Regular BSOD - won't restart unless power disconnected for 15min or more!!
This BSOD has been happening more regularly, sometimes after 30mins, other times after a couple of hours.
If I try and restart it crashes shortly after Win 7 logo appears.
Unless I disconnect the power for at least 15mins, it won't restart Windows - just re crashes.
Have attached the dump and sysdata files - note that the two files are not always written.
Hopefully someone can analyze this for me.
Rig is i7-920 on an ASUS P6TD Deluxe(not overclocked), Win 7 SP1, Nvidia Quadro FX 1800, 12gb Patriot RAM, disks are WDC Raptor 280GB for OS, Patriot Warp V2 64GB SSD, and 2 x 1TB Seagate Barracuda's in Raid 0
Thanks
Brian
Mike
Windows Forum Admin
[FONT=Courier New][SIZE=2][COLOR=#000000]Crash dump file:        C:\Users\Mike\Downloads\SysCrashData\020612-55037-01.dmp
Date/time:              2/5/2012 5:23:49 AM GMT
Uptime:                 01:25:26
Machine:
Bug check name:         [URL="http://www.google.com/search?q=MSDN+bugcheck+INTERRUPT_EXCEPTION_NOT_HANDLED"]INTERRUPT_EXCEPTION_NOT_HANDLED[/URL]
Bug check code:         0x3D
Bug check parm 1:       0xFFFFF88004DDBF40
Bug check parm 2:       0x0
Bug check parm 3:       0x0
Bug check parm 4:       0xFFFFF880015C6E47
Probably caused by:     [URL="http://www.google.com/search?q=ntoskrnl.exe"]ntoskrnl.exe[/URL]
Driver description:     [URL="http://www.google.com/search?q=NT Kernel & System"]NT Kernel & System[/URL]
Driver product:         [URL="http://www.google.com/search?q=Microsoft® Windows® Operating System"]Microsoft® Windows® Operating System[/URL]
Driver company:         [URL="http://www.google.com/search?q=Microsoft Corporation"]Microsoft Corporation[/URL]
OS build:               Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Architecture:           x64 (64 bit)
CPU count:              8
Page size:              4096
Bug check description:
This bug check appears very infrequently.
Comments:
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
[/COLOR][/SIZE][/FONT]
There are nearly half a dozen Norton driver modules in the crash dump. Consider following the steps outlined below to determine if the crashes continue to happen without Norton.
http://windows7forums.com/blue-scre...ode-0x3d-interrupt_exception_not_handled.html
Thanks Mike for the quick reply,
Using BlueScreenView I notice that (along with ntoskrnl.exe) Mv61xx.sys, are the only two marked as 'appears in the crash stack'
Re Norton, I have a Norton suite installed, plus Norton Ghost backup utility.
Mike
Windows Forum Admin
I was looking at all loaded modules from the time of the stop. It is quite possible that the persistent slowdown you describe in the boot process is caused by a driver conflict. As antivirus would be typically suspect, and as these are the most predominant modules loaded (outside of Microsoft ones), this would be a starting point. Have you checked event viewer logs around the time of the slowdown (which you describe as a sort of outage). I would suggest doing so and also would ask if Saltgrass or Elmer can check this one.
Hi Mike,
Firstly I might have found the culprit - Norton Ghost - more after this,
Re event viewer - nothing obvious - there is only an
Event 41 Kernel-Power
"The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly".
Re rebooting , in a normal (successful) Windows start-up I hear a couple of sets of disk chatter, after one of these crashes the logo comes up, then a brief disk noise then silence, within 5 secs or so another VERY brief BSOD (only about half a second ! no time to read it) then it shuts down and tries to restart- viscous cycle.
What intrigues me is why disconnecting the power for some minutes enables a reboot?? But if I don't - even after an hour or so Windows still won't start. Is there something stuck in memory?
Now re Norton Ghost, because I was getting BSOD after 30 mins or so after boot, Ghost had missed backing up my main Raid 0 drive(s), so I've been trying to do manual runs the last few days, I've noticed that each time I've tried this (4-5 times ) I get a BSOD after about 5 mins. So earlier this evening I stopped the Ghost service - at the moment the PC has been up for over 6 hours with no BSOD. I'll let it run all night and see if this lasts :).
Another point is that I think this Ghost issue might only happen when I try and run it against my Raid drives, I was able to run it on my smaller system drive (300GB Rapter) and my SSD drive. I note again that mv61xx.sys was in the crash stack - I believe mv61xx.sys is related to a Marvel IDE/SATA driver.
