . . : Friday, December 07, 2012 11:19:51 PM
Default Gateway . . . . . . . . . : 10.0.51.1
DHCP Server . . . . . . . . . . . : 1.1.1.1
DHCPv6 IAID . . . . . . . . . . . : 234886400
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-03-A7-33-8C-89-A5-00-55-33
DNS Servers . . . . . . . . . . . : 10.0.10.90
80.227.2.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{9DA739AB-9FB3-4749-B865-415D4B60F10B}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.ADAB-F.local:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter Reusable ISATAP Interface {3A1B7A86-8ECE-4AC2-B590-309C7364A528}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
patcooke
Microsoft MVP
Microsoft MVP
I assume you're referring to the wireless adapter. Three points to start with:
1. Both the the dhcp and dns server addresses are very odd - are you part of a greater network? Have they been manually or automatically set?
2. You have IPv6 configured and you are unlikely to be using it - you should consider disabling.
3. The lease time for your IP address allocation is very short - you might amend your router config to lengthen it.
I'm currently deployed now and using the network the base provides, which I assume is the reason for the odd address.
How would I go about disabling the IPv6?
I've been using this network for some time now and everything was working fine. It started when I installed that bluetooth program Bluesoleil, so I'm sure it has something to do with that.
patcooke
Microsoft MVP
Microsoft MVP
Sorry but not sure what this means. Do you mean you are part of a subnetwork attached to a larger one and are you on a router or cable connection?
IPv6 is accessed via the properties of the wireless network adapter.
#7
I'm in the military and not in country. But I believe that its part of a sub network, and its a router connection.
patcooke
Microsoft MVP
Microsoft MVP
#8
Ok - that explains a bit. Depends on your setup on the sub and main network but I'd first try setting the dns server address to 10.0.51.1
#9
The thing is, I believe my connection is fine. Its gotta be something that program changed or did. Thanks so far for the help =)
I've been using the same connection for the past month now, and I always look at my network icon to see how strong my signal is, and it happened when I installed that damn program :mad:.
patcooke
Microsoft MVP
Microsoft MVP
#10
Easiest way to check that out would be a system restore back to before the install.
#11
I was afraid of that answer lol. I'll see when my last save point was. Thanks.
patcooke
Microsoft MVP
Microsoft MVP
#12
Bluesoleil should have created one for you.
#13
Just did it and its back to normal. Don't know why it did that, at this point I don't care. Thanks for the help Pat!:)
patcooke
Microsoft MVP
Microsoft MVP
#14
Thanks for the feedback. For future reference for yourself at least might be interesting to examine your ipconfig now and see if some changes were being made to that or if the problem was caused by changes made in other areas.
#16
To resolve this problem
Simplest way is just restore your computer
goto
Start menu > All Programs > Accessories > System Tools
Then select System Restore
And select restore point when Bluesoleil is installed
This is done.
Thank You.
#17
1-device manger show all HIDDEN device UNINSTALL all network devices from network if some of them not delete disable it
2-from your lan driver use the uninstall
3-remove your cable then restart
4-type in start regedit >>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network
5-right click export network on desktop and delete config do not restart your pc
6-install your lan driver
7-put your cable fixed
the sol is by obada_jaber mechanical engineer
