Windows 7 Remote Desktop Problems - Can't log back in after using RDP
ridergroov1
Hi folks. I'm trying to see if anyone else is having problems with remote desktop. A lot of the times it works fine but sometimes after I RDP into windows 7 then try to go back I get kicked out instantly and see a little message saying "Device attached to the system has malfunctioned". It only flashes for an instant then goes away. If I try to go to the computer itself and log back in after this happens, it acts like it is going to login then goes right back to the password screen. I have to reboot every time this happens. Ideas? Thanks.
pgessford
I'm experiencing the same thing. Quickly flickers the "a Device has malfunctioned" and then remote desktop abruptly closes. You can't login at the console either as you say. A reboot is the only thing that gets it working correctly. This doesn't always happen though. Once or twice a day.
ridergroov1
I'm glad that it's not just me. Well, you know what I mean. Seems like a pretty large oversight on MS part. That's a pretty big problem I'd say. I thought it was because I was using a nonstandard port but it has happened since I changed back to standard as well. I'm using the lowest form of remote authentication. No network authentication.
To: Microsoft
Microsoft,
Please fix this.
Regards,
Locked out user.
pgessford
I'm using Less Secure
Allow connections from computers running any version of Remote Desktop (less secure)
I don't know if this happened at the same time I started using an 8 GB flash drive and enabled ReadyBoost for that device. Probably just a coincidence. You didn't do anything simliar, correct ridergroov1?
